turbonetics people quick question for you...
Old Mar 13, 2007 | 07:47 PM
boostintt's Avatar
boostintt
Default turbonetics people quick question for you...
what size spring comes stock in the wg on the turbonetics single turbo kit for 350z.
Old Mar 13, 2007 | 09:02 PM
TayTaythatsme04's Avatar
TayTaythatsme04
I think it 8psi spring.
T
Old Mar 13, 2007 | 09:10 PM
boostintt's Avatar
boostintt
T
thanks t.
anyone else wants to second that???
Old Mar 13, 2007 | 09:22 PM
2slo2bfurious's Avatar
2slo2bfurious
isn't it 9 and you lose .5 to 1 across the ic?
Old Mar 13, 2007 | 09:25 PM
boostintt's Avatar
boostintt
anyone else???
im selling my turbonetics wastegate and the buyer wants to know what spring comes in it.
Old Mar 13, 2007 | 09:27 PM
2slo2bfurious
Quoted from MIAPLAYA off another thread
Originally Posted by MIAPLAYA
OK lets see if I can make this clear...
The boost signal from the compressor outlet (fitting on the turbo) goes to the lower port of the wastegate. The lower port is the one furthest away from the Red Turbonetics logo that is on the polished diaphram housing (top). The purpose of this signal is to open the wastegate when the spring pressure is overcome by the pressurized air. For this turbo kit the spring in the wastegate is a 9 PSI spring. The compressor will produce 9 PSI of pressure at the outlet but after the pressure drop across the intercooler and charge piping the pressure at the intake manifold is actually 8-8.5 PSI.
The boost signal line from plenum (intake manifold) goes to the upper port on the BOV. That is the port the is closest to the red logo at the top. The purpose of this line is to hold the BOV closed under boost. When you close the throttle plate the immediate vaccum condition in the plenum caused by the closed throttle pulls the BOV open until the spring overcomes the vacuum and shuts the valve again.
Hope that was clear enough...
Old Mar 13, 2007 | 09:50 PM
boostintt's Avatar
boostintt
thank you sir...
Old Mar 14, 2007 | 06:52 AM
QuadCam's Avatar
QuadCam
it is a special wastegate spring.
It is rated at giving you 8-9 pis, but it has been known to offer a special scramble boost setting.......
Just kidding, don't flame me too hard.
Old Mar 14, 2007 | 06:53 AM
MIAPLAYA's Avatar
MIAPLAYA
Its a 9 PSI spring with pressure drop across the intercooler core and piping you should see 8-8.5 PSI at the manifold.
Old Mar 14, 2007 | 07:42 AM
QuadCam's Avatar
QuadCam
I do remember the box that the wastegate came with said 10 psi on the side of it.....I typically saw 8.5-9.5 psi on my turbonetics kit........
I used the overboost correction kit, and never really had a problem.....I think I logged a low 10 psi value once or twice.
Old Mar 14, 2007 | 12:27 PM
MIAPLAYA's Avatar
MIAPLAYA
Explain to me how that would be possible considering the highest rated spring available for the Evolution wastegate is a 9 PSI spring...
http://turboneticsownersclub.com/tur...nWastegate.pdf
Old Mar 14, 2007 | 01:41 PM
2slo2bfurious
Just wondering what kind of wastegate you swapping it with?
Old Mar 14, 2007 | 02:23 PM
boostintt's Avatar
boostintt
tial with a .5 bar spring.
Old Mar 14, 2007 | 02:45 PM
QuadCam's Avatar
QuadCam
i can't explain it........i didn't print the label on the box.
Old Mar 14, 2007 | 03:44 PM
MIAPLAYA's Avatar
MIAPLAYA
Got a pic of the label?
Old Mar 14, 2007 | 04:15 PM
QuadCam's Avatar
QuadCam
no, I sure don't. My wife tries to throw away everything asap. I am only recalling it from memory as it struck me as odd......
whatever the case may be, I never had an overboosting issue.
Old Nov 19, 2008 | 05:29 PM
tylerxfire's Avatar
tylerxfire
whats the overboost kit consist of
Old Nov 20, 2008 | 07:55 AM
str8dum1's Avatar
str8dum1
^^a blown motor
you do not want over boost.
issyz
Jul 2, 2017 03:04 PM
May 30, 2017 03:28 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
