Pics of my APS TT
MODS:
APS TT kit
APS Strut bar
APS Tall Boy
APS 3" race exhaust with 3.5" downpipes
Utec computer => changed by latest Unichip
utec map sensor
Nismo oil cover kit
Carbon fiber intercooler plate
Nismo shift **** titanium
Oil cooler
Defi meters (Oil temp, exhaust temp (2), boost)
Defi link meter
Apexi turbo timer
HKS ground wire kit
Motor support bracket ( pump)
Hood dampers
Things to come this year:
NOS intercooler spray
Water methanol injection system
Strut bars nismo
D2 8pod 356mm full brake kit
D2 street springs
Volk Racing Wheels GTC face 2 20"
Cartuner (monitor)
APS TT kit
APS Strut bar
APS Tall Boy
utec map sensor
Nismo oil cover kit
Oil cooler
Defi link meter
Apexi turbo timer
HKS ground wire kit
Hood dampers
Strut bars nismo
D2 street springs
Cartuner (monitor)
Originally Posted by BrianLG35C
Congrats!!
What's the problem with the UTEC? I've heard other APS TT owners are running it without problems.
The car is really great. Very good and high quality materials from APS. Def. worth the money! Tommorrow it will be dynoed. I ll keep you guys posted
. ps: the sound of the 3" and 3.5" test pipes is truly amazing!
Originally Posted by maximumsportZ
Nice setup bro.
On the UTEC it sounds more like a tuner problem than a problem with the product itself..
Ps: Love your car! It was an inspiration for me with your movies to go FI
Originally Posted by clemlover15
Nice job, is the oil cooler a custom set-up, and is that the nismo real diff cooler as well. The ECU is a pain I unless you are very experienced with it. AEM is on the way for me.
Originally Posted by KempieZ
We really tried everything. Maps from turboXs were very bad, maps from some other people wouldnt work either. It was a real pain in the *** the new software. But it could be done, if you worked two weeks on it. If you have a Utec, can you post your map to me, that is my last effort, If you are willing to do so. Thx
I plan on using UTEC on my build however. Good luck.
Very nice setup!
Did you decide to switch to the 3.5" dp's at the last moment because that one pic shows the 2.5" dp bolted to the turbo. What is that flange on the 3.5" dp???
On a side note, am I the only person running the APS TT without the aluminum heat shielding on the exhaust manifolds? Mine are ceraminc coated along with the exhaust housings, and dp's, and I haven't seen any signs of stuff melting.
Originally Posted by Nismo350ZRT
Very nice setup!
Dyno tuning will be for monday. We are waiting for an installation sheet for the unichip. Its the latest version and a little bit different. Monday I ll post the numbers. The car has done a few dyno runs on the Utec and they were very promissing.
http://www.science.uottawa.ca/~paul/.../G35TT070.html
http://www.science.uottawa.ca/~paul/.../G35TT071.html
http://www.science.uottawa.ca/~paul/.../G35TT072.html
http://www.science.uottawa.ca/~paul/.../G35TT073.html
http://www.science.uottawa.ca/~paul/.../G35TT079.html
http://www.science.uottawa.ca/~paul/.../G35TT088.html
On a side note, I'll be trying the UTEC instead of the unichip comes the Spring. It seems quite easy to use, we'll see...
Later,
Originally Posted by Madelinot
I had mine coated as well with Cermakrome. It has help up extremely well, it still looks just like the following pictures after 25,000 miles:
Later,
Later,
I remember when you posted the pics and I pm'd you about it. My parts are coated with turbo black.I'm with Kemp on the UTEC. I've heard too many ppl having issues with it. One of the local import tuners, who was tuning BrokeZ's car (PE TT, UTEC), told me it was buggy and not to get it. I'm waiting on the AEM and Hyrda.
