Upgrading
Old Apr 19, 2007 | 04:44 PM
Torched Z's Avatar
Torched Z
Default Upgrading
so its soon to be summer and my friend just got a new Lancer IX and i think hes going to be faster then me....that doesnt make me happy!
So i was thinking of a 3.12 pulley, with the turbonetics fuel pump shortcut. Is this a wise decision or im i going to wait for something to blow?!
HELP HELP
p.s. i did search and this is how i got my information. Just needing clarification
Old Apr 20, 2007 | 07:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What is the TN fuel pump shortcut? BTW-Evo9 w/bolt-ons and a tune is EASILY mid 12's low 12's with a good driver, a few have dipped into 11's with alcohol injection-stock snail. You are gonna spend $$$ and likely still get beat.
Old Apr 20, 2007 | 07:39 AM
Torched Z's Avatar
Torched Z
if i understand it correctly(hope i do) its when you take out the fuel pump and put in a 255 one and drill it slightly. Add injectors and dyno it and thats it. But like i said i could be very very wrong!
I have these injectors sitting right in front of me and i want to get them in the car! Dont know the best way to do that though!
Old Apr 20, 2007 | 07:50 AM
THE TECH's Avatar
THE TECH
You don't need to swap pumps to change the injectors. Just install the new injectors and have someone flash your ECU for them.
Old Apr 20, 2007 | 09:05 AM
rocks's Avatar
rocks
How big of injectors can you run on the stock pump by rescaling the ECU for larger injectors? Has this been tried before?
Old Apr 20, 2007 | 11:32 AM
Torched Z's Avatar
Torched Z
so i have 440cc injectors and will be getting a 3.12 pulley soon. All i have to do is install the injectors and then get my car dynoed? Or can i use the Nissans programmer thing that they have at work for flashing?
Old Apr 20, 2007 | 11:44 AM
Gman2004's Avatar
Gman2004
I think a walbro 255 fuel pump would be cheaper than a $600 flash.
Old Apr 20, 2007 | 11:56 AM
Torched Z's Avatar
Torched Z
600bones for a flash!!!
even so if i did get the pump i still would have to get it tuned?
Old Apr 20, 2007 | 12:02 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes
Old Apr 20, 2007 | 12:52 PM
350zSteve's Avatar
350zSteve
If the safety of your stock block is an issue get tuned
Old Apr 20, 2007 | 12:54 PM
350zSteve's Avatar
350zSteve
And I dont see him being able to beat you on 91 octane vs 91 octane...
Old Apr 20, 2007 | 12:59 PM
THE TECH's Avatar
THE TECH
Originally Posted by Gman2004
I think a walbro 255 fuel pump be cheaper than a $600 flash.
But that doesn't change the fact that you are trying to run larger injectors with the stock ECU.
Old Apr 20, 2007 | 01:15 PM
Gman2004's Avatar
Gman2004
The greddy kit brings 440's and there's no need to flash the ECU to run that kit. You scale the injectors with the EMS. If he was swapping out his injectors for 550's then he would need to flash the ECU cause the SS box can't scale enough for 550's.
Old Apr 20, 2007 | 10:08 PM
Torched Z's Avatar
Torched Z
grrr!!!
decisions! Well im going to get the walbro 255 pump and get it tuned. That would be the safe thing to do with my 3.12 pulley?
P.S. - i know i got 440's but how can i know for sure!? What i bought was 440's but what happens if what i bought isnt what i wanted?
........sorry now im paranoid! I just want my car to be a little faster!
Old Apr 21, 2007 | 08:58 AM
THE TECH's Avatar
THE TECH
You don't need to have the SS box control the larger injectors if you have the stock ECU flashed for them. SS box will work normally and you'll have more fuel.
Old Apr 21, 2007 | 03:45 PM
Gman2004's Avatar
Gman2004
either way will work, ecu flash or SS tuning. $600 for the ecu flash, $500-$600 for tuning, and $100 for the walbro 255, but why spend $600 on a flash if he has to pay for a retune anyway? Not to mention his car will be down a few extra days while he waits to get his ECU back.
Old Apr 21, 2007 | 05:25 PM
THE TECH's Avatar
THE TECH
Tuning has to be done either way, but since the SS box only works in boost, there is nothing to control the larger injectors outside of boost unless the ECU is flashed.
Old Apr 22, 2007 | 08:17 AM
Torched Z's Avatar
Torched Z
so the SS tuning can be done where? and the ECu gets sent out to whom? I havent bought anything yet cause i am so confused right now!
i apologize but im doing my research and trying to learn as much as i can but im still new!
Old Apr 22, 2007 | 09:33 AM
Mike Wazowski's Avatar
Mike Wazowski
find a local tuner to tune the SS box.
send the ECU to technosquare or AAM for the reflash.
Honestly, you should look into a Utec though.
Old Apr 22, 2007 | 10:52 AM
Torched Z's Avatar
Torched Z
i was going to originally but i cant afford it now! I want to do this for this summer and then save up over winter to tobuy a utech!
now i just have to find a local tuner! Anyone know of one in illinois?
