after 18 months, ITS FIXED!!!
haha, 75% of the kit, is a Tig special, and what do you know, it runs better, well, the IC still fills with oil, but im working on that, probably gonna change the weldon pump out for the mocal unit.
after all this work, it would have been faster, cheaper, reliable-er, and less headache, if i had just had my buddy that did the TT z06 do me a custom kit, but at least i like tinkering and seeing what makes things work "right", if i didnt, i would have thrown this kit away a long time ago.
here is a text file of 4th gear during a run, the zeitronix wont let you save it as a jpeg so im gonna have to take a pic with my dig camera. side note, for some reason my EGTs have gone down a bit, must be the drop in turbulence in the downpipe with the divider in there.
Date Exported: 11/8/2006 7:32:45 PM
Time, AFR, RPM,Boost(PSI/inHg), EGT(F), TPS
6:11:29 PM, 10.40, 6087, 8.10, 1474, 98
6:11:29 PM, 10.40, 6087, 8.00, 1474, 98
6:11:29 PM, 10.40, 6079, 8.10, 1474, 98
6:11:29 PM, 10.40, 6079, 8.20, 1474, 98
6:11:29 PM, 10.40, 6095, 8.00, 1474, 98
6:11:29 PM, 10.40, 6103, 8.00, 1474, 98
6:11:29 PM, 10.40, 6111, 8.00, 1483, 98
6:11:29 PM, 10.40, 6111, 8.10, 1476, 98
6:11:29 PM, 10.40, 6103, 8.20, 1485, 98
6:11:29 PM, 10.40, 6111, 8.00, 1480, 98
6:11:29 PM, 10.40, 6144, 8.10, 1476, 98
6:11:29 PM, 10.40, 6152, 8.10, 1480, 98
6:11:29 PM, 10.40, 6152, 7.90, 1476, 98
6:11:29 PM, 10.40, 6152, 7.90, 1487, 98
6:11:29 PM, 10.40, 6160, 8.00, 1476, 98
6:11:29 PM, 10.40, 6177, 7.90, 1476, 98
6:11:29 PM, 10.40, 6185, 8.00, 1476, 98
6:11:29 PM, 10.40, 6185, 8.10, 1480, 98
6:11:29 PM, 10.40, 6185, 8.10, 1476, 98
6:11:29 PM, 10.40, 6210, 8.00, 1476, 98
6:11:29 PM, 10.40, 6202, 8.10, 1482, 98
6:11:29 PM, 10.40, 6210, 8.10, 1480, 98
6:11:29 PM, 10.40, 6194, 8.00, 1480, 98
6:11:29 PM, 10.40, 6210, 8.00, 1480, 98
6:11:29 PM, 10.40, 6210, 7.90, 1476, 98
6:11:29 PM, 10.40, 6235, 7.90, 1476, 98
6:11:29 PM, 10.40, 6235, 8.10, 1474, 98
6:11:29 PM, 10.40, 6252, 7.90, 1482, 98
6:11:29 PM, 10.40, 6252, 8.10, 1476, 98
6:11:29 PM, 10.40, 6244, 8.10, 1476, 98
6:11:29 PM, 10.40, 6244, 8.00, 1476, 98
6:11:29 PM, 10.40, 6252, 8.00, 1474, 98
6:11:29 PM, 10.40, 6252, 8.10, 1480, 98
6:11:29 PM, 10.40, 6269, 8.00, 1476, 98
6:11:29 PM, 10.40, 6278, 7.90, 1480, 98
6:11:29 PM, 10.40, 6269, 8.00, 1482, 98
6:11:29 PM, 10.40, 6269, 8.10, 1480, 98
6:11:29 PM, 10.40, 6278, 8.10, 1480, 98
6:11:29 PM, 10.40, 6295, 8.10, 1483, 98
6:11:30 PM, 10.40, 6304, 8.10, 1482, 98
6:11:30 PM, 10.40, 6321, 8.00, 1482, 98
6:11:30 PM, 10.40, 6330, 8.00, 1482, 98
6:11:30 PM, 10.40, 6330, 8.10, 1483, 98
6:11:30 PM, 10.40, 6312, 8.10, 1482, 98
6:11:30 PM, 10.40, 6312, 8.10, 1483, 98
6:11:30 PM, 10.40, 6304, 8.00, 1492, 98
6:11:30 PM, 10.40, 6356, 8.00, 1482, 98
6:11:30 PM, 10.40, 6347, 8.00, 1482, 98
6:11:30 PM, 10.40, 6338, 8.10, 1482, 98
6:11:30 PM, 10.40, 6347, 8.10, 1482, 98
6:11:30 PM, 10.40, 6347, 8.10, 1483, 98
6:11:30 PM, 10.40, 6356, 8.10, 1482, 98
6:11:30 PM, 10.40, 6347, 8.00, 1483, 98
6:11:30 PM, 10.40, 6373, 8.10, 1483, 98
6:11:30 PM, 10.40, 6373, 8.10, 1485, 98
6:11:30 PM, 10.40, 6391, 8.10, 1485, 98
