Turbonetics Larger Turbine A/R ?
Old Nov 15, 2006 | 12:48 PM
JETPILOT's Avatar
JETPILOT
Default Turbonetics Larger Turbine A/R ?
Is there a larger A/R turbine housing with a T3 flange and 4 bolt exhaust that will bolt up in the stage 1 kit available? I think the stock one is a .77? Is there something bigger that can bolt up?
JET
Old Nov 15, 2006 | 01:21 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
There are none in the same config in the Turbonetics catalog. The turbine housing used on the Stage 1 kit is rather unique.
Old Nov 15, 2006 | 01:31 PM
JETPILOT's Avatar
JETPILOT
Why am I not suprised....
Is it because of the oversized T3 turbine?
JET
Old Nov 15, 2006 | 01:41 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
No not exactly. They do make several turbine housings for the Stage V turbine wheel. This particular housing is unique in its internal design and outlet configuration. This would be the CLOSEST to what you need except it has a vband discharge: 20692-5 Turb Hsg,0.81,Stg 5,Tund,Vb. That is a Stage V turbine housing .81 A/R Tangential Undivided Vband. There is also a 20696-5 Turb Hsg,0.84,Stg 5,Tdiv,Vb which is a Stage V turbine housing .84 A/R Tangential Divided V band discharge. Both of them would require you replace the 4 bolt flange with a Vband setup and then they still might not fit. Only because I am unsure if the Kolkelen turbine housing used on the Stage 1 system has EXACTLY the same dimensions as the non-Kolkelen.
Old Nov 15, 2006 | 02:10 PM
JETPILOT's Avatar
JETPILOT
What is a Kolkelen housing? What distinguishes this housing? Would a housing in the 1.0 A/R range be too big?
JET
Old Nov 15, 2006 | 02:17 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
It is a specific turbine housing design. The exact details of which I don't personally know. If you look at the box the turbo came in thought you should see the tag and the Kolke after .77 A/R. I don't know what specifically is different about the inside of the housing unfortunately...As for A/R I have no idea if a 1.0 is too big. The only way to know that for sure is to get a few different A/R housings and try them one at a time on the dyno.
Old Nov 15, 2006 | 02:36 PM
JETPILOT's Avatar
JETPILOT
The downpipe is 2.25" or 2.5"?
JET
Old Nov 15, 2006 | 02:48 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
i'm fairly certain the downpipe is never smaller than 2.75"
Old Nov 15, 2006 | 03:36 PM
JETPILOT's Avatar
JETPILOT
I just measured the inner diameter of the downpipe and it is 2.5"
JET
Old Nov 15, 2006 | 03:37 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
OK then I was wrong. Sorry.
Old Nov 15, 2006 | 03:38 PM
JETPILOT's Avatar
JETPILOT
I guess I could cut the 4 bolt flange off and go with one of these welded on.
http://www.atpturbo.com/Merchant2/me...egory_Code=FLS
JET
Old Nov 15, 2006 | 03:46 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
Yes I suppose you could. Make sure its Stainless. The Turbonetics one is part number 30230
Old Nov 15, 2006 | 03:49 PM
JETPILOT's Avatar
JETPILOT
Are there any plans for Turbonetics to create a 3" downpipe possibly in stage 2?
JET
MIAPLAYA's Avatar
MIAPLAYA
JET
Don't know yet...
Old Nov 15, 2006 | 03:53 PM
rocks's Avatar
rocks
3.5 inch down pipe with a 1.0a/r would be good. You would make power too redline then. No wonder it peters out, 2.5 inch pipe is bad.
JETPILOT's Avatar
JETPILOT
Yeah I figured!
JET
Old Nov 15, 2006 | 03:56 PM
rocks's Avatar
rocks
Is it possible to fit a 3.5 inch pipe in the area where the downpipe is?
Old Nov 15, 2006 | 03:57 PM
JETPILOT's Avatar
JETPILOT
3.5" will never fit in there.... I dont think a 3" will even fit in there. I'm going to have to dump the exhaust through the fender like my Grand National.
JET
Old Nov 15, 2006 | 03:59 PM
taurran's Avatar
taurran
JET
Someone has a very skewed opinion of distance. Jet, just make sure you aren't selling yourself short in "other areas".
Rocks, I've been considering a downpipe modification for a while now, since I had headers in the car. If you routed the downpipe higher, over the top of the headers, and then down to the midpipe you could probably squeeze a larger pipe in there, and also clear aftermarket headers. I'm actually surprised they routed the pipe where it is and was kind of hoping it would be changed for stage 2.
Old Nov 15, 2006 | 04:00 PM
taurran's Avatar
taurran
Does anyone have photo proof that it's 2.5"? I'd like to measure one out of the car myself. From what I remember it may have been a HAIR under 3"...
