Turbo vs. Vortech s/c
I wonder what I would the 1/4 in. I have 438rwhp @ 350rwtq. My car is a heavy 3450 (zr) What do you guys think? My buddy has a 06 Vette with h-pipe and exhaust. His best was 12.9, can I beat him?
Originally Posted by FrickU
Depends on the turbo kit. Some start boosting at 2300 rpm's, and others start boosting at 4+
no VQ turbo kit that I know of starts boosting past 4krpm
most all of them have full boost in the 3krpm range
Originally Posted by sentry65
IMO turbos will have higher peak torque
IMO the vortech will have about equal top end as a turbo at the same psi
Originally Posted by Sentry
IMO it is easier to get traction and manage it with the vortech because the torque doesn't come on so fast to overpower the tires, but it won't kick you back in your seat as much, so the fun factor isn't as high
IMO an equal psi turbo is roughly .5 sec or less faster in the 1/4 mile with everything else being equal
IMO the vortech is safer than a turbo and less likely to create head lift from having too much peak torque for what the stock headgaskets can hold
IMO I've seen some time slips with stock vortechs and exhaust/plenum on stock tires run 12.5-12.6's on good days and 12.8-12.9's on bad days
IMO I haven't heard of many people running slicks with vortechs in the 1/4 mile. Usually just street tires unlike the turbos guys running slicks
IMO the vortech is a different animal than turbos and more often than not bashed because of it's lack of peak torque and slower spool up and parasitic loss
Originally Posted by Nealoc187
What were your trap speeds and 60' times? That is a pretty good time bro.
Originally Posted by Alberto
That translates to "I cant launch a car with TQ so I'll play my S/C's weakness as a benefit"
How is that possible? If a Vortech is easier to launch and has equal top end to a turbo Z your telling me the turbo's midrange alone makes it .5 faster on average down the 1/4?mmmm---> Turbo's win from the beginning of the race to when you let off in defeat.
Shouldn't you of all people know if a turbo Z with slicks goes to the strip and does a 11.9 and then a "stock" vortech on street tires does a 12.5 that they're comparable, but the edge does go to the turbo probably cause slicks will do to help the turbo car than they will to help the vortech car
TQ doesnt cause head lift.
Stock Vortech means a Vortech not tuned. Please show me one 12.5 second time slip from an untuned, stock pulley Vortech with exhaust/plenum running mid 12's. Ive been on this forum for years and never seen it. Best Ive seen for a bolt-on stock map Vortech is 12.9 @ 108mph. Average is low 13's @ 110mph or less....
I was meaning stock as in you take a stock vortech kit added to some typical things like exhaust, cats and plenum, and then tune the thing. I wasn't considering tuning optional. I think everyone should get their FI car to a shop to tune - not just for power, but to double check A/F etc
I'd hate to see a "stock" turbo run with no tune and no exhaust anything. Those setups usually run high 12's as well right?
btw, does everyone who has a FI Z post on these boards? Does everyone who's a track junkie come home and post times for Alberto to see? Some people just go to the strip, do some runs and some of them might even be pretty decent like mid 12's. Not everyone feels the need to rush back to My350Z.com and post up scanned time slips to prove to the world that they have some big ***** or something
I don't see very many people at all that have a bone stock car, with a bone stock FI kit, bone stock tune and NOTHING else. Everyone usually has an exhaust and plenum or something else added in the mix. Everyone usually tries adding some cheap bolt on NA parts first before they decide they need to step up into FI and I thought most people usually bothered to take their car to the dyno to get tuned since base FI tunes were not tuned with the assumption people would have breathing mods already
Your 100% correct, why dont S/C guys spend $500 on wheels/tires for the track and prove these theories they like to post around the boards?
I guess the vortech guys don't want to be 1/4 mile gods like you alberto. I suppose one theory might be want to actually be out driving their car instead of busting up their transmission or axels and other things?
For the record Im not bashing S/C's different strokes for different follks, but the way you play up your S/C is hilarious. You cant compare your tuned & cammed & 3.9FD S/C Z, to a stock base map TN/turbo kit, even then Id bet you would have trouble pulling away if you could at all....
the base TN kit probably is the god of all things performance
360whp TN OwNZ sentry65
btw, where did I bring my car vs a base TN into this discussion?
I might believe that a base 360whp TN Z might feel faster than my car, cause that's one of the things turbos do - make you feel faster than you actually are
http://www.panhandlez.com/videos/satracing2.wmv
Check out this Vid there`s a race inside between 350Z`s for Vortech vs Turbonetics ST, am sure it will give you the idea you wanted.
forgot what the specs were between those two cars but if they're roughly equal in whp and weight etc that's probably about what I'd expect
I still think 10 psi with a vortech setup is about as safe as 8psi is on a turbo and even though some people will disagree, I think that's a more fair comparison than 8psi vs 8psi SC vs turbo because we know that the vortech wouldn't see max boost until redline anyway. To hell with whatever the different FI kits give you as a stock tune/setup
original thread:
https://my350z.com/forum/showthread....satracing2.wmv
backagain's vortech 8psi car at that time:
379.55whp
1_2_NV's TN car:
?? whp
backagain's newer tune/setup as of march 2006:
379.55whp
1_2_NV's TN car:
?? whp
Originally Posted by backagain
yea, the tune helped a lot, in the video i was hitting just under 8 lbs of boost, im hitting almost 9.5 now for some odd reason. if you arent busy in the next day or so 12 nv we should get together and do it again. stop by and check out the fence i just built also.
