Road trip with boosted Z ??
Old Apr 18, 2007 | 05:27 AM
Gurp's Avatar
Gurp
Default Road trip with boosted Z ??
Hey Guys,
Hopefully these arent stupid questions!!.....
I'm planning on driving my car from Edmonton (Elevation: 668m/2191ft) to Vancouver (Elevation: 2m/7ft-sea level). The drive is about 10 hours. Do I need to worry about the change in elevation?
Also, will the 10hour highway drive be okay on the turbo?
I have the APS ST running at 91 octane.
Any help would be greatly appreciated....thanks!
Old Apr 18, 2007 | 05:30 AM
merlin3's Avatar
merlin3
should be ok, I took my twin turbo 300zx on a road trip to florida and back, about 17 hours each way. That was after I just done a twin turbo conversion, I had just rebuilt the whole engine and only had like 200 miles on it and it performed great.
Old Apr 18, 2007 | 05:32 AM
abyss's Avatar
abyss
Should be fine, if your not playing around you should be in low RPMS and no/low boost when cruising.
Old Apr 18, 2007 | 06:50 AM
BamBam's Avatar
BamBam
I think a # of us have taken long trips with turbo'd cars. I would sugest just cruising and using your low boost setting if you have one to save on gas.
Keep an eye on engine/water temps and you should be good.
Old Apr 18, 2007 | 07:10 AM
dutchboy's Avatar
dutchboy
I drove 800+ miles from Georgia to Michigan on a barely broken in motor with no troubles at all. Is 91 octane the most you have available?
Old Apr 18, 2007 | 08:23 AM
Gurp's Avatar
Gurp
94 octane is availiable where I am starting and where I am finishing. Not sure about the ride in between though. If I could run 94 that would probably help?
Old Apr 18, 2007 | 08:27 AM
Jay'Z's Avatar
Jay'Z
Make sure you check your oil level too!! That **** killed me on my drive from Ft. Drum, NY to Ft. L wood MO, and resulted in catastrophic failure!!(on my last car before Z)
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
