Stilen belt and pulley install? How?
Old Nov 19, 2006 | 02:30 PM
BlackSpec02's Avatar
BlackSpec02
Default Stilen belt and pulley install? How?
So I am out in the garage and I am attempting to replace my supercharger 6-rib drive belt, the 4 rib blower belt and the stage 2 to stage 3 pulley and here are the problems I am running into...
I've loosened the tensioner on the 4 rib belt all the way down, but I still cannot get the belt loose enough to get off.... it doesnt appear there is a way to loosen it any further... how do I get that belt off and the new one on.... (this is the K040220 belt, 4rib 22 inch)
Second... Ive got the 6 rib belt off and can get the new one on just fine, but I can't get the stage 2 pulley to loosen without spinning... any special way to hold it down?
Any info is appreciated!! Thanks!!
should I just take it to a shop?
EDIT: Im an idiot apparently.... for the a-holes out there... you know I meant STILLEN and not stilen
Old Nov 19, 2006 | 09:18 PM
BlackSpec02
looks like i'll be dropping her off at the shop. damn.
Old Nov 20, 2006 | 09:28 PM
PANCHOVILLA's Avatar
PANCHOVILLA
Its simple there's a nut in the back of the pulley you have to hold with a wrench and use another wrench to turn it in the opposite directiom (righty tighty,lefty loosey)for the 4 rib its called rolling the belt,you heve to stretch the belt over the pulley and with the proper wrench turn the blower it should come off.this is how i do mine. good luck
Old Nov 20, 2006 | 09:39 PM
BlackSpec02
Ooookay! Very cool, I will check that out. Thank yOU!
Fixxxercask
Nov 9, 2015 11:10 AM
