flashing "service engine soon" light
Old Nov 7, 2006 | 05:16 PM
QuadCam's Avatar
QuadCam
I'd have to have cats for that to happen!!
Old Nov 8, 2006 | 03:45 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would probably set your timing to around 30 at peak tq, i promise if you do that, your SES light wont come back on again for a while....
*Disclaimer* i am kidding..
Old Nov 8, 2006 | 06:27 AM
QuadCam's Avatar
QuadCam
I think I'll try that.
Old Feb 27, 2007 | 11:53 AM
ACEMAN's Avatar
ACEMAN
Master
Flashing Service engine soon light
Mine just started doing this today. And now the car is running real rough. And there is a strong smell of gas. The car also does not have as much power. Its not running in safe mode, had that happen before. Its just runs really rough.
To me it seems as if one of the plugs are not firing or maybe a coil pack. I have a O2 sensor on the driver side and it is reading fine. So i assume its on the passenger side.
Tomorrow i am going to Auto Zone to see what the cell is.
What do you guys think?
Thanks
Todd
Old Feb 27, 2007 | 12:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Thanks
Todd
If your SES light is flashing it indicates that a misfire event is occuring at that time.
Old Feb 27, 2007 | 12:06 PM
Kenk2's Avatar
Kenk2
Professional
Thanks
Todd
It happened to me a month back when I was still NA.. I had LOW OIL so you might want to check that. I took it to the dealer and they told me I was low after changing my oil just 2500 miles ago.. Def let the car sit for 20 mins then check it..
Old Feb 27, 2007 | 12:07 PM
ACEMAN's Avatar
ACEMAN
Master
So, what do you think might be causing a missfire. Car has been running great since i have owned it. And i have not made ANY changes to it in over 5 months.
Plug filed out? Coil pack going bad?
Later
Todd
Old Feb 27, 2007 | 12:08 PM
ACEMAN's Avatar
ACEMAN
Master
Will do, Thanks Kenk2
Todd
Old Feb 27, 2007 | 12:23 PM
MIAPLAYA's Avatar
MIAPLAYA
Could be spark blow out. Maybe a spark plug is fouled. Or maybe a coil pack died. You mentioned it smells like gas and is running rich... It sounds to me like on or more cyliners is not combusting...
Old Feb 27, 2007 | 12:30 PM
ACEMAN's Avatar
ACEMAN
Master
Yep, thats what i think is happening. I know its not the drivers side. I have a UTEC installed and the 02 sensor is on that side. It reads fine and is not rich. So i assume its on the passenger side. I guess i will head to Auto Zone tomorrow and see what the code is. That way i know which cylinder is causing the issue.
Later
Todd
Old Feb 27, 2007 | 01:18 PM
ACEMAN's Avatar
ACEMAN
Master
Well, just got back from Auto Zone. It is a misfire and it looks like cylinder #5 code(P0305) Passenger side rear.
Here is the funny thing though. The drive over and back the car ran just fine. No issues at all. So before i order plugs or a Coil pack. What can i do to narrow it down?
Going to check that plug tomorrow to see what it looks like.
Thanks Guys
Todd
Old Feb 27, 2007 | 01:23 PM
Kenk2's Avatar
Kenk2
Professional
Bro I thought the same thing as you.. Took it to the dealer and they said oil was very low..
Old Feb 27, 2007 | 01:32 PM
ACEMAN's Avatar
ACEMAN
Master
Thought i would add this to the thread aswell. Might help someone else later.
Old Feb 27, 2007 | 01:38 PM
Beer Goggles's Avatar
Beer Goggles
I don't know if this is mentioned, but SES in a steady glow means there is an error code. Flashing usually means there is a more serious problem and requires immediate attention.
Old Feb 27, 2007 | 02:05 PM
Juztin's Avatar
Juztin
I've had my CEL flash at me like 2 or 3 times now when just starting up the car (seemed like once in a while over a couple weeks). It only lasted a couple seconds before going back to a solid cel. Hmm probably time to pull teh codes.
Old Feb 27, 2007 | 07:34 PM
MIAPLAYA's Avatar
MIAPLAYA
The ECU will flash the CEL when a misfire event is occuring. Trust me on this. I would pull the plug and see if its fouled first before you go buying a new coilpack..
Old Feb 28, 2007 | 03:23 AM
Audible Mayhem
My350z
maybe your blinker fluid is low todd
Old Feb 28, 2007 | 08:33 AM
  #38
ryan350z's Avatar
ryan350z
Sounds to me the Muffler Bearing may be on its way out?
Old Feb 28, 2007 | 08:45 AM
  #39
Old School's Avatar
Old School
Shift_Boost
You sure its not the flux capacitor or the warp drive?
Old Feb 28, 2007 | 11:12 AM
  #40
ACEMAN's Avatar
ACEMAN
Master
That was my first thought too. BUt i checked it, and its topped off
Well the car ran fine all day today so i got the oil changed. Tomorrow i plan on checking to see if the plug is fouled out or not. Looks like a new coil is almost $80. So i hope its just a little plug.
Thanks for your help guys.
Later
Todd
