Turbonetics RWHP Numbers
Old Jan 16, 2007 | 04:32 AM
Laww's Avatar
Laww
Default Turbonetics RWHP Numbers
All,
I was wondering what numbers people have out there that they have gotten / are getting for their respective TN ST kits, and if you are getting those numbers from a built motor or stock.
Thanks in advance for your replies.
Laww
Old Jan 16, 2007 | 04:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
396 whp, 400ft/lbs Dynojet, 5th gear uncorrected. Stock motor with 9psi, Crawford plenum, JIC 3" Exhaust, UTEC, AAM RFS. IIRC SAE corrected #'s were 388whp, 39X ft/lbs. May not have been the most powerful, but I loved it Hows your car coming along?
Old Jan 16, 2007 | 04:41 AM
Laww's Avatar
Laww
Nice numbers bro! I am getting the final tune done on Friday, and since I am built now, I figured I'd try to dial in somewhere in the vicinity of 13-14 lbs boost and see if I can attain 450rwhp. Not sure if I am dreaming, but that is the goal....
If I can hit that target I think I will have the highest TN ST that I am aware of.
Laww
Old Jan 16, 2007 | 04:49 AM
bboypuertoroc's Avatar
bboypuertoroc
If you're built it shouldn't be a problem with the 60-1 you got. We (Evo's) make 500+ to the wheels with that turbo... don't see why you can't (and have the added benefit of hella quicker boost then us).
Old Jan 16, 2007 | 04:52 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Laww
Im positive you can hit 450whp on AAM's dynojet. Remind me, do you have cams? Most Ive seen out of a TN set-up is JETPILOT on Sharif's dyno (reads much lower than Dynojet) 14 or 15psi and he did in the 460's, could be 490ish on a DJ. Of course you know the TQ will fall off faster than you'd like but the car will be fast, Mike tuned my TN set-up very well. We def should meet up when its finally back on the road, I know its been a while for you.
Old Jan 16, 2007 | 04:54 AM
Alberto's Avatar
Alberto
Cranky FI Owner
The turbine/downpipe is a restriction in our applications. At or slightly after 14-15psi its nothing but hot air. Nobody has hit 500whp with a Stage 1 system yet-why do you think I sold mine Tony
Old Jan 16, 2007 | 05:06 AM
bboypuertoroc
Because 2 are better than one? Just a guess
What the hell is wrong with the downpipe? I can understand the turbine side, but it's a 3 incher, same that we run... what size wheels is the turbo running?
Old Jan 16, 2007 | 05:10 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I dont want to turn this post into a "whats wrong with Stage 1" but IIRC the turbine is a T3 not a T4 like maybe the Evo guys would run. Im sure if Im wrong somebody will quickly step in and correct me ie. MIA Also, there was some debate on the actual size of the DP, I remember a while ago somebody posting a pic of the internal diameter being smaller than 3". Bottom line is nobody has hit that 500whp mark, but you never know OP may be the first...Laww do you have cams/headwork? What compression?
Old Jan 16, 2007 | 05:14 AM
Laww's Avatar
Laww
That's all good stuff to hear, Alberto!! The mods I have are as follows:
Forged Engine built by GT Motorsports
UTEC
550 cc injectors
AAM Return Fuel System (Stage I)
HKS VI Boost Controller
AAM Plenum Spacer
UR Pulleys
AAM Reflash
Long time is right! 14 months to be exact ....and I counted every day of it!!
AAM Throttle Body spacer
Old Jan 16, 2007 | 05:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You will have one of the healthier TN set-ups. Good luck with it all, be sure to post results when you have them. You can finally join us at the crazy meets we have...
Laww's Avatar
Laww
Looking forward to it bro!
Old Jan 16, 2007 | 05:30 AM
bboypuertoroc
OK... I remember that **** now...
BTW, we use a T3 setup also.
The Mid-A crew is getting crazy man... sounds like a good setup bro.
Old Jan 16, 2007 | 05:53 AM
redman333's Avatar
redman333
Just read my sig for my current setup, I will be going with a built bottom soon.
Old Jan 16, 2007 | 07:18 AM
MIAPLAYA's Avatar
MIAPLAYA
The turbo on the Stage 1 kit is a 60-1 compressor with a Stage V T3 turbine. The Stage V turbine wheel actually has a larger exducer then a O trim T4 wheel but the major diameter is about .2" smaller. Essentially its the largest T3 turbine you can find. The housing is .77 A/R tangential Kolkelen. With cams I would expect to see some really good power all the way across the band. Unforutnately all the built motor Stage 1 kits weren't using any kind of cams..
Old Jan 16, 2007 | 07:33 AM
OutsiderZ5's Avatar
OutsiderZ5
Welcome back Laww. Wish I was still up North to see that beast of yours. Glad to see things are going well for your Z.
Old Jan 16, 2007 | 08:01 AM
Laww's Avatar
Laww
thanks bro! Sounds like a good excuse to take a road trip and come up to Alberto's and my neck of the woods.
Laww
Old Jan 16, 2007 | 08:48 AM
rocks's Avatar
rocks
The problem is the 2.5 inch down pipe on a 3.5L engine. The tn kit would have no problem if it had a 3-3.5" downpipe. It was made for midrange power. I am aiming for topend power.
Old Jan 16, 2007 | 12:50 PM
2slo2bfurious's Avatar
2slo2bfurious
When you guys say downpipe are you refering to the pipe that goes to the exhaust, or the jumble of pipes that come from the manifolds to the turbine?
Just wondering because it seems that the restriction would be worse on the merge pipes and not the downpipe.....
Old Jan 16, 2007 | 12:55 PM
bboypuertoroc
Downpipe is the pipe that starts from the turbine housing and goes out to the rest of the exhaust piping.
Thanks for the info MIA. That turbo *SHOULD* be capable of over 500... there should be a way to fab up a true 3 inch downpipe. I wonder how hard it would be to switch the hotside to one that would except a 3 inch dp (like what we use).
Old Jan 16, 2007 | 01:08 PM
rocks's Avatar
rocks
The down pipe is the pipe that comes off of the back of the turbo. If it were possible to fit a 3.5 inch downpipe on the turbonetics kit i would conisder buying one. I am just going to use full 3inch for around 450 or so hp for now. When i want more i will make me a 4 inch exhaust.
