manual boost controller
Old Dec 4, 2006 | 07:46 PM
kostat26's Avatar
kostat26
Default manual boost controller
does anyone know if i can run a manual boost controller with my aps st or a solution to my problem cause i broke the tip of the comp...
Old Dec 4, 2006 | 07:52 PM
Nismo350ZRT's Avatar
Nismo350ZRT
I'm using a Greddy manual boost controller with the APS TT. It should work on the ST too.
Old Dec 5, 2006 | 07:42 AM
Zivman's Avatar
Zivman
I maybe be completely wrong here, but that is more than just a boost control issue. I am thinking that is also the map sensor allowing the unichip to see boost and used for tuning.
Old Dec 5, 2006 | 09:53 AM
kostat26's Avatar
kostat26
yup
Old Dec 5, 2006 | 10:44 AM
JoeDirtPharmD's Avatar
JoeDirtPharmD
Hmmm- makes me wonder something then: I now use the Blitz EBC, and essentially removed APS' BC, thus the plug going to said BC is just, um... laying there. Potential problem?
Old Dec 5, 2006 | 10:54 AM
Zivman's Avatar
Zivman
I don't know if it is a problem, but do you still have a vacuum line running to your FPR? If so, I would assume you still have a vacuum line running to the module.
Old Dec 5, 2006 | 11:03 AM
tig488's Avatar
tig488
that nipple shouldnt be used for anything other than boost reference to the boost control solenoid, you T off and then go to the fpr. if hes gonna buy an ebc, he doesnt need it, just send a line to the fpr. no biggie.
i did the same thing JoeDirt, it isnt a problem, do you still have the line going to the nipple, if you do it doesnt matter.
Old Dec 5, 2006 | 11:05 AM
Nismo350ZRT
I have the plug just laying in the engine bay too. The Unichip still gets MAP from the T-fitting on the manifold. Not sure why you think the disconnected solenoid plug would be a problem.
Old Dec 5, 2006 | 11:58 AM
Zivman's Avatar
Zivman
Where is this T-fitting running to? I don't have the unichip on anymore, but IIRC it runs through the firewall to that module and T's off again to run to the FPR.
Old Dec 5, 2006 | 06:35 PM
Nismo350ZRT
One line is running to the blowoff valve and the other line runs thru the firewall like you stated and T's off to the Unichip and FPR.
Old Dec 6, 2006 | 08:09 AM
Zivman's Avatar
Zivman
So you are still running a vacuum line to this module which I would think allows the unichip to see boost.
Old Dec 6, 2006 | 09:36 AM
Nismo350ZRT
Yep.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
