Can anyone tell me the Torque Spec range of ARP L19 ,Main bolts and Eagle Rod botls?
Old Jan 27, 2007 | 04:18 PM
marcelz's Avatar
marcelz
Default Can anyone tell me the Torque Spec range of ARP L19 ,Main bolts and Eagle Rod botls?
thanks alot...
Old Jan 28, 2007 | 06:43 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
L19's are 90-93ft/lbs. Make sure to use moly lube only, and run a chase through the holes..make sure they are clean.
ARP mains 60ft/lbs with moly
I dont have the spec for eagle rod bolts with me...I am sure someone else can answer that.
Old Jan 28, 2007 | 08:42 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
The Eagle rods use a 3/8" ARP2000 that torques to 45 Ft/Lbs with Moly lube
Old Apr 16, 2009 | 06:35 PM
Madelinot's Avatar
Madelinot
Reviving this old thread instead of starting a new one...
So 90-93ft-lbs for the head nut of the L19 kit. What about the rods themselves that screw into the block? What is the torque spec on those?
BTW, I did search, but could not find the answer.
Thanks!
Old Apr 16, 2009 | 07:32 PM
rrmedicx's Avatar
rrmedicx
I could be wrong but I believe I read somewhere here that the head studs themselves only need to be about 10-15lbs of torque to properly anchor them into the block.
But please get confirmation from a second source.
The nuts on those studs you already know 90-93 lbs.
Old Apr 17, 2009 | 05:12 AM
Sharif@Forged
Forged Performance
Just snug them into the block...basically light hand tight. There is no official trq spec. Technically, they should be put into the block unloaded, but a little snugging isn't a bad thing.
Old Apr 17, 2009 | 05:57 PM
Madelinot's Avatar
Madelinot
^^^^ Great, that's what I did. Thanks again for you help Sharif. What a great shop to deal with....
aboodi
Oct 28, 2015 02:07 PM
