Boost gauge on a Stillen SC
Old Jun 26, 2006 | 04:28 PM
ROGUE23's Avatar
ROGUE23
Default Boost gauge on a Stillen SC
Hello everyone, I hope someone could help me with this.
I bought a Defi boost gauge and I don't know where to connect the T connector.
Picture will be great, and YES I already try to find it using the SEARCH..
Thank you in advance..
Old Jun 26, 2006 | 07:24 PM
samec's Avatar
samec
tee into the small line (1/8") that comes off the plenum. this is the pressure sensing line that goes to the fuel/timing box. any other line will not give you a boost reading.
Old Jun 26, 2006 | 08:38 PM
rookie's Avatar
rookie
Hope this helps.
PANCHOVILLA's Avatar
PANCHOVILLA
I suggest T-ing into the pressure sensing line coming off the EMU. The further away from the blower you are the more accurate the reading is.You can T into the line like 4" away from the EMU.This is the way STILLEN did mine.Reason being if you ever get belt slippage you know for sure,and you are consistant reading 6,7,8lbs of boost depending on what stage youre on.
Old Jun 28, 2006 | 05:04 AM
ROGUE23's Avatar
ROGUE23
Thank you all for the quick reply, will install this weekend.
Thanks again guys.
Old Jul 26, 2007 | 11:11 AM
hyperz's Avatar
hyperz
subscribing. Does anyone know what strut brace is in the pic?
Old Jul 26, 2007 | 12:11 PM
rookie's Avatar
rookie
The Stillen pictured above was on my FX so the STB is probably odd to the Z drivers.
Old Jul 26, 2007 | 12:37 PM
abyss's Avatar
abyss
Rookie! I lust for your FX.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
