Turbonetics RWHP Numbers
Old Jan 16, 2007 | 01:15 PM
taurran's Avatar
taurran
Look at a Turbonetics kit and you'd see that it is most likely possible to fit a 3" downpipe in there. You'd just have to route it up over the top of the exhaust manifolds.
As far as numbers, I made 412whp and 431 ftlbs at 9psi on the reflash. I'm waiting for turbonetics to release their EMS so I can tune, hopefully it might be sometime soon as even I'm getting a bit antsy.
Old Jan 16, 2007 | 01:31 PM
rocks's Avatar
rocks
Taurran the hydra ems will be out in febuary sometime. Thats what im going to use its a full standalone. I know the turbonetics kit will fit a revup with a steering rack change but does that disable the speed sensitive power steering?
Old Jan 16, 2007 | 05:10 PM
lemansz20's Avatar
lemansz20
IM getting my tune FINALLY next wednesday so see what we can get and itll be on a 4wd mustang dyno like sharifs I think that reads lower. I have all your mods except for the plenum, and Im gonna try and run a bigger front mount that I have. I HOPE lol I can get close to these high numbers that people have. I didnt know people were reaching almost 500 on the tn kits, so close yet so so far away lol.
Old Jan 16, 2007 | 08:48 PM
redline350ZZ's Avatar
redline350ZZ
I'm working my bugs out as well I need to get my UTEC installed but..
Arias 9.0-1, GTM Turbo cams, rods blah blah blah
Besides my TN ST soon to be on 12-14 psi as well. Someone mentioned a while back that the Evo wastegate would not be good enough for those boost lvl's..anyone chime in on that?
Old Jan 16, 2007 | 08:52 PM
MIAPLAYA's Avatar
MIAPLAYA
It should be ok to ~500 HP based on its flow rate.... I would start thinking up a larger gate though... A Racegate or Newgen maybe..
Old Jan 16, 2007 | 08:59 PM
D350Z10's Avatar
D350Z10
Originally Posted by Alberto
I dont want to turn this post into a "whats wrong with Stage 1" but IIRC the turbine is a T3 not a T4 like maybe the Evo guys would run. Im sure if Im wrong somebody will quickly step in and correct me ie. MIA Also, there was some debate on the actual size of the DP, I remember a while ago somebody posting a pic of the internal diameter being smaller than 3". Bottom line is nobody has hit that 500whp mark, but you never know OP may be the first...Laww do you have cams/headwork? What compression?
https://my350z.com/forum/forced-induction/205317-turbonetics-stage-2-5-results.html
Haha where were you when i posted this thread?
Note this was with a greddy evo 2 2.5 in, now i have a custom 3in all the way out with a apexi n1 muffler and gotta dyno/tune it but it moves faster i can tell you that much.
Old Jan 16, 2007 | 09:37 PM
Nealoc187's Avatar
Nealoc187
Originally Posted by MIAPLAYA
The Stage V turbine wheel actually has a larger exducer then a P trim T4 wheel but the major diameter is about .0001 smaller.
The P trim wheel has a larger inducer and larger exducer than the T3 Stage V wheel. The P trim has 64.6mm exducer and 74.2mm inducer. Stage V T3 wheel has a 61.9mm exducer and 71.0mm inducer.
Old Jan 16, 2007 | 10:13 PM
MIAPLAYA's Avatar
MIAPLAYA
My apologies I looked in the wrong field on my size sheet. What I posted is true for the T4 O trim wheel... I will edit my original post.
Old Jan 16, 2007 | 10:22 PM
redline350ZZ
I'm just trying to save cash until 2 arrives.
Old Jan 17, 2007 | 12:26 AM
JETPILOT's Avatar
JETPILOT
I think I have made the most power with the OE Turbonetics kit to date. 456whp, and 488 ft-lbs.
The only addition to the kit was Alphawerks headers. The peak power was at 5450 RPM. Well short of the OE powerband. The 2.5 inch downpipe is the killer as well as the turbine housing.
It doesn't make sense to wait for the stage II kit to be released. We already know the street price for the GTK-550 alone will be $1900 plus any additional piping they will have to fabricate. It won't be worth the added expense to make the switch to an upgraded single turbo setup.
It does make sense to get a Greddy TT setup and sell the TN kit. Greddy TT with intercooler is $5300. Sell the Turbonetics for $3000.
The Turbonetics set up is good for 380-410whp on an OE block. It makes financial sense then. But if you have a built motor then any single turbo kit is a waste of time as every aspect of a TT kit is better as long as price is not a factor.
I think Turbonetics has been talking about the release of a stage II kit for over a year now. It seems like it is always going to be released "soon". Meanwhile for a kit that is supposed to be released soon there aren't any answers to even the most basic of questions such as changes to pipping. If this thing were close to being put on the market they would have that info at worst case.
JET
Old Jan 17, 2007 | 02:50 AM
ILLBZNU's Avatar
ILLBZNU
Default my main problem
My main problem is that I have been planning on getting the 650, but it has T4 flange. What will be involved in making this fit, considering the Stage I kit is using the T3 flange. If this is doable I am not going to be waiting another few months for the stage II kit, when Ed at turbonetics said that they should be shipping the turbos this month.
Old Jan 17, 2007 | 04:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by D350Z10
https://my350z.com/forum/showthread.php?t=205317
You upgraded your turbo, that means your not a stage 1 like the OP. I said nobody with stage 1 has hit 500whp and I am correct.
Old Jan 17, 2007 | 06:04 AM
D350Z10's Avatar
D350Z10
O my bad yea good luck with the 60-1 the max you will get is 485 ish around there. I pushed that turbo to the limit and it wouldn't move.
Old Jan 17, 2007 | 06:20 AM
617G's Avatar
617G
Originally Posted by JETPILOT
It does make sense to get a Greddy TT setup and sell the TN kit. Greddy TT with intercooler is $5300. Sell the Turbonetics for $2000.
JET
Can you please pm me where you can get a greddy w/ ic for $5300.
Old Jan 17, 2007 | 07:28 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Id be surprised if you could put down 500+whp on a Dynojet. Dyno you went on reads higher...any track times from you yet? I remember reading a lot more from you but havent seen you on here in a while.
Old Jan 17, 2007 | 07:58 AM
D350Z10's Avatar
D350Z10
its winter here, car is stored, but have a set of bfg 305's on the back now and car is ready to go just need to sharpin up the tune a little bit.
Old Jan 17, 2007 | 09:46 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice-I will look forward to seeing track times from you.
Old Feb 27, 2007 | 03:45 AM
  #38
gcoupeturbo's Avatar
gcoupeturbo
Default motor going to get built by builtzmotors
another newbie here getting a built motor for the turbonetics kit... I blew my motor and am paying the price... ..besides proper tuning, a built motor, what else does it require to atleast make 450rwhp?
Old Feb 27, 2007 | 06:09 AM
  #39
MIAPLAYA's Avatar
MIAPLAYA
Cams would help...
Old Feb 27, 2007 | 06:46 AM
  #40
TENGAI's Avatar
TENGAI
Cams will help, but don't expect any miracles.
