Shop owners - Tuners - opinions on SC parasitic loss
Old Mar 14, 2007 | 02:02 PM
  #41
sentry65's Avatar
sentry65
the burninator
Originally Posted by booger
WE are strickly talking about parasitic loss . at the same psi on the exact same motor
it's all guessing then.
who here can say they run the same timing maps, same boost, and same A/F at the same elevation, same ambient temp, same dyno, same fuel octane, and same everything else on the car.
I don't know what else to say. We talk about 13 psi SC vs 13 psi turbo and every car is running drasticaly different setups - cams, exhaust, cats/TP, etc. We talk about bone stock out of the box tunes with 8 psi vs 8 psi, and that's not a good comparison because the tunes are apparently too drastically different to think it's within reason to compare
So now you're talking about optimally tuning each type of car. Well a small turbo will always have more area under the curve for the same psi compared to a SC so no contest there. I mean, I agree with you that a turbo is going to be more capable, but I'm thinking if the parasitic loss of the SC was really rearing it's ugly head in a major way, then adding more boost wouldn't be giving people more power. Several people with 2.87 pulleys are getting in the 430-450whp range with 11-12 "psi" yet they were making 390-410whp at 9-10psi with the 3.12 pulley. If the vortech was truely running into the threshold of parasitic loss overcoming power being made, then they wouldn't be making more power. As far as power beyond a 2.87 pulleyed stock blower... I dunno, I'm not willing to go any further.
Maybe you're already at that threshold where more boost is meaningless - obviously with the belt slipping, that's causing it to be meaningless anyway other than more power before it slips
I'm still trying to find people who have blown up rods with a vortech kit though - regardless of power
If I recall the greddy TT's stock tune wasn't all that safe...seem to remember at least a couple blown up engines, but then again, same with the early prochargers
I dunno, I still don't see how worrying about parasitic losses are going to make me or anyone lose sleep at night unless they're shooting for over 500whp on the stock displacement engine
Old Mar 14, 2007 | 02:09 PM
  #42
booger's Avatar
booger
What ever....I'll stick to the safe side when figuring fuel requirements . That for 600whp you'll need 750whp worth of fuel . And at around 400whp the fuel needs will be about 1/3 less than that [ 500whp worth ] Just to be on the safe side .
Old Mar 14, 2007 | 02:21 PM
  #43
sentry65's Avatar
sentry65
the burninator
as long as the A/F and fuel pressure are good, I don't see how it matters other than worse gas mileage. I guess for someone starting from scratch, they'd just make sure to get larger injectors and a better fuel pump than they normally would think to get. If the fuel system wasn't up to par, there wouldn't be good pressure or A/F
I've never really thought of it in any other way. If my tuner gave me my car with perfect A/F and fuel pressure, I probably wouldn't ask him if my 600whp car has 750whp worth of fuel or not, and if it didn't that he should go back and add more fuel - it's not like he's measuring fuel volume, he's just getting the A/F to be around 11.5 or so
Booger, I kinda wonder why you're sticking with the vortech if you're really worried about the parasitic loss - even now that you have the Dsport belt setup so your belt shouldn't slip anymore. Do you not think you'll be able to make more power beyond the 13psi that you've been slipping at?
I never intended to go above 500whp on a stock block so I've been happy with the vortech. I might someday stroke my engine to 4.24 liters and see how it does with the stock vortech 2.87 blower first before thinking of trying the T-trim and possibly slipping at whatever given power level
Old Mar 14, 2007 | 03:47 PM
  #44
MMC Racing's Avatar
MMC Racing
You could two cars that looked like this:
350z 10psi 425rwhp
350z 10psi 455rwhp
Assuming same dyno and conditions, what is the big difference? The 455 rwhp guy is running a smaller pulley, but has better flowing heads and exhaust. Just like an extremely restrictive exhaust (say clogged cats) will show a higher PSI, but lower power
While Corky's statements on doubling power seem to hold pretty true in a world I'm more familiar with (supercharged Lightnings), it depends on many factors.
-Mark
Old Mar 14, 2007 | 03:53 PM
  #45
Jay'Z's Avatar
Jay'Z
I wish this was posted months ago when i upgraded my cats= loss in boost...
Old Mar 14, 2007 | 03:56 PM
  #46
sentry65's Avatar
sentry65
the burninator
who care's about boost, did you gain power?
Old Mar 14, 2007 | 04:00 PM
  #47
MMC Racing's Avatar
MMC Racing
Exactly... And to add to my previous post, boost isn't the whole story either. Outlet temps play a big part in what actual power is made. A blower can be ran on the outside of its efficiency curve and produce a lot of heat, while a different supercharger may be within it's operating efficiency and have a 50 degree lower outlet temp. Both can be producing the same boost at different outlet temps and different HP results.
-Mark
Old Mar 14, 2007 | 04:02 PM
  #48
Jay'Z's Avatar
Jay'Z
I lost power.... I will post more today.. Im going to finally find out if my POS ATI BPV was killing me, or switching to HFC's killed me.... Well see....
