JWT TT BB530 vs BB700
Old Dec 19, 2006 | 05:10 PM
Cannysage's Avatar
Cannysage
Default JWT TT BB530 vs BB700
any major difference between the two besides one being able to hold more power? more lag?
Old Dec 19, 2006 | 05:38 PM
MIAPLAYA's Avatar
MIAPLAYA
Technically the 700 doesn't "hold" more power. The compressor wheel is capable of flowing more air therefore making more horsepower to the wheels.
Old Dec 19, 2006 | 05:43 PM
WA2GOOD's Avatar
WA2GOOD
Originally Posted by Cannysage
more lag?
Surprising enough,The 700BB turbos only have about 300 rpm more lag than the ultra fast spooling 530BB's ( I was skocked myself, cause turbo lag = )
Old Dec 19, 2006 | 05:54 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
It all depends on your HP goals. I'm told the 530's are maxed out at about 14 PSI. However, to even come close to 14 PSI, you have to build your motor. The stock motor (non-built) is probably good to about 9 PSI, so if you are neve going to build it, you should go with the 530's, as while the 700's spool very fast, they are just a bit slower than the 530's (as WA2GOOD states)
Me, I'm more than happy on my stock motor with the 530's at 6 PSI. I will probably at some point get bigger injectors, an AAM fuel return system, and a boost controller and go to 8 or 9 PSI, but I have no plans to build the motor, and will stop there.
My JWT TT G is great for daily driving with the 530's; they spool instantly, and give me more than enough power to pass whoever I want to. Other than that, I could never see myself driving a 20 PSI boosted turbo monster that can spin the tires at the tap of the throttle.
Old Dec 19, 2006 | 05:58 PM
WA2GOOD's Avatar
WA2GOOD
Very well put.....+1 Couldn't have said it better myself.
Old Dec 19, 2006 | 06:14 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
DAVE90-TT Humm? You say that now. I know I did when I had 9psi, I am up to 12psi on stock block and track it every weekend. Building very very soon.
Old Dec 19, 2006 | 06:27 PM
Cannysage's Avatar
Cannysage
wow, great input guys. If there aren't any downsides to the 700, I prolly go with that. I'm definitely rebuilding and don't want to have any 'what ifs' later. can you even notice a 300rpm lag? That sounds pretty minor..
Old Dec 19, 2006 | 06:36 PM
WA2GOOD's Avatar
WA2GOOD
It is very minor, I was impressed at how well, and how long the 700's pull for compared to the 530's, and I was a big fan of the 530's. I thought the 700's would be so laggy and overwhelming, but they are great and worth the extra cost. built motor is a must though....
masterj26's Avatar
masterj26
what is the difference in price from the 530's and 700's?
Old Dec 19, 2006 | 06:37 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Well, the downside is the 300 rpm lag. Mostly not noticeable, but it is there.
You really need to decide on your ultimate goals before you start. If your goals are to eventually go to 18/20/30/500 PSI, then yes, go with the 700's, no doubt abut it. If you are sure your ultimate goals are to stay below 14 PSI, then go with the 530's, as long as you are sure.
I really am sure that my ultimate goals are below 14 PSI, which is one reason why I went with the 530's. You can get a very powerful car on the 530's. Check out Eagle1's G35 over on G35driver, he has the 530's (I think), and tracks his car on a regular basis and is very satisfied with the 530's. I think his whp is low 500's, but WA2GOOD would know better, as they are the ones who built his G.
But it is ultimately up to you, and by knowing the pros/cons of each, you can make a good decision.
WA2GOOD's Avatar
WA2GOOD
about 2K + more miscelanious supporting mods
Old Dec 19, 2006 | 06:38 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Thats the other downside, the 2000 extra dollars...
Old Dec 20, 2006 | 04:53 PM
350Zzzz's Avatar
350Zzzz
Professional
I don't really feel the lag at all, as it as responsive as I could ever want my Z to be. I have not driven one with the 530s, but as a passenger I didn't feel any lag with either.
With the 700/s I feel that 6500 rpm is not sufficent to appreciate its full potential, as the darn thing wants to keep going.
It would seem that the 530s are well matched with a stock motor.
G
Old Dec 22, 2006 | 10:56 PM
Devil Z's Avatar
Devil Z
There is no Turbo lag with any of the kits maybe except APS Extreme.
Old Dec 26, 2006 | 12:10 PM
Cannysage's Avatar
Cannysage
Thumbs up
G
yeah, it'll be badass with the '07+ zs with 7500rpm!
B Esquire
Sep 24, 2015 07:52 AM
