the downfalls of the Z?
Old Dec 1, 2006 | 08:56 PM
newjerzrep's Avatar
newjerzrep
Default the downfalls of the Z?
ok i want to boost my Z and all that good stuff, but i wanted to know first whatts the downfalls of the car? like the rsx has weak trannys and there nothing i can really do about that..
so a acouple ?
whats a good hp for the stock block
hows the tranny?
if i do decide to do a full engine rebuild can the trannys take it?
and whats the biggest problem ppl have on these cars when they turbo them?
another i read about it but whats the best engine management?
thanks in advance
Old Dec 1, 2006 | 09:05 PM
drivenCSZ's Avatar
drivenCSZ
go give MRC $10k and the keys to your car....and you'll be just fine.
Old Dec 1, 2006 | 09:14 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
+1
yeps, MRC does quality work. VRT too!
Old Dec 1, 2006 | 09:18 PM
z33boi's Avatar
z33boi
the stock block can handle a good 400-450 imo but there are quite a bit that push it to 500hp ... depending on how hard you drive it and how much power you have, the tranny holds pretty well...some of the problems going turbo is the head lifts i think. which can be resolve with a better HG and L19 head studs or you can go with the 1/2'' studs...hks seems to be a very good ems if you want standalone but if you want a piggyback, i would say most people use the UTEC
Old Dec 1, 2006 | 09:22 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
search
Old Dec 1, 2006 | 09:48 PM
plumpzz's Avatar
plumpzz
you want the same speed as ur rsx give 20k to MRC and they'll hook you up :-D
Twin turbo, built motor, fuel system, computer wheels and tires.
Biggest downfall is usually the driver.
Old Dec 1, 2006 | 11:51 PM
JETPILOT's Avatar
JETPILOT
Technically the UTEC is not a piggyback, it's a paralell ecu.
JET
Old Dec 2, 2006 | 12:09 AM
sugarspunZ's Avatar
sugarspunZ
100% on how you drive. a mis-shift killed my motor with 375whp. if you like to beat the **** out of your car like i do then for sure build your motor.
and i dont get why everyone is so utec happy. imo if you want to do it right then get an FCON.
Old Dec 2, 2006 | 12:17 AM
newjerzrep's Avatar
newjerzrep
how are the tranny if i shoot for like 600 to 700whp? im not sure if im going to make this another project car or a daily driver
and what management will give you the most control over the car?
Old Dec 2, 2006 | 12:44 AM
sugarspunZ's Avatar
sugarspunZ
not sure about the tranny. however for management i would go with an HKS FCON VPRO.
Old Dec 2, 2006 | 06:02 AM
rocks's Avatar
rocks
utec because you can tune it, fcon only hks dealer can tune it.
Old Dec 2, 2006 | 06:50 AM
Zivman's Avatar
Zivman
utec is decent, but in resolution alone, the Fcon is clearly the better choice. I know some won't even consider an EMS you can't tune yourself. I just think 99.99999999% of owners lack the skills and shouldn't be messing with their EMS or tune.
<500 whp is doable with a resonable amount of money
>500 whp is doable with a lot of money
600-700+ whp is doable with an INSANE amount of money. at 600+whp and depending on your driving habbits, it would be wise to put aside money for routine tranny replacements
Old Dec 2, 2006 | 06:56 AM
rocks's Avatar
rocks
Well there is also the AEM but is more expensive than the utec. I could not have a ems i could not tune myself because i do to many diffrent things to my car.
Old Dec 2, 2006 | 07:03 AM
redman333's Avatar
redman333
GTMotorsports has gearsets you could put in the tranny if you go to the 600whp area. Alberto just blew his 3rd gear out on the track at 554whp. Also around that whp you'll be looking at replacing the axles.
I agree with sugarspunZ that if you drive hard than you'll want a built motor. I had to learn twice, and now I'm going with a built motor. I wasn't looking for more than 400whp but I drive my car car very hard, so I need it built.
Old Dec 2, 2006 | 10:43 AM
newjerzrep's Avatar
newjerzrep
hmm not sure what im going to do with this car yet, but i will know in the next couple days if im going to use this as a daily driver or go by another one and make this thing a beast, and yes i know how much $$ it would take to get 600hp or more, about the same or a lil more then i spent on my rsx, money isnt an issue at all
Old Dec 2, 2006 | 01:34 PM
MoodDude's Avatar
MoodDude
After being boosted now for 2 years on a stock motor (440rwhp) and login amost 5000 track miles (and 25,000 street miles) on it where I am beating the sh*t out of the car, the weak point is:
The LSD! Why oh why did Nissan have to supply a VLSD instead of a gear type? Probably since it was cheaper? Oh well, I actually didn't find the limit until I went with 305 R-Compound in the rear, if you drive it on the street - you will be just fine with the stock LSD since your tires will slip before it gives up.
Old Dec 2, 2006 | 02:13 PM
sugarspunZ's Avatar
sugarspunZ
what type of LSD did you end up going with? quaife?
Old Dec 2, 2006 | 04:59 PM
MoodDude's Avatar
MoodDude
Well - I haven't replaced the VLSD yet - but after next weekend (my season ender at VIR) I will be installing the Quaife.
07zee
Jun 22, 2015 09:17 PM
HardHitter
Nov 26, 2005 08:14 AM
