Turbonetics single turbo
Old Dec 29, 2006 | 10:58 AM
freezeg35's Avatar
freezeg35
Originally Posted by lemansz20
I would be careful running the flash but w/e lol your funeral. Hope everything works out for ya.
Did you blow your motor because of the reflash? I thought it was safe on the stock boost with stock exhaust.
Old Jan 8, 2007 | 09:59 AM
3fiftyzva's Avatar
3fiftyzva
Default Service Engine Soon Light
Originally Posted by jlimquest
I have the Turbonetics w/ the reflashed ECU & have been very happy with the performance, looks & reliability. On top of that it comes a 1 year no fault warranty. With what ever kit you decide on just make sure that it is installed by a shop that specializes on that kit. Have seen many horror stories on bad installs.
Just had the Turbonetics ST installed. Looks perfect and boost is very nice. However the Service Engine Soon light keeps coming on. Read it and code mentions missfire and/or emissions? Anyone had this problem? Came on one time when I went to boost. Came back on when it was idlying for about 2 minutes. Once in awhile it will flash?
Thanks.
Old Jan 8, 2007 | 11:26 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Thanks.
worry about big things... this lil' SES thing is a known behaviour that you should not worry about it.
Old Jun 2, 2007 | 04:20 PM
michaelbrown13's Avatar
michaelbrown13
Default AAM Oil Pan Spacer?
I had my Turbonetics installed at Altered Atmosphere, purchasing their oil pan spacer, liking the idea of having that extra quart of oil and a nice clean (oil lines) installation. Well I am having the 4th new Turbonetics turbo unit installed as I'm typing this quote.
AAM tapped into the oil pan spacer, and JetPilot and others including Turbonetics are right when they say not to tap into the spacer, the lines come in to high and gravity can't do it's thing and help the oil return. You end up blowing the seals in the turbo and it starts burning oil and smoking.
Like I said 4 turbo units later, we're capping the oil pan taps and tapping into the oil pan as low as possible. Hopefully this will fix it once and for all.
Good luck on your setup.
Old Jun 2, 2007 | 04:24 PM
taurran's Avatar
taurran
Uhh.. you want to tap as HIGH as possible. At this point I think seal issues are more related to the line itself than the tap location. Still, I'll be leaving my upper pan tapped even on my built motor.
Old Jun 2, 2007 | 04:31 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
let me know if you are in the southeast and i can help you out with your TN install....
Old Jul 26, 2007 | 12:32 PM
Jeepsterja's Avatar
Jeepsterja
fst100
North East
Sep 8, 2015 11:37 AM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
