Allighment
I install camber arms on my car and i took it to get it alighned drove 30 miles there with no problem...they do the alighment and everythign i watched them stall it like 4 times they sais "its the satge 3 clutch" "we are not used to it" anyways it gets alighned. the guys goes out for test drive he comes back i pay and i seriously drove 30 feet and my car shuts off and my pedal is acting really weird...sometimes it will work sometimes no, sometimes it jsut revs by itslef so i drive back, and tell them this hasnt happened before my cars been running perfect and now as soon as i drive off after u touched it this happened. they said theres noting we can do about it we didnt touch anything. he checks the codes and its throwing off like 4 tps codes. idk what to do....
i knew i shouldnt have let them drive it
the day before i was also messing with the fuel assembly and the wire that was welded broke off so i tied it around the metal piece where it was. im thinking maybe that might have cause my car to go to safe mode
. i drove the car like 60 miles after i did that and it run fine...
Originally Posted by kevinapex
It might fix your car from blowing up!
Be careful man!
Be careful man!
all i know is i let some ****ed driver my car and stall it a bunch of times and then i drove not even 30 feet and it shuts off...
and now i need to figure out what is wrong
So APS runs a separate fuel line all the way to the tank instead of making use of the stock one?! Come on, inquiring minds want to know! And why is there that gap between your rubber o-ring and anythng else around it. You asked for help...were trying to help...just don't write off a vaild question...
You know what I'm saying, it's a Z thing!
