** Aps Extreme Tt Kit Install **
Old Jan 7, 2007 | 08:08 PM
westpak's Avatar
westpak
SFZCC
Default ** Aps Extreme Tt Kit Install **
Sorry no big fonts and bells and whistles on this post just wanted to post info on an install of an APS Extreme TT kit along with a built block in forum member Gators2001's 350Z. Very nice kit, the intercooler is huge, for the engine management we went with a Utec.
Other mods previously installed or installed along with the kit and built block:
JWT Springs and C2 Cams
HKS Headgaskets
ARP L19 Head Studs
Samco Hoses
Nissan Rear Cooling Mod
KOYO Slim Radiator
JWT Flywheel
Clutchmaster FX400 CLutch
TurboXS Utec and Tuner Pro
Sertrab Oil Cooler
APS 3" Exhaust
AAM Plenum Spacer
The car was tuned for base boost of the wastgates which turned out to be 12 psi, we will tune for higher boost later. Results on our Mustang dyno were RWHP=476 and RWTQ=411, he took it to a Dynojet and got RWHP=507 and RWTQ=442. I am sure he has his hands full with that but will bring it back in for a higher psi tune.
Here are some pics of the process and also of the dynos:
Old Jan 7, 2007 | 08:18 PM
supra crazy's Avatar
supra crazy
Looks good.
Old Jan 7, 2007 | 08:24 PM
rookie's Avatar
rookie
Wow at the thickness of that intercooler.
Old Jan 7, 2007 | 08:25 PM
CraZ33Y's Avatar
CraZ33Y
good luck .....
Q? is this kit come with fuel system ..!!?!?
350z_2NR's Avatar
350z_2NR
nice check mine out http://www.streetsports.com/photo/ve...ps/default.htm
Old Jan 7, 2007 | 08:35 PM
westpak's Avatar
westpak
SFZCC
Originally Posted by CraZ33Y
good luck .....
Yes it comes with the APS Extreme Fuel system (Twin Pump, dual regulators, rails, injectors)
Originally Posted by 350z_2NR
Nice plug but that is not an Extreme Kit but rather a regular TT kit.
Old Jan 7, 2007 | 08:38 PM
tig488's Avatar
tig488
very nice, damn that IS a big IC.
looking forward to 800+whp results.
Old Jan 7, 2007 | 09:04 PM
clemlover15's Avatar
clemlover15
can u get the extreme kit without the fuel kit??
Old Jan 7, 2007 | 09:14 PM
Mike Wazowski's Avatar
Mike Wazowski
looks great
Old Jan 7, 2007 | 09:20 PM
Jun's Avatar
Jun
looks sweet!
Old Jan 8, 2007 | 03:33 AM
Gators2001's Avatar
Gators2001
This kit makes the car a beast! The installation went smooth. The Turbos have no lag at all.
Im really looking forward to increasing the boost and seeing what she does. At 12lbs, she is asking for more.
Big THANKS to Japtrixs and Gus (westpak) for the great work!
Yo JUN when you coming over for a ride?
Old Jan 8, 2007 | 04:19 AM
masterj26's Avatar
masterj26
Congratz Manny, can't wait for a ride
Old Jan 8, 2007 | 04:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Very nice TQ curve. Nice work guys. What was the Dynojet correcion factor used, and on what gas was this tuned on?
Old Jan 8, 2007 | 04:39 AM
savvy's Avatar
savvy
holy crap thats a massive intercooler
Old Jan 8, 2007 | 04:41 AM
phunk's Avatar
phunk
CJ Motorsports
good work! how much boost did it make that power at? (just curious if the turbos are really much larger at all).
looks like a very clean installation on a clean car.
alberto: I think that graph appears to be uncorrected. Even tho the top right corner of the graph where it says the correction and smoothing is cut off, on the vertical axis where it says "Power" and "Torque" it would typically say "SAE Power" or "STD Power" Etc.
Old Jan 8, 2007 | 05:13 AM
westpak's Avatar
westpak
SFZCC
No Dynojet correction, the 476/411 numbers were on our Mustang dyno and the 507/442 were on another shop's Dynojet.
It was tuned on 93 octane.
Thanks the tech prides himself on his clean installs.
The tune was on the base boost of the wastgates which turned out to be 12 psi.
Old Jan 8, 2007 | 05:17 AM
phunk's Avatar
phunk
CJ Motorsports
thanks, i look forward to you guys turning up the boost! I must admit that I am very curious if it will make any more power then the Greddy turbos do!
Old Jan 8, 2007 | 05:19 AM
captj3's Avatar
captj3
It looks great manny. I need a ride next time we meet. To everyone else the intercooler is even bigger in person.
Old Jan 8, 2007 | 05:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ok, so those Dynojet #'s were actual-what were the conditions for the run?
Old Jan 8, 2007 | 05:35 AM
captj3's Avatar
captj3
Alberto it was 84 degrees outside when he dynod.