Old Mar 14, 2007 | 04:14 PM
  #49
sentry65's Avatar
sentry65
the burninator
I think the BPV is probably most likely at fault. HF cats adds power even when NA and you don't even have cams, which lots of NA guys have with an open exhaust and they still make power
Old Mar 14, 2007 | 04:18 PM
  #50
Jay'Z's Avatar
Jay'Z
I believe so too... The ATI BPV is a serious POS... ATI attempted another BPV, that looks like a cheap plastic tial in black.. I havent seen anyone else with it.. I may be the only one with it...... Because I only see others with the Grey mushroom looking bpv....
Old Mar 14, 2007 | 05:19 PM
  #51
booger's Avatar
booger
I was never worried about parasitic lose . You are the one that that seems to think it isnt anything near what it actually is . You have your opinion and I have mine and they are different . Thats why I posted this thread to begin with . To get the OPINION of shop owners and tuners that have actual hands on knowledge . But it seems it just ended up being you arguing every little difference between a SC and a turbo .
I dont know about the other guys that have replied [ if they are tuners or owners ] , but Sharif is the only one so far that has replied and he seems to agree with the artical in DSport mag and my thoughts on it .
I bought Derek's cog set up to be able to build boost to redline and to try to get the most out of what I have . Im not worried about trying to have the top whp with a SC . That will never happen with my AT5 . I dont make excuses , or try to dream up reason why my SC isnt making the same whp as a turbo . Nor do I try to make my SC seem like it is better in some areas of the power curve than a turbo . Anyone can come up with graphs and calculations on this and that . Trying to justify something that isnt true or isnt going to happen in real life .
So maybe you can sit back for a while and not dominate a thread and let a few others reply . So we can get some opinions from others
Old Mar 14, 2007 | 05:30 PM
  #52
sentry65's Avatar
sentry65
the burninator
...we obviously disagree on many things then
I think the parasitic loss is what it is, and it increases at a somewhat exponential rate as you push the blower further and further. As long as you're under the area where the SC really starts to fall on its face the parasitic loss isn't a show stopper for making decent power. That's all I've ever thought.
kinda like how the stillen makes perfectly good power up until around 340whp then it just falls on its face after that trying to make more
The parasitic loss I do think will become really severe trying to cross the 500whp mark with a vortech, where adding another lb of boost does hardly anything at all other than raise under hood temps. Otherwise, that's partly why I run 96 octane fuel and water injection despite my power levels - because I know the engine is working harder than what the dyno is showing
btw, how do you take a certain volume of fuel and determine how much hp that fuel is capable of making? I'm sure there's something that'll explain it
I haven't been dabating dyno curves or turbo vs SC in this thread. I've only brought up compressor efficiencies and parasitic loss issues with turbos and SC in regards to turbos because turbos are the only other FI method there is really. Also that Dsport article you keep bringing up has to do with turbo/NA parasitic loss compared to SC parasitic loss so how can someone talk about it without mentioning a turbo?
Old Mar 14, 2007 | 05:35 PM
  #53
booger's Avatar
booger
What is it with you ? Please !!!!!! Let it rest and lets see if we can get some one other than You to give thier opinion . YOU dont need to get the last word in .
Old Mar 14, 2007 | 05:38 PM
  #54
sentry65's Avatar
sentry65
the burninator
booger, then put me on your ignore list
I'm here to participate and there's no one else has posted in here anyway during the last couple hours
Old Mar 14, 2007 | 05:44 PM
  #55
Jay'Z's Avatar
Jay'Z
LMAO at you two........ This **** is funny!!!!
Old Mar 14, 2007 | 05:48 PM
  #56
booger's Avatar
booger
1- Are you a pro tuner ?
2- Are you a shop owner ?
3- This is my thread , and I asked you to let it rest so you dont try to dominate the thread . You seem not to read anyone elses opinion or dont think anyone elses opinion matters .
4- Read the threads Topic....you are not a pro tuner nor a shop owner , I think that is the only ones I asked a opinion from .
And to add , since you already ruined the thread and no one with an opinion that matters wont reply because of you...Thanks !
  #57
MMC Racing's Avatar
MMC Racing
Parasitic loss has nothing to do with blower capacity and efficiency. If the blower is past it's operational limits, it is a big heat pump at that point. If you hit a brick wall at 500hp, it isn't because of increased parasitic loss (unless you are defining it differently than I do).
-Mark
Old Mar 14, 2007 | 05:56 PM
  #58
booger's Avatar
booger
Mark
Call as soon as your in town Saturday and we'll meet along the Interstate and 72nd street , and you can follow me to the shop from there
Old Mar 14, 2007 | 06:19 PM
  #59
Quamen's Avatar
Quamen
Regarding belt slippage for those of you who are using the vortech. Have you ever considered getting a larger cog gear for on the back side of the jackshaft? This would great a sort of step up since the cog gear on the back of the jackshaft and the cog on the back of the V2 would no longer have a 1:1 ratio. This would allow you to run a larger pulley on the front of the jackshaft which translates to more surface contact on the pulley.
Just a thought.
Old Mar 14, 2007 | 06:23 PM
  #60
booger's Avatar
booger
Just a thought.
I already have done it . I had a custom 34 tooth cog pulley made for the jackshaft . The stock is 32 tooth . You cant go any bigger , as the cam sensors get in the way . I run the 3.12 serp pulley on the other side .
