Greddy RS or HKS SSQV
I have a newer SSQV going on my build. When its done, ill try and get some clips up, altho im sure by then MaximumSportZ will have some sound/video up. The new ssqv's do look hot though!
I don't know if I would have enough room with a oil cooler an PS cooler on the sides of the intercooler, not to mention I will be running the extreme kit. If not I would most likely copy your idea! :P
-George
GT Motorsports
-George
GT Motorsports
-George
GT Motorsports
-George
GT Motorsports
Originally Posted by GQ 350z
If you go with the greddy setup, could you put the BOV's like that as well? Also, do you have to have a built block to run dual Bov's?
no need for a built block!... and the greddy's work great!!!
Quad, SWEET setup. So what's the point of the dual's and that particular location? Is it much louder? Also, is it safer for the motor?
Originally Posted by maximumsportZ
When you run two your not running it for sound but to prevent compressor surge, so the turbine doesn't spin backwards. Especially helpfull if your running alot of boost.
also, my drivability has improved. previuosly, I used to get some surging when driving around at low throttle angles. I think it may have had to do witht the close proximity of the BOV to the MAF on my pipes. Now, the car drives like " butta."
hey guys, i have an aps st and my bov is not impressive at all. matter of fact you can barely hear it over my exhaust note. i want to get the hks bov, is there anyhting else i will need to attach it? or does it come with everything needed? thanks
I got it here:
http://www.maxspeed-motorsports.com/ssqvadap.html
some of you guys have your bov's mounted in some weird locations, I have always read and this is how it is generally done on the z32's that you want the bov as close to the throttle body as possible.
does anyone have any good clips of the Type RS bov? The HKS has somewhat of a high pitched wistle at the end. Is the type RS like this, or is it more of a air release sound?
