turbonetics vacum setup
Old Dec 4, 2006 | 02:50 PM
Eazzy's Avatar
Eazzy
Asked earlier---But ??---- Is this a new kit ? And what u running for vacuum at the plenum port?
Old Dec 4, 2006 | 02:51 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by q8pianist
MIAPLAYA i chekd everything the vuc setup was correct but still NOOO BOOOST we allso do some thing.
we tryed to over boost the car, but its only showing 0.5 bar !! that means with overboosting its giving 7.4 psi only !!! what dos that mean ???
after that we did the vuc again like u said and it was showing 5 psi again !!
damn ?? what to do know after all this.
i chekd the plenum (upper, lower, mid, its not leaking. and just to make sure i changed all the plenum gasket. and still the same it is
I would triple check every coupler. The one on the compressor outlet can come loose sometimes. A while back my car started only making 3 PSI of boost and I put the car in the air and found that when I had removed my front bumper to replace my head lamps I somehow whacked the charge piping going to the intercooler inlet enough to get the coupler to come loose. the next time I pressurized it it came completely off. I sincerely think its just a massive boost leak somewhere. Whats your vacuum reading at idle?
Old Dec 4, 2006 | 03:43 PM
q8pianist's Avatar
q8pianist
MIAPALAY
my vacum readings is 18 allways, befor i dont know cuz this car is not for me its for a guy and im working on it for him.
but what i know, the vacum readings has to be 20 to 22 ?? is that correct ?
Old Dec 4, 2006 | 03:50 PM
Eazzy's Avatar
Eazzy
MIAPALAY
20 or so at sea level, less as u elevate---18 is good
Old Dec 4, 2006 | 03:52 PM
MIAPLAYA's Avatar
MIAPLAYA
Eh, if you have an electronic map sensor and a half way decent gauge it should be auto calibrating on start up. You should be at 20 in/hg. Any less and theres a leak somewhere. You could pressurize the intake tract to find the leak.
Old Dec 4, 2006 | 03:53 PM
q8pianist's Avatar
q8pianist
hmmm u know this reading is from the vacum in the plenum. but what about the turbo ??? i think its leaking some where befor the throttelbody.
its not easy too find what shuld i try now ?
Old Dec 4, 2006 | 03:54 PM
MIAPLAYA's Avatar
MIAPLAYA
See above post...
Old Dec 4, 2006 | 10:59 PM
q8pianist's Avatar
q8pianist
hey guys, i chekd the gauge in the car and the reading is in Kilopascal
and its showing me ate idle 0.6-0.7 and this readings is les than 0.0 bar
its a defi gauge.
all that time i do not know its reading in bar :P sorry
but still i have the same problem
ill open the bumper and chek the pips.
i dont know why i have a bad feeling about the turbo !!
Old Dec 5, 2006 | 05:04 AM
QuadCam's Avatar
QuadCam
[QUOTE=q8pianist]hey guys, i chekd the gauge in the car and the reading is in Kilopascal
its a defi gauge.
[\QUOTE]
do you mean 6-7, or do ou mean .6-.7? .6-.7 is almost 0 vaccum!! even if it is 6-7, that is only about 2"Hg of vaccum! bad either way.
you should be able to hear that kind of leak.
also, that's a leak somewhere in the engine, not in the turbo piping. You need to be looking between the throttle body and the block.
Old Dec 5, 2006 | 12:25 PM
TurboKits.com's Avatar
TurboKits.com
The best to way quickly check for a boost leak is to hook up 2 boost gauges. 1 to the intake to monitor how much boost the engine is seeing and 1 between the turbocharger and wastegate too monitor how much boost is actually being produced...
If both boost gauges match, then no leak...
Jesse
MIAPALAY
Old Dec 5, 2006 | 12:33 PM
Eazzy's Avatar
Eazzy
Jesse
Is a set of vacuum/pressure gages accurate enough for this test ? Or maybe a good set of --say---0-20 PSI Glyserin filled pressure gages ?
Old Dec 5, 2006 | 12:45 PM
q8pianist's Avatar
q8pianist
QuadCam
yes its .6- kilopascal and some times its showing .7- those readings are befor the boost line. thats in idle
Old Dec 6, 2006 | 11:49 AM
LODOSS's Avatar
LODOSS
I just check my BOV and the top port is plugged up.. bottom port is open on my BOV with nothing on it not even a fitting. i put my finger over it and i can feel the vaccum.. i am guessing this would cause a pretty big boost leak? well anyways i looked at the instructions and understand that there should be a fitting from that port going into the turbo somewhere.. can anyone point it out in a picture? is it at the bottom fo the turbo when the kit is installed? the only thing i see from the top is just an oil line.
Old Dec 6, 2006 | 11:52 AM
MIAPLAYA's Avatar
MIAPLAYA
the lower BOV port is supposed to be open and no its not a boost leak. The compressor has a fitting on the outlet which is hard to see with the kit installed going to the lower wastgate port.
Old Dec 6, 2006 | 12:16 PM
LODOSS's Avatar
LODOSS
hm.. so feeling vaccum on the lower BOV is fine? once the car builds boost does it automatically shut that opening?
also would'nt a vaccum leak there cause the ECU to have a hard time getting a stable idle?
Old Dec 6, 2006 | 02:30 PM
LODOSS's Avatar
LODOSS
anyone???
Old Dec 6, 2006 | 03:13 PM
QuadCam's Avatar
QuadCam
that's not a vaccum leak. the BOV is located before the MAF. any air sucked in through the BOV gets metered at the MAF.
vaccum leaks occur after the throttle body.
Old Dec 6, 2006 | 03:48 PM
  #38
LODOSS's Avatar
LODOSS
your absolutely right.. what about under boost. does it shut it close?
Old Dec 6, 2006 | 04:16 PM
  #39
MIAPLAYA's Avatar
MIAPLAYA
Yes it does...
350Z_Al
Oct 29, 2020 07:44 PM
