any built aps st's out there?
Old Jan 23, 2007 | 05:44 PM
  #41
rocks's Avatar
rocks
If it were a gt3582r it would have no problem making that power but the compressor housing is aps custom made so the wheel isnt the same as whats in the ones on the cars making 600whp..
Old Jan 23, 2007 | 06:05 PM
  #42
Nealoc187's Avatar
Nealoc187
You sir, are incorrect...
JoeDirtPharmD on this board bought an off the shelf 3582R cartridge to replace his ruined one - it fit perfectly in the APS housings. It's a 3582R... Custom housings mean nothing when it comes to the wheels involved. the end.
https://my350z.com/forum/showthread....ighlight=3582r
Old Jan 23, 2007 | 06:24 PM
  #43
rocks's Avatar
rocks
Hm ok i was under the impression they were diffrent. I still wonder why there are no bigger power numbers from it then. Considering i was going to use a turbo of similar size or bigger than a gt35r82 in my single turbo setup. I do have a built engine though.
Old Jan 23, 2007 | 07:19 PM
  #44
azula's Avatar
azula
because no one has really tried....everyone that builds does it off of a platform that has more potential...(greddy tt, aps tt, etc.)
Old Jan 23, 2007 | 07:27 PM
  #45
wtf no turbo's Avatar
wtf no turbo
APS single turbo is too small to make that much power. Wedge a bigger turbo in there and you would be good for 550s+. I bet a masterpower t70 with a t3 inlet would fit in there.
Thats alot of wedging considering how tight the 35 is. I had a aps st with a built motor running around 16 to 17 psi close to 480 hp. Turbo starts to run out of its eff area when you hit the 18 to 20 range.
Old Jan 23, 2007 | 08:04 PM
  #46
RNB419's Avatar
RNB419
Sugarspun Please Please keep us posted. Ill be looking forward to your future write up. Whats the down time?
Old Jan 23, 2007 | 09:16 PM
  #47
sugarspunZ's Avatar
sugarspunZ
god, it has been in the shop for ever. the reason it is taking so long to totally due to money or lack of it. i bent a rod/s and i was not planning on building my motor this soon. i was forced to.
had i had the cash up front to do it GTM said about a month of down time.
Old Jan 24, 2007 | 05:03 AM
  #48
azula's Avatar
azula
did they give you a hypothesis on how you bent ur rods? what psi were you runnin?
Old Jan 24, 2007 | 06:18 AM
  #49
buzzardmountain's Avatar
buzzardmountain
Originally Posted by turismo
People are haveing issues with the extreme fuel system kit. This is why I decided to go with the cj motorsports fuel system.
Not to thread jack any more........but could you elaborate?
Thanks.
Old Jan 24, 2007 | 07:17 AM
  #50
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Excellent thread.. I just bought a short block to build it... My goal is 450~500WHP with APS ST.
wtf no turbo,
Did you upgrade your fuel system?
sugarspunZ,
Keep us posted...
Old Jan 24, 2007 | 08:15 AM
  #51
tig488's Avatar
tig488
he upgraded his whole setup, he went with the JWT TT,
when he had the aps, he was still using the fuel system that came with the kit, that was his problem, i think he was running out of fuel.
Old Jan 24, 2007 | 08:39 AM
  #52
azula's Avatar
azula
a have a couple numbers in my head, but could someone give me a break down on how much it would cost for this type of build....the shortblock, fuel system...etc.....?
Old Jan 24, 2007 | 08:59 AM
  #53
rocks's Avatar
rocks
I have a question do you get full boost in first gear with the APS single turbo?
Old Jan 24, 2007 | 09:02 AM
  #54
rocks's Avatar
rocks
Azula doing none of the work yourself your looking at around 20k$
Old Jan 24, 2007 | 09:06 AM
  #55
azula's Avatar
azula
wow
Old Jan 24, 2007 | 09:44 AM
  #56
TENGAI's Avatar
TENGAI
Yep, if you sat back and watched a shop do everything for you, it'd come close to that. Considering proper fuel system, ems, aps external wg, etc, etc, etc. Given the number of individuals that have installed this kit on the boards, you could probably manage it yourself if you're inclined (to include the fuels sys, ems, etc).
I would however, strongly recommend that you go to a good shop to get it tuned. One preferrably that has experience with the ems and aps kits.
I think the debate as to whether or not it'll hit 500+ rwhp has been addressed. It just takes someone with the desire to push that setup to it potential before we see it on these forums.
Keep in mind that if you really wanted more power, you could always augment the kit with a nitrous setup as well. Although many people seem to be leary about mixing power adders (i.e boost + NOS) in regards to these cars, it's been done countless times on other platforms...
Old Jan 24, 2007 | 01:25 PM
  #57
wtf no turbo
Yep your right, but even with fuel 8.5 to 1 comp ratio I can not see more then 480 to 500 with the stock aps st. May squeek some more on a 9 to 1 and hit 520 or so. Still miss hearing the big single spool.
Old Jan 24, 2007 | 01:30 PM
  #58
azula's Avatar
azula
450-75hp would be fine for me, but i'm not sure if that's worth 20k!!!!
Old Jan 24, 2007 | 01:53 PM
  #59
GTM's Avatar
GTM
Vendor - Former Vendor
It's all worth it at the end, when you are cruising down the highway with 550BHP, it feels awesome. So people (myself included) have spent a bit over 20k and still have no regrets
Just my PERSONAL opinion
-George
Old Jan 24, 2007 | 01:55 PM
  #60
NA&CH's Avatar
NA&CH
I am looking at the APS ST kit myself. I don't see it going much higher than 20k. A shortblock build shouldn't get that high. Hell I might be wrong. This drug is expensive Thats why not everyone is using it
Azula how do you like the ST kit?? you can pm me if you dont want to flood the thread. Thanks