6:11:30 PM, 10.40, 6382, 8.10, 1487, 98
6:11:30 PM, 10.40, 6400, 8.10, 1485, 98
6:11:30 PM, 10.40, 6400, 8.20, 1492, 98
6:11:30 PM, 10.40, 6400, 8.10, 1487, 98
6:11:30 PM, 10.40, 6418, 8.00, 1487, 98
6:11:30 PM, 10.40, 6391, 8.00, 1487, 98
6:11:30 PM, 10.40, 6400, 8.10, 1489, 98
6:11:30 PM, 10.40, 6418, 8.20, 1494, 98
6:11:30 PM, 10.40, 6427, 8.20, 1489, 98
6:11:30 PM, 10.40, 6418, 8.10, 1487, 98
6:11:30 PM, 10.40, 6418, 8.10, 1492, 98
6:11:30 PM, 10.40, 6445, 8.10, 1492, 98
6:11:30 PM, 10.40, 6427, 8.20, 1498, 98
6:11:30 PM, 10.40, 6436, 8.20, 1492, 98
6:11:30 PM, 10.40, 6445, 8.20, 1492, 98
6:11:30 PM, 10.40, 6454, 8.20, 1492, 98
6:11:30 PM, 10.40, 6454, 8.10, 1494, 98
6:11:30 PM, 10.40, 6454, 8.10, 1496, 98
6:11:30 PM, 10.40, 6463, 8.10, 1494, 98
6:11:30 PM, 10.40, 6454, 8.20, 1496, 98
6:11:30 PM, 10.40, 6472, 8.20, 1496, 98
6:11:30 PM, 10.40, 6472, 8.20, 1498, 98
6:11:30 PM, 10.40, 6481, 8.20, 1498, 98
6:11:30 PM, 10.40, 6490, 8.20, 1498, 98
6:11:30 PM, 10.40, 6481, 8.20, 1500, 98
6:11:30 PM, 10.40, 6499, 8.20, 1500, 98
6:11:30 PM, 10.40, 6518, 8.20, 1500, 98
6:11:30 PM, 10.40, 6518, 8.10, 1500, 98
6:11:30 PM, 10.40, 6527, 8.10, 1500, 98
6:11:30 PM, 10.40, 6564, 8.20, 1500, 98
6:11:30 PM, 10.40, 6545, 8.20, 1500, 98
6:11:30 PM, 10.40, 6555, 8.20, 1503, 98
6:11:31 PM, 10.40, 6564, 8.20, 1496, 98
6:11:31 PM, 10.40, 6545, 8.20, 1496, 98
6:11:31 PM, 10.40, 6527, 8.20, 1498, 98
6:11:31 PM, 10.40, 6536, 8.20, 1498, 98
6:11:31 PM, 10.40, 6555, 8.20, 1496, 98
6:11:31 PM, 10.40, 6555, 8.20, 1498, 98
6:11:31 PM, 10.40, 6564, 8.20, 1498, 98
6:11:31 PM, 10.40, 6573, 8.20, 1498, 98
6:11:31 PM, 10.40, 6583, 8.20, 1500, 98
6:11:31 PM, 10.40, 6583, 8.20, 1503, 98
6:11:31 PM, 10.40, 6611, 8.20, 1505, 98
6:11:31 PM, 10.40, 6621, 8.20, 1500, 97
6:11:31 PM, 10.40, 6621, 8.20, 1505, 95
6:11:31 PM, 10.40, 6536, 8.20, 1509, 95
6:11:31 PM, 10.40, 6347, 8.10, 1518, 97
6:11:31 PM, 10.40, 6202, 7.80, 1500, 97
6:11:31 PM, 10.30, 6330, 7.80, 1505, 91
6:11:31 PM, 10.10, 6698, 8.10, 1516, 75
6:11:31 PM, 10.20, 6971, 8.00, 1516, 54
6:11:31 PM, 10.50, 7046, 7.30, 1530, 41
6:11:31 PM, 11.00, 6929, 6.40, 1518, 34
6:11:31 PM, 11.40, 6857, 5.40, 1498, 24
6:11:31 PM, 11.60, 6767, 4.10, 1483, 13
6:11:31 PM, 12.10, 6518, 2.40, 1469, 6
6:11:31 PM, 12.80, 6649, 0.80, 1458, 5
6:11:31 PM, 13.80, 6573, -0.80, 1447, 5
6:11:31 PM, 15.50, 6499, -4.30, 1438, 5
6:11:31 PM, 20.00, 6427, -7.20, 1431, 4
in the above post, i was gonna show the whole gear, but you can only post 10000 in one post, and it was 22000, so i narrowed it down from about 6000 rpms up to redline. the boost holds from 8.1 to 8.1 at 6800.
I think alot of these problems have to do with the inherit nature of the beast. Its a GT35 which was never meant to be internally gated. There is no wastegate priority in the housing and the turbine is large enough to always be the lowest pressure differential.
here are some pics of the datalogs. the first 2 are of the text file i posted earlier, the 3rd is a 4 gear pull, and the last is showing where i start building boost, its somewhere around 2300 iirc. look at that flat line!
Tochigi_236
Sep 27, 2015 03:40 PM
