TURBONETICS G35 Turbo Install (DVD)
Old Mar 10, 2007 | 11:58 PM
g35_anonymous's Avatar
g35_anonymous
Is this going to be part of Ali's Drift Garage? We did the hose techniques segment on my car a few weeks ago. The car is done for the most part, just working on brakes and suspension here soon. What are the build specs gunna be? Good luck with the project!
Old Mar 11, 2007 | 05:37 AM
DRIFTING.com's Avatar
DRIFTING.com
Hi g35_anonymous,
The hose techniques video is an online feature that will be reviewed on Wednesday.
Old Mar 11, 2007 | 12:15 PM
DRIFTING.com
http://store.driftingshop.com/35g35tuindvd.html
Old Mar 11, 2007 | 12:43 PM
DRIFTING.com
Old Mar 11, 2007 | 01:35 PM
QuicksilverZ33's Avatar
QuicksilverZ33
looks good so far
Old Mar 11, 2007 | 02:46 PM
MardiGrasMax's Avatar
MardiGrasMax
What camera are you using to shoot your footage?
Old Mar 11, 2007 | 06:49 PM
DRIFTING.com
Originally Posted by QuicksilverZ33
looks good so far
Thank you QuicksilverZ33,
We would like to re-shoot the installation on a 350Z but this has not been confirmed.
Old Mar 11, 2007 | 07:04 PM
DRIFTING.com
Old Mar 11, 2007 | 07:09 PM
QuicksilverZ33
This is very interesting, as I plan to purchase/install the kit myself in the future...I will most likely be purchasing this video...Keep up the good work!
Old Mar 11, 2007 | 07:27 PM
DRIFTING.com
Thank you,
Old Mar 11, 2007 | 09:16 PM
Mahdivr4's Avatar
Mahdivr4
great idea! good luck!
Old Mar 11, 2007 | 09:41 PM
DRIFTING.com
Old Mar 12, 2007 | 08:18 AM
DRIFTING.com
Old Mar 12, 2007 | 08:48 AM
MIAPLAYA's Avatar
MIAPLAYA
Shots look great Alex!! Thanks for coming up this weekend...
Old Mar 12, 2007 | 02:37 PM
VIZAGE's Avatar
VIZAGE
In regards to the above picture (the up-pipe), I've now have seen this one and many others, but the flange seems to be flat and level when placed upright. But the one I installed on my kit last week is at an angle. As in slightly to the left going downwards. I hope you understand what I'm saying here. Just wondering if that is normal? It kind of threw off the alignment of the turbo and cause me another two hours of install time to redo some ac lines, grind out some of the headlight bracket for the hump hose and still have a small concern about the oil return line fitting for it's just about on the frame, in which it might hit when vibrating or running. Will keep eye on for awhile though.
Also this cause the turbo to be alot closer to the radiator than the picture showed, all most touching it but I think I have this underwraps. Is all the normal or am I'm being picky. I know nothing never works out perfect for it is aftermarket but what do you think? I shoul also add that I did call TN tech guy and he said it was normal but I'd like to get other insight as well.
Old Mar 12, 2007 | 02:50 PM
tomiegunzz's Avatar
tomiegunzz
Very interesting...
Old Mar 12, 2007 | 03:49 PM
DRIFTING.com
Old Mar 12, 2007 | 03:58 PM
  #38
MIAPLAYA's Avatar
MIAPLAYA
This install was a little bit unique. Your set up should be fine...
Old Mar 14, 2007 | 12:07 AM
  #39
DRIFTING.com
The fuel pump video feature is now online; the link should be public by tomorrow.
Old Mar 14, 2007 | 02:03 PM
  #40
DRIFTING.com
The G35 Sedan fuel pump test video is now public.
http://www.youtube.com/watch?v=SCy98COo_Vg
This install is not the same as the 350Z.