Originally Posted by 1 2 NV
Actually I(tn brickyard z) beat backagain (silver vortec z)by a hair since his tune. But his car is a different animal now. I ended up frying my clutch in the process though!
vortech with 3.12 pulley, dc sport headers, pro-1 test pipes, borla td exhaust, weight is ~ 3700 lbs though with stereo equip. i weighted it at a weigh station. if i could get the weight down i should be doing a little better with my track times. i dont have a 1/4 mile track anywhere around here but at our local 8th i ran a 8.411 at 86.87 mph with a 2.12 60 ft time. should calculate to a 12.8 or 12.9 from what i've seen other guy run.
you can't compare 10psi vs 8psi anything. 8psi vs. 8psi, same mods, is an equal comparison....nothing else.
Compare a TN with exhaust and a Vortech with exhaust. The TN will have more torque, by at least 50 ft-lbs, will out accelerate in the midrange and therefore leave the Vortech. That's just how it works.
you can't throw in an extra 2psi plus more supporting mods and say it's equivalent to 8psi on a TN
thing is, an exhaust does a lot more for a turbo than a SC because it doesn't just change power, but also how the turbo spools up.
and actually, PSI between a SC and turbo are not compatible. The turbo has a wastegate to maintain a constant psi and the SC doesn't
With a SC, if you change to a really open exhaust the psi goes down while the power goes up. It is possible for a turbo with 8psi to be outperformed by a SC with 7 psi if the SC car has a really open exhaust and cams etc
if we did that comparison with TN vs vortech with each having an exhaust, the vortech would lose boost so it'd be like 8psi TN vs 7psi vortech. But that certainly isn't fair under your psi = psi rules. So then you'll need to change out the vortech pulley to the 3.12 to get back that additional 1 psi on your boost gauge - which also adds another 25whp
Simple fact is, the vortech has a different range of powerband than the TN kit. The TN will wear out the engine more in the midrange than the vortech will. To make up for the difference, you gotta change out the pulley on the SC. What if Vortech came with the 3.12 pulley as stock? No one can help that they decided the 3.33 pulley was where they wanted their base tune to start out at
Originally Posted by 617G
Won't the open exhaust even more drastically reduce tq?
yeah IMO you DO NOT want a dual 3 inch exhaust with the vortech unless you're making like 600whp with it which hasn't been done quite yet, but give it time...lots of developments happening right now
no one has brought up gearing yet. IMO the vortech's ideal final drive is the 3.917 and the turbo's ideal FD is the stock 3.538 with the exception of certain setups and types of racing the 3.36 being more ideal. A lot of turbo guys get the 3.36 FD for what IMO are the wrong reasons and then end up being stuck with slower accelleration. The big whp guys with 600+whp probably need all the help they can get though as far as traction and not shifting so fast.
IMO you want the most aggressive gearing that can maintain your traction threshold with none or little wheelspin. The vortech works with the 3.9 very nicely since it doesn't have the little burst of torque between 3500-4500's the single turbos have. In some races you'll have to shift more, in others you won't.
, and I think you're right. The longer gears will allow a turbo car to be in its power range a lot longer, while the shorter gears will allow the s/c to achieve more power quicker and be at a higher rpm point after upshifting and thus closer to peak power at all times.
yeah the main thing I think is control.
Turbos are going to spool up fast, hit hard with a lot of torque and go thru the gears pretty quick to the point that in some cases slowing everything down will give people a little more edge in controlling their car which might end up making it faster in the end.
The vortech is the opposite since it already has a higher control threshold since it's not making as much boost in the midrange - kinda halfway between an NA car and turbo car. So speeding things up with the 3.9 FD is completely viable and my car is living proof that it works well
as an example using 6th gear:
at 80mph in 6th gear with the 3.917 FD, you're around 3300 rpms.
at 80mph in 6th gear with the 3.358 FD you're around 2750 rpms
that'd be like a 40-60 tq advantage in favor of the SC due to the higher rpm range and because the SC is actually already making some boost while a ST is just starting to, and then there's the 16.5% gear torque advantage that the 3.917 FD has over the 3.358
Still though, the 3.36 FD IMO is only useful for certain cars under certain types of racing (like 1/4 mile to eliminate the extra shift). Otherwise if you have some good racing class tires, the stock FD is going to be ideal. One thing is for sure, it'd make better gas mileage on the highway
