JWT clutch limits
Old Nov 9, 2006 | 02:22 PM
clemlover15's Avatar
clemlover15
Default JWT clutch limits
I've read that it is rated at over 500lbs/tq but what have you guys taken it to?
I want to use it with the stock flywheel (to chatter) (daily driver) and max out at 500hp, 450hp daily on low boost, does anyone see a problem??
My motor is nearly done and I want to make sure that this is the right choice.
Thanks for any info.
Old Nov 9, 2006 | 05:39 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive seen it run at 460whp with no ill effects. You may want to upgrade the clutch disc to the heavy duty version for those levels, although pressure plate stays the same, it may help some and it isnt expensive.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
