Has anyone broke 500whp with an ST?
Old Nov 5, 2006 | 03:04 PM
  #41
rocks's Avatar
rocks
If it takes to long to spool, could just use a 25 shout of nitrous for alot faster spool up. 25 shot on a turbo car is like 75hp.
Old Nov 5, 2006 | 03:24 PM
  #42
Gman2004's Avatar
Gman2004
Originally Posted by rocks
The reason i like single turbos more is it is less complex and easier to install my self, as in the engine doesnt have to come out.
well if you are building your motor which you said you were it has to come out.
Old Nov 5, 2006 | 03:26 PM
  #43
rocks's Avatar
rocks
Haha i have just enough to do the motor. I bought the car in august, engine blew up the first month so i decided to build it rather than put a used engine in it. If i had another 8k$ to blow i would turbo it, sucks it has to wait. Im going to have a built engine and no turbo heh.
Old Nov 5, 2006 | 03:29 PM
  #44
tig488's Avatar
tig488
build it and put a 300 shot on it until you have the money for a turbo kit.
Old Nov 5, 2006 | 03:30 PM
  #45
Gman2004's Avatar
Gman2004
so you are rebuilding with low compression and still driving it n/a? man that thing is going to be a dog until you get your turbo.
Old Nov 5, 2006 | 03:33 PM
  #46
rocks's Avatar
rocks
its 9:1 compression, ill just advance the timing as far as i can. I have thought about using a 200shot of nitrous with a digital controller untill i can afford a turbo. Should only lose about 15-20hp with it n/a. I orderd some headers for it and testpipes so that should give a little power back. I hope... Engine should be done and in the car next weekend. Todd at built z motors is doing it.
Old Nov 5, 2006 | 07:35 PM
  #47
Shabib67's Avatar
Shabib67
If someone can come up with a ST kit that can run turbos like the gt40r, gt42r or turbos in that size, you would see huge horsepower numbers. Also they wouldn't lag that much compared to other cars like supras or evos that have gt40r and gt42r since the VQ is 3.5L.
Old Nov 5, 2006 | 07:37 PM
  #48
rocks's Avatar
rocks
You can make it 3.8l with sleeves and 100mm pistons. The only thing is the space contraints with a single turbo that big and the huge exhaust.
Old Nov 5, 2006 | 08:05 PM
  #49
lemansz20's Avatar
lemansz20
On jetpilot's defense, I am in his same shoes. I didnt get cams b/c theyre was really nothing very good out that was turbo specific when I built my motor. NOW, there finally releasing some options of turbo specific cams. AND I promise you their is no way if he puts cams in that he will make power till redline. The TN 60-1 just doesnt have the flow characteristics to do it.
Old Nov 5, 2006 | 09:40 PM
  #50
taurran's Avatar
taurran
Really? How long ago did you build your motor? All of the JWT, Tomei, and Scotts cams are better than stock even if they aren't specifically for a turbo application and they've been out for a long time now. I didn't personally say they would absolutely build power till redline, but they certainly would help a lot. Besides, all of the newer JWT cam choices have been out for a few months now, I think jetpilot's build was started after they were available.
By the way, a 60-1 compressor housing can flow PLENTY for that type of power on this car. The issue is with the T3 turbine housing, which, as stated, was selected for its spool characteristics for the intended power delivery of this kit. So far the only people that I know that have upgraded turbos with the kit have only upgraded the compressor housing, which won't get you too far.
Old Nov 5, 2006 | 09:50 PM
  #51
JETPILOT's Avatar
JETPILOT
I was waiting for the GT Motorsport cams to come out. They were a little too late in releasing their new FI cam. My heads were there @ GTM being built but the cams didn't make it in.
Why does everyone talk about making power to "redline". The car as delivered from Nissan doesn't make power to "redline". "Redline" is 6600 RPM on the non-rev up. The cams make power to 6250RPM. That is not "redline". I am glad I could clear that up.
My turbo is being exchanged for a warranty issue and I am having a custom spec turbo returned to me.
JET
Old Nov 6, 2006 | 05:14 AM
  #52
lemansz20's Avatar
lemansz20
You kinda contradicted yourself here man. Is the turbine housing, NOT apart of the turbo??? I dont think so, so that makes it APART of the turbo. MEANING the turbo cant make the certain power on this motor. I know b/c I have the same problem, but Im waiting for the new gtk turbos. Ill be able to get the power I want without cams, and most likely just with this upgrade. FYI I was waiting for the turbo specific gt motorsports cams also. When the TN gtk stage 2 comes out, ill do headwork and cams simple as that.
Old Nov 6, 2006 | 09:14 AM
  #53
chimmike's Avatar
chimmike
why? We don't have any dyno proof of them, or specs either....what makes them better than the numerous options available on the market now?
I'd be willing to bet they're similar to JWT S1 cams.
I'd also be willing to say I don't think there's any n/a specific cams on the market right now.......so why request something that says turbo specific?
Old Nov 6, 2006 | 09:55 AM
  #54
synth19's Avatar
synth19
hopefully I can break the 500whp mark come spring when I upgrade EMS and FM.
Old Nov 6, 2006 | 10:34 AM
  #55
sugarspunZ's Avatar
sugarspunZ
hopefully i will beat you to it. heheheheee
Old Nov 6, 2006 | 10:54 AM
  #56
synth19's Avatar
synth19
The race is on!
Old Nov 6, 2006 | 11:35 AM
  #57
taurran's Avatar
taurran
No I didn't. I stated that if you had issues with the turbine housing not flowing adequately you could swap it out for a different housing. Go read my post again before trying to tell me I'm wrong without understanding the subject.
Old Nov 6, 2006 | 01:36 PM
  #58
lemansz20's Avatar
lemansz20
Im not gonna start a stupid childish argument about a stupid turbo online. YOu go think what you want, and go make 600 hp with your 60-1. Good Luck.
Old Nov 6, 2006 | 02:00 PM
  #59
taurran's Avatar
taurran
Who's childish?
You're just showing here that you know very little about turbochargers. I will never claim to be an expert on the subject personally, but at least understand the basics of it. Perhaps you should go back and read a few books before coming here and making claims about this "stupid turbo".
Fact is, that a 60-1 compressor mated with a T4 turbine housing and properly sized wheel will make well over 500whp on this motor.
I'm not going to attempt to make this kind of power on my car because:
A) My car makes good enough power on the stock motor with the turbo that's included in the kit.
B) I understood the power levels this kit was intended for upon purchasing it.
C) If I do want to go for more power I'll just wait until Turbonetics launches a properly designed system designed to handle it.
D) I possess a thing called "patience".
Thanks, but I'll continue subscribing to this thing called "reality", not just making blind assumptions based on what I read here.
PS: I'm not the one trying to make 500+whp on this turbo alone. You are.
Old Nov 6, 2006 | 02:01 PM
  #60
chimmike's Avatar
chimmike
LOL!!! Wow....talk about posts coming out of left field....I think this one was thrown in from the 600' mark.
