rod/piston combo on ebay
Old Feb 26, 2007 | 07:12 AM
dukeduster's Avatar
dukeduster
You know you guys are to biased. I went to these guys shop and saw their cars. Alamo autoports isn't the friendliest of people but they know what they are doing. I would order from them cause they are a shop and I have actually been there and dyno tuned my car their as well. Please stop hating on things you know nothing about. id put a 100 bux they have ran 34psi of boost on the setup if they say they have.
Old Feb 26, 2007 | 07:14 AM
dukeduster's Avatar
dukeduster
oh BTW they offer great support as I had a question after the dyno and they answered my question as soon as i called.
Old Feb 26, 2007 | 07:44 AM
merlin3's Avatar
merlin3
If a reputable vendor was within 50 bucks or so of what I can find them for online the I would purchase from them. I am having a local shop assemble the short block. It's the same shop that did the short block on my z32 and I'm very happy with it as well.
Old Feb 26, 2007 | 08:02 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I didnt even realize that Alamo was the vendor. His ebay user name didnt indicate that. Sorry.
Old Feb 26, 2007 | 08:25 AM
merlin3's Avatar
merlin3
hey sharif is the arp head and main stud kit that you sell for $400 good enough for what I am wanting to do? Also It looks like most of the rod kits come with arp rod bolts, are those good enough? I've got about a million questions but still learning about these engines.
Old Feb 26, 2007 | 09:05 AM
Sharif@Forged
Forged Performance
The ARP rod bolts included with the Eagle rods are fine. However, i would not use the standard ARP head studs..even with low boost. You would be better off using stock head bolts, if you are planning on a low power build up. Otherwise, use the ARP L19 head studs that we sell.
Old Feb 26, 2007 | 09:16 AM
merlin3's Avatar
merlin3
And do I need the arp main bolts as well or is stock ok? I'm pulling the engine right now and hope to get it running in a few weeks.
Old Feb 26, 2007 | 09:31 AM
TTRANK's Avatar
TTRANK
What is your definition of "low power"? Under 550?
Old Feb 26, 2007 | 09:43 AM
TENGAI's Avatar
TENGAI
My
1. Go with the Eagle Rods. They're perfect for your power goals and regardless of what you hear, they're very strong rods.
2. Ditch the Arias pistons. Standard Arias pistons have weak piston rings. Weisco pistons are actually better than the standard Arias set IMO.
3. ARP main studs cheap. Peace of mind is priceless.
4. L19 head studs FTW. Standard ARP head studs fall into the same catagory as the Arias standard pistons IMO.
5. HKS head gaskets. Cometic is almost as flimsy as the stock ones...
Setup (depending on EMS) should easily break into the 500's without issue.
Old Feb 26, 2007 | 11:35 AM
merlin3's Avatar
merlin3
ok, I think the same guy sells a wiseco/eagle combo so maybe I'll take a look at that. I have the greddy emanage and j&s safeguard. Not sure what else I'm going to need.
Old Feb 26, 2007 | 11:37 AM
Sharif@Forged
Forged Performance
We do not use Standard ARP head studs at all. We even had head lift on the race track with a normally aspirated engine build...believe it or not. We switched to the L19 headstuds at 92ft/lbs, and the car ran cool and strong all day long.
I was just saying, that given the choice between standard ARP and stock headbolts, you would be better off with stock head bolts.
Old Feb 26, 2007 | 11:49 AM
rocks's Avatar
rocks
I have also been to alamo motorsports. They are not the nicest people but they sure as hell know what they are doing.
Old Feb 27, 2007 | 04:29 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Originally Posted by MikeEwithTheZ
At the shop i hang around at all the time we have gotten several kits from eagle where the weight of each rod was way different...I am not knocking them as a company cause i know they make a decent rod at a good price, i just wouldn't put them in my own car because of what i have seen...(these rods were for Porsche cars)...I think he should get them from a vendor and not eBay in case he runs into this problem or any problem with any part he buys...
ACTUALLY, Eagle rods are almost perfect. when my machine shop guy stopped by my shop last night, we were talking about it, they are weighed and balanced damn near a half of gram of each other. you can always tell when you get a set back and you look at the bottom of the rod.
Eagle rods usually dont have any material taken off at least 3 of them..
Old Feb 27, 2007 | 04:33 AM
Audible Mayhem
My350z
what head gasket was being used in the scenario?? just wondering
Old Feb 27, 2007 | 04:59 AM
Jay'Z's Avatar
Jay'Z
What is the cheapest you can do the rod/piston/L19 headstuds combo?
Old Feb 27, 2007 | 05:10 AM
merlin3's Avatar
merlin3
same here, give me a price on eagle rods/wiseco or arias pistons, L19 head studs, arp main studs, hks head gasket.
Old Feb 27, 2007 | 06:14 AM
Sharif@Forged
Forged Performance
PM's sent to both of you.
Old Feb 27, 2007 | 06:16 AM
  #38
Sharif@Forged
Forged Performance
[edit]Cosworth Gasket. The car we did, suddenly became a track only car. So it spent it's life on the circuit course, at 5000-7200rpm continuously. probably woulnt have been an issue on a street car, but the circuit course tends to quickly uncovered cooling and other misc issues.
Old Apr 3, 2007 | 09:24 PM
  #39
webcarconnection's Avatar
webcarconnection
Hey Sherif... PM me the cheapest you can do with rod/piston/L19 headstuds combo too... but I want 10.0 of comp. on the pistons if is posible... thanks!
P.S. I want around 540 whp tops!
Old Apr 4, 2007 | 12:34 AM
  #40
2slo2bfurious's Avatar
2slo2bfurious
I say you get it from a vendor, and if possible a local vendor to you. When I got my arias pistons, arias put a wrong size pin in the set, and my vendor (Performance Factory) swapped the pin the same evening after hours just to help with my time constraints... buy from vendors ftw! Don't go by website prices, sometimes they can come down depending on all kinds of things...
