white smoke vid inside...?
Old Dec 7, 2006 | 12:04 PM
kostat26's Avatar
kostat26
Default white smoke vid inside...?
i jsut started my car today for first time everything looks fine but after 10 minutes of driving the car it starts smoking really bad??? i called japtrix and they said its normal but it definetely doesnt look normal i dont like it at all. anyone know what i could do to stop it?? oir if anything is wrong
http://s22.photobucket.com/albums/b3...=103006082.flv
kostat26's Avatar
kostat26
first link is vid
Old Dec 7, 2006 | 12:10 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
Well I will state the obvious from my non mechanical background. It looks like you are burning something and it definitely isn't normal.
Old Dec 7, 2006 | 12:12 PM
SargentZ's Avatar
SargentZ
looks like you're burnin oil (smell?)or somebody put sonmething in your tail pipes. any enemies? **** anybody off lately?
Old Dec 7, 2006 | 12:14 PM
z33boi's Avatar
z33boi
maybe its oil..nice car btw
Old Dec 7, 2006 | 12:16 PM
chimmike's Avatar
chimmike
without looking at the vid, does the smoke linger? or does it dissipate/evaporate?
Is there new exhaust? How many miles since the kit was put on?
Old Dec 7, 2006 | 12:20 PM
kostat26's Avatar
kostat26
it lingers. and its stock exhaust. i drove the car for prolly like 10 miles since i put the kit, but kit is used...i called japtrix the said its normal but im definetely not driving my car around with that much smoke coming out
Old Dec 7, 2006 | 12:21 PM
glowz825's Avatar
glowz825
Looks like youre burning oil. Might be a valve seal.
Peking's Avatar
Peking
without looking at the vid, does the smoke linger? or does it dissipate/evaporate?Is there new exhaust? How many miles since the kit was put on?
Mine smokes alot when cold outside (white smoke along with I always let the car get warm before driving), but goes away after 30 mins of driving.
Actually it can smoke too when some what being cold out, though not as much and also goes away.
I don't or won't consider it to be a issue until it is smoking all the time, having no cats and running boost I have always been aware or extra smoke from time to time.
So you drove for 10 mins, do you let your car warm up before you drive? What is the temps outside? Does it always smoke? Or does it eventually go away? Does it spit anything out of the tail pipes at idle? Is there build up or oil in the pipes?
-Jonathan-
Old Dec 7, 2006 | 12:26 PM
kostat26's Avatar
kostat26
it smokes about after 5 10 minutes of drving im florida and its pretty hot here... and i had the car running for about 8 minutes then i took vid and also i think i put too much oil in i drained it out and put 4 quarts only too make sure i didnt put too much. i cant really read the dip stick synthetic is hard to see...
Old Dec 7, 2006 | 12:29 PM
kostat26's Avatar
kostat26
idk its pretty bad i have everyone staring at me i had my friend come over to see if my car is fine cause he had his friend calling him telling him it looked like i blew my motor...my engine and boost is running perfect but smoke definetely needs to go away..
Old Dec 7, 2006 | 12:31 PM
Peking's Avatar
Peking
No kidding, the dipstick sucks monkey ***** on telling the level... I used to check it from the dipstick from which is seemed fine... But when changing my oil I found from putting 6 qts. in I was getting only like 5 qts. back out
Also I wasn't thinking you had too much oil, just that if the turbo oil seal was ruined it would be spitting/accumulating some oil in the exhaust.
Huh? You only put 4 quarts of oil? Doesn't stock require 5? I use 6 because I have a oil pan spacer.
Oh and I def. wouldn't be putting less oil in my car.
Old Dec 7, 2006 | 12:32 PM
chimmike's Avatar
chimmike
whoever said valve seal,,,,,no.
sounds like the turbo oil seal is gone.
also, you don't want to run too little oil.
run a MINIMUM of 5 quarts! if you have a spacer, 6!
too much oil won't affect the turbo like that. And I don't think you'd be spitting it out the exhaust either.
Old Dec 7, 2006 | 12:35 PM
Peking's Avatar
Peking
I wouldn't be listening to that friend
If the engine and boost are running fine your motor is not "blown".
kostat26's Avatar
kostat26
i didnt have cup to measure b ut i put around 5 quarts i have spacer in and aps site says 5 so it should be 5 dipstick doesnt show anything its pointless pulling it out. i told japtrix turbo seal they said no thats not it...maybe cause turbo hasnt been run in like 4 months? it taked time to recirculate?
Old Dec 7, 2006 | 12:40 PM
kostat26's Avatar
kostat26
no i said his friend saw me driving with smoke everywhere and called him and he showed up at my house cause his friend said my engine is blown
Old Dec 7, 2006 | 01:01 PM
tig488's Avatar
tig488
100% your sump isnt working, the oil is flooding the turbo causing it to spill over into the exhaust. check the sump pump connections.
now your gonna have to drop the downpipe and exhaust and clean it all out as best you can.
Old Dec 7, 2006 | 01:03 PM
westpak's Avatar
westpak
SFZCC
We have had to fix some self installs and one thing that has been common in them is the installation and wiring of the oil pump, check that to make sure it is correct and also make sure the connections are good and cannot come undone.
Being a used kit you run the danger of having a bad turbo seal, also which check valve do you have? The later selonoid? or old version check valve?
Old Dec 7, 2006 | 01:15 PM
tig488's Avatar
tig488
used kit, 06 Z, wiring may be different, oil solenoid i believe.
Old Dec 7, 2006 | 02:18 PM
kostat26's Avatar
kostat26
i have new check valve and i think too much oil is getting in to i wired into the black wire yellow trace
