APS TT Forge Actuator question???
Old Nov 15, 2006 | 03:31 PM
  #61
Julian@MRC's Avatar
Julian@MRC
Originally Posted by clemlover15
I just called Z1 770.838.7777, some guy kinda of a dick told me that APS makes upgraded actuators, I asked how much $ and didn't know but they are available he says, then he told me that they have them on there car that make 570 (stock motor) at the wheels @12psi.
based on that statement I don't think this is 100% accurate or is he??
570@12psi on a stock motor..I would think you would picking up your rods and pistons with a broom and dust pan..
Old Nov 15, 2006 | 03:32 PM
  #62
MIAPLAYA's Avatar
MIAPLAYA
No way, I saw it. It had FIVE turbonators and a DPS box...
Old Nov 15, 2006 | 03:35 PM
  #63
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It was probably one pass on the dyno wth C16. Anything is possible...once or twice.
Old Nov 15, 2006 | 03:38 PM
  #64
Julian@MRC's Avatar
Julian@MRC
Well We just replaced our forged actuators today with one that work..Now the problem is, we cant build "Enough" boost..My boost peaks only at 14psi, but takes till 4900-5000 to build now I suspect we need a bit more tension on the springs..Which may be what tore the diaphrams in the first place..External wastegate set ups really SUCK
Old Nov 15, 2006 | 05:03 PM
  #65
tig488's Avatar
tig488
i suggest you convert those bad boys to dual port wastegates
thats one thing i did notice while changing the springs, there is no piece of metal to take the pressure of the spring off the diaphragm, the spring sits right on the diaphragm, thats gotta be whats causing them to tear.
Old Nov 15, 2006 | 06:30 PM
  #66
Weqster's Avatar
Weqster
Another option is to use a split dump pipe design and weld on an external wasstegate flange onto the wastegate gump outlet. Remove the internal gate flapper and u are set. THis will allow the best boost control without moving to an externals/manifold setup. the hard part is getting a nice seal on the split dump, which can be hard depending on the turbine housing design.
And also, any welder worth there money can weld steel to iron. U Must heat and cool it properly, but it can be done reliably without doubt.
Old Nov 15, 2006 | 07:57 PM
  #67
MIAPLAYA's Avatar
MIAPLAYA
I've never seen a shop locally do it and do it right. Heating the iron to the proper temp and cooling it can be done but if you screw it up at all prepare for cracked welds. I'm saying it would be MORE reliable to either make then entire manifold cast or out of SS321 or 304
Old Nov 15, 2006 | 08:08 PM
  #68
350zDCalb's Avatar
350zDCalb
builtZmotors
hahahahha
Old Nov 16, 2006 | 05:13 AM
  #69
Julian@MRC's Avatar
Julian@MRC
You know what I find funny..Companies that manufacture CAST manifolds claim CAST to be Superior and less prone to cracking than Tubular designs..And companies that manufacture tubular manifolds claim their designs to be better and less prone to cracking than CAST manifolds..
I have seen both designs fail, so it seems as if it is "hit or miss" when it comes to a good manifold. I had a severe crack in my CAST manifolds when I pulled my motor last year to do my heads..I never would have known if I had not pulled my motor to do my heads.
Old Nov 16, 2006 | 07:15 AM
  #70
MIAPLAYA's Avatar
MIAPLAYA
Well for all intents and purposes a properlly designed cast manifold should last forever. The problem is its not nearly as easy to weld to it so if you don't include bracing in your mold for the manifold its basically relying on its own structural integrity to hold it up unless you can find a way to brace it to the block. Although I will say most cast iron manifolds are strong enough to hold up for almost ever if there is not too much weight on them. A lot of companies prefer them because they can be made quickly once the mold is made and the process can be repetead very accurately as there will be no variance in them. No chance for someone to weld them a little off, heat to warp the flat surface of a flange, etc. The downside is they can't always be made in the design you want and I have yet to see an equal length Cast manifold and sincerely doubt it can be done correctly. Stainless is nice because it offers you a lot of flexibilty in the manifold to account for vehicle variance and future design changes but suffers from the above listed issues. In the end a properlly designed cast or stainless manifold are just as good. For this application I would do a stainless setup. For the simple fact that APS is charging an arm and a leg for the Extreme manifolds.
Old Dec 7, 2006 | 10:33 AM
  #71
brooke's Avatar
brooke
Old thread but any new updates on better actuators or ideas???
brooke
Old Dec 7, 2006 | 10:35 AM
  #72
Julian@MRC's Avatar
Julian@MRC
brooke
EXTERNAL WASTEGATES are made for a reason..
Old Dec 7, 2006 | 09:14 PM
  #73
brooke's Avatar
brooke
Thanks but no help... I pickup my built motor next week and need a plan for more boost. I do not want to waste money on actuators since I know they will fail... Where's peter when you need him?? Surely they would have known their customers were going to raise the boost so why not have options to them??
brooke
Old Dec 8, 2006 | 04:58 AM
  #74
Julian@MRC's Avatar
Julian@MRC
brooke
Peter was banned 2 years ago..lol , you could try the forged actuators or go with the ones tha Mia posted.
http://www.forgemotorsport.com/
Old Dec 8, 2006 | 07:58 AM
  #75
tig488's Avatar
tig488
brooke
this is peter youre talking about, they make them, but they cost 2000 dollars, and youre gonna have to wait 6 months to get them. its just another addition to the kit.
Old Dec 8, 2006 | 08:29 AM
  #76
KPierson's Avatar
KPierson
The only issue I see is if the Vehicles speed sensor will send a good signal to work with the Dtec, since it works of the CAN bus communication with the vehicles BCM, and has no output wire on the ECU to tap off..
I'm using the VSS to control my auto door locking system with no problems at all. There is an actual VSS wire, it just doesn't run to the ECU.
Old Dec 8, 2006 | 08:57 AM
  #77
Julian@MRC's Avatar
Julian@MRC
Does it run to the BCM?
Old Dec 8, 2006 | 10:11 AM
  #78
KPierson's Avatar
KPierson
To my knowledge it doesn't, but it does run to the A/C controller. It also runs to the Navi (if equipped) and a few other various places. The best bet is right at the AC controller though, and I believe in my '04 G35 it was a white/green wire.
Old Dec 8, 2006 | 10:47 AM
  #79
Julian@MRC's Avatar
Julian@MRC
interesting....
Old Dec 8, 2006 | 03:14 PM
  #80
XBS's Avatar
XBS
Veteran
On the G35 Coupe it is the white/green wire that runs to the A/C display up to were the clock is.
I just tapped it the other day for my Avic Z1, works great
-George
