Did I bend a rod????
Old Feb 7, 2007 | 05:14 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default Did I bend a rod????
Last night I went somewhere an hour away.. Took care of business and when I started the car , idle was rough and sounded weird. Constant audible thuds/clicking from the engine bay and I could feel the vibration as well... It sounded like really loud cams... Pushing the clutch didn't change anything... But, when I slowly revved the engine, the constant thuds/clicking noise and vibration went away once RPM went above 1000rpm.
Although it was stupid of me to drive back, I did and the car drove fine.. After driving on a highway for 30 min, I exited and stopped at a stoplight.. Idle was perfect.. no noise, no vibration.. I came home and reset the ecu, and performed throttle position learning, and idle learning procedures.. Car seemed to be fine..
Then this morning.. it all came back!! What's going on here??
Can low oil level possibly be the cause of this? My APS sump pump leaks a little, so I need to add oil periodically... I should add oil and see...
Since it's driving fine above 1000rpm, I don't think I bent a rod... what do you guys think?
Old Feb 7, 2007 | 05:22 PM
priscilla ls1's Avatar
priscilla ls1
Might be low on oil.
Old Feb 7, 2007 | 05:47 PM
chris'smax's Avatar
chris'smax
So the issue only occurs on cold start? I would say it could be a bad rod bearing but that usually is evident when the oil has heated up enough to thin out.
Old Feb 7, 2007 | 05:56 PM
thawk408's Avatar
thawk408
My car kinda did the same thing as yours. After a day of driving it the noise was at any RPM and ended up being a spun rod bearing. I am not rebuilding the motor. IF it is a spun bearing STOP driving the car, so you might have a chance of saving your crank.
Old Feb 7, 2007 | 07:28 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Yeah I guess noise is only there before the engine warms up... I added oil just now and I'm gonna let it cool down for 6 hours before I start up the engine again.. Is there any other ways to tell it is indeed the bad rod bearing?
Old Feb 7, 2007 | 07:33 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
That's not a good news... I hope it's just a low oil....
Old Feb 7, 2007 | 07:48 PM
THE TECH's Avatar
THE TECH
Let us know if you find anything concrete.
Old Feb 7, 2007 | 07:55 PM
thawk408's Avatar
thawk408
Pull the oil pan. If you got shavings then its probably a bearing.
Old Feb 7, 2007 | 08:15 PM
Beer Goggles's Avatar
Beer Goggles
Is this like a misfire, could you just have a bad coil?
Old Feb 7, 2007 | 08:47 PM
thawk408's Avatar
thawk408
if it was a bad coil it wouldnt tick
Old Feb 7, 2007 | 09:11 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
No, I don't think so.. the noise was in sync.. like the cams ticking noises. but louder..
Old Feb 8, 2007 | 05:22 AM
chris'smax's Avatar
chris'smax
It will usually make a marbles in a can noise at idle and the noise will be rpm dependent. Usually the cause is detonation impacting the piston when it is on it stroke upwards. This pushes down on the rod giving the rod bearing just enough space to move.
Old Feb 8, 2007 | 05:27 AM
chris'smax's Avatar
chris'smax
Just thought of something, has anyone experienced a loose timming chain? I am pretty sure the chain tensioner is hydraulic so you could be getting some chain slap on cold start and then when the tensioner buildes up enough hydraulic pressure the chain tightens.
Don't take this word for word, but just an idea i am throwing out there
Old Feb 8, 2007 | 01:42 PM
Beer Goggles
Did you use an oil filter without an ANTI-siphon valve, that would lead to dry start and lots of noise.
Also the one person that I knew that was Turbo had a coil go bad and he thought he ruined his car too.
Old Feb 8, 2007 | 04:07 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I never had a problem with oil filter valve... I changed oil 1500miles ago..
If a coil goes bad, shouldn't it make noise all the time, since it causes misfire?
Old Feb 8, 2007 | 04:24 PM
Beer Goggles
I'm assuming it could be almost bad, where it would have problems when cold.
What oil filter did you use?
Old Feb 8, 2007 | 04:32 PM
cleanandquick06's Avatar
cleanandquick06
just a thought. he could have a bad lifter. try using a thinner oil
Old Feb 8, 2007 | 04:41 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
ARGH!!!! The noise is still there~ I started up the car after cooling it down for 6hours.. Noise was there for about 10 min, and it disappeared once the car warmed up...
Could it be the VVT sprocket issue????? There is a TSB out for this problem!!
Sam at GT motorsports mentions it here:
https://my350z.com/forum/showthread....ts+short+block
The TSB is to address a momentary noise after a cold start from the timing cover area,it get mistaken for a timing chain tensioner or guide ,there is a spring that keep tension on the VVT sprocket ,the spring brakes or get weekend witch will cause the noise ,these sprockets are not cheep there are about $500 give or take each .I will scan the TSB and post it here . we have seen this problem mainly on the early 03-04 models .
Old Feb 8, 2007 | 07:59 PM
sugarspunZ's Avatar
sugarspunZ
i hate to say it bro but that is exactly how my car sounded when i bent my rod/s.
Old Feb 9, 2007 | 04:51 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
So your ticking/thuds would disappear once the car warms up as well? This is just too strange... The short block I bought off from one of the members is being shipped to GT Motorsports as I type this... So, I might be in the same boat as you... I was already planning on building the engine, and this happens....
