HKS GT3037 ST Installed
Old May 22, 2007 | 04:48 AM
  #41
baptist's Avatar
baptist
Originally Posted by live2themaxuk
You guys are spoilt by the amout of decent tuners you have in the US and how darn reasonable the prices are comparded to dumb-*** rip off britannia
Its cheaper in America, no doubt, but people in the UK still manage.
Where are you based?
Old Aug 8, 2007 | 11:47 PM
  #42
350zrn35's Avatar
350zrn35
Default HKS GT3037 SPL turbo kit
did anyone install this kit on a USDM Z?
Old Aug 19, 2007 | 05:04 PM
  #43
350zrn35's Avatar
350zrn35
Originally Posted by MR RIZK
Well after a long and stressfull 3 weeks of doing the install on stands at home and by myself for 99% of the job, a little bit every day after work it is finally finsihed.
The kit was a perfect fit in every respect the only downside was the instructions were in japanese. Tell you what google translate became my best friend.
Basically at the moment the install is per the book. Stock boost using the wastegate spring which is holding it around 4.5psi. The pics don't show it below but nearly everthing and anything has also been insulated including the body work near the turbo.
In addition to the kit I have fitted the following
Ceramo Coated the manifolds
PE 510cc Injectors
Upgraded fuel pump
AAM Intake Spacer
HKS FCON V Pro with MAP,TEMP and harness
HKS Super Fire Plugs - 40IL's
HKS Oil cooler on order
NISMO Thermostat
NISMO Radiator Cap
HKS SSQV - on its way
Radiator - researching
Catch Can - No idea where th hell to fit one
The car was already fitted with a Amuse R1 exhaust which is still being used.
At the moment it has about a 95% tune in it and all I can say is the car with the FCON is super smooth. There is no hesitation WOT, Part throttle or with any accessories running etc. What annoyed me the most was that my Pro Dealer has never done a 350z before so we expected that the harness and supplied base map would be good to go to get it running. My a$$ it was. After a good 5 hours of troubleshooting on how the fcon will control the throttle and before we started modifying the harness we thought we would send an email to HKS asking if there was any gotchas with the FCON install in the Z. PNP my butt after they came back to us with about 5 pages of info on how the harness, fcon and maps should be modified it was all up and running So much for a $390 buck harness
The car is making about 310WHP on the 4.5psi which you all will say that is nothing but keep in mind these are early days. Need to get everything in check first before we start tinkering.
At the moment it looks to be creating full boost at about 2900-3100rpm.
Also a big thanks to Tom my local HKS Pro Dealer
Below are some pictures of the install..
Michael
you can get an ARC Oil cooler, it is a pretty cool design! Do you know the possiblility of fitting this kit on a USDM Z? thx
Old Aug 19, 2007 | 07:03 PM
  #44
Sea Bass's Avatar
Sea Bass
Beautiful looking kit. It's a shame HKS couldn't configure it to work with LHD cars. Of course, I imagine it would cost a grip compared to the other ST kits here as well.
What are the measuring units for the dyno curve? I ask because the tq compared to the hp is INSANELY high. Makes me think you're driving a Kenworth
Old Aug 20, 2007 | 03:57 AM
  #45
MR RIZK's Avatar
MR RIZK
KW and NM
Old Aug 20, 2007 | 08:42 AM
  #46
Slick 6MT's Avatar
Slick 6MT
KW and NM
Any updates on the setup? (i.e. How's it running? Any problems? etc.)
Old Aug 20, 2007 | 06:33 PM
  #47
MaRbLe's Avatar
MaRbLe
Due to the steering rack both the single and twin kit will not work on the US spec Z's. So far they seem to have no plans to make a US spec version but we will get a US spec version on the HKS GT Supercharger at some point. I really wish they would offer all of them for US spec Z's....
Old Aug 21, 2007 | 12:04 AM
  #48
MR RIZK's Avatar
MR RIZK
No problems so far. Investigating options for a new motor to rebuild on the side and thats about it at the moment.
Old Aug 21, 2007 | 12:42 AM
  #49
silver nismo's Avatar
silver nismo
well done and keep us posted :-)
Old Aug 21, 2007 | 12:44 AM
  #50
silver nismo
Here are some pics of the HKS oil cooler. Has note been fitted yet but when it is will take some more photos. You will notice that the HKS unit replaces the factory washer bottle with the blue pouch which has the integrated pump.
You will surprised that it will cool things down more than the radiator it self... i have tested that myself.. good choice and with HKS u will never go wrong good luck..
Old Aug 21, 2007 | 12:48 AM
  #51
kfresh's Avatar
kfresh
Thats awesome man... I am looking more and more at the HKS kit as something different.
Where abouts in Aus are you?
Cheers,
-K
Old Oct 14, 2008 | 09:37 PM
  #52
Kwame's Avatar
Kwame
Any pictures of where you mounted the windshield washer pouch within the engine bay?
Old Oct 14, 2008 | 11:29 PM
  #53
350zrn35's Avatar
350zrn35
HKS USA has offer a version of twin turbo setup kit for the US market now. It gives you a lot of flexibility, however, it will also cost a lot more at the end for all the custom fabrication.
