Load Based (Dyno Dynamics) vs. Inertia Based (Most DynoJets)
Old May 2, 2007 | 10:14 AM
  #41
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by Sam@GTM
A good tuner can tune a car perfectly with and without a dyno (on the road),weather its a load dyno or inertia. the dyno is only a tool to accomplishes a job .it takes a lot more talent and experience to tune a car on inertia dyno verses tuning on a load dyno .both tuning method require road tuning afterward ,you can never duplicate road conditions ever on nether dynos,the load dyno will help inexperienced tuner to do a better job, on the other hand inexperienced tuner can get in trouble really fast on a inertia dyno if he releases the car with out road tuning. your self stated even on a load dyno raod tuning is required . so how can you make this silly statement .and if you are so not into guessing why are you not tuning with and f con and further more you are not using a head phones tuning a stock block to 18 PSI .this is exactly what I call guessing .
I just wish people will really think before they make such statement .I call it lack of experience .
I was using headphones BTW. The TurboXS Tuner Pro has a dedicated knock sensor which was installed next to the stock knock. But headphones only tell you so much.
My silly statement is based on fact. Lets take something that everyone can verify with no chance for confusion.
http://www.dynojet.com/automotive_dy...yno/index.aspx
This is DynoJets "NEW" Load Based Dyno.
So the manufacturer of your dyno is now making a load based dyno. This brings one of two options with a possible but similair third as to why they have done this.
1. They realize that an interia dyno is not the correct tool for tunning.
2. They have lost to many sales to Load Based dynos, which in turn points to the fact that the actual tuners in this country that have done their research find a load based dyno to be a much better tuning tool so they are buying load based dyno.
3. So many dyno purchasers are asking for load based dynos that DynoJet saw an opportunity in the marketplace. That still falls back into the catagory of #2.
Let me add a little more information. Here are some logs from a Turbonetics UTEC tune that was completed on the street. Following that are the logs from the UTEC once it was run on a DynoJet.
Note how the AFRs are SIGNIFICANTLY DIFFERENT and the Boost is also VERY LOW on the dyno pulls. The boost is not correct becasue we cannot "Load" the motor properly.
STREET LOGS
DynoJet Logs
4TH GEAR (note how short the run is compared to the street logs)
5TH Gear (Note boost and AFR's are still not correct compared to the street but length of the run is closer)
Let compare Apples to Apples
DynoDynamics 4TH Gear Dyno Pull
DynoDynamics 4TH Gear Street Pull
(Note Boost AND AFR's are very similiar. Also the Run length is similiar becasue I am able to control how fast the car accelerates on the Dyno.)
Ultimately it comes down to this, which we can all agree on.
The quality of the tune all comes down to the quality of the tuner and wether or not he knows how to use the tools he has. If "talent" is another word for a good guesser then you are correct. I don't have to guess as much on the DD thus I can make a more precise tune.
Old May 2, 2007 | 10:19 AM
  #42
DaveFunction2ND
Originally Posted by jpc350z
Dave,, could you please explain to me why when you worked at AAM and saw my car tuned (several times) on there DJ (by mike) where a street tune was not conducted you did not advise me to the fact that you believed street tuning was a absolute must. Thanks John C.
No problem. It was completely out of my control. Mike is the ONLY tuner at AAM. He will not allow ANYONE else to tune. I learned through reading, and testing my own cars. Mike does not feel confident street tuning and this is one of the many many reasons I left there. He will not show anyone what he does and he will not tune a car properly. That is why his cars blow up at even low HP levels.
  #43
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by Audible Mayhem
arent you tuning for power though?? i think you are confusing the customers with too much info. people have tuned thousands and thousands of cars on dynojets. the industry standard is the dynojet for a reason...
the best place to tune a car is on the street, hands down, thats the only way to replicate how a car is REALLY going to act....
+1
Old May 2, 2007 | 10:23 AM
  #44
DaveFunction2ND
awd dynojet with eddy current without a doubt
Are you kidding me? So your arguements all come down the the manufacturer? So you WOULD get a LOAD based dyno. Hmmmm...
Old May 2, 2007 | 10:36 AM
  #45
phunk's Avatar
phunk
CJ Motorsports
a load based dyno OBVIOUSLY assists in the tuning process. of course dynojet would release load dynos, its expected that they would update their products and add new features.
however, if you know how, you can easily tune on an inertia dyno. to tune on any dyno and not hit the street afterwords in not very effective. a load dyno will just reduce your time on the street.
as for "real" versus "fake" hp... in the united states the dynojet is the comparison standard. i dont really care if the dynojet is mathimatically correct with its calculations, i care that its not manipulated with operator controlled correction factors and its amazingly repeatable making it very easy to compare your setup to the next guys (and thats why most of us are here, cause we want to be faster then the next guy along with just enjoying our cars). if you want to compare apples to apples, you do a few pulls on one after your tuning on whatever dyno just so you can play the game. a dynojet at or near sea level is still the most fair and trustworthy comparison.
Old May 2, 2007 | 11:08 AM
  #46
Audible Mayhem's Avatar
Audible Mayhem
My350z
you are missing the point, i never once said that load based dynos arent better for tuning, i said, people can tune WOT and for power just fine with a dynojet.
you said its not possible that we are guessing??
gman asked if money is not an option , what would i buy??
if you made 563 on stock block you should trap high 120s all day. put up some numbers and then make another post. thats all we ask. you cant correct trap speeds...
do you always max out the injectors??
Old May 2, 2007 | 11:38 AM
  #47
sentry65's Avatar
sentry65
the burninator
just for reference, how long have Dave and the guys at Function Tuned been tuning cars?
I know Sam at GTM has been running GTM for something like 16 years. I'd guess he's been tuning at least that long at a minimum.
He told me they're planning on getting a dyno-dynamics in addition to their dynojet. They already have the hole cut into the concrete (see foreground in picture) and a 2nd garage door for it. The resources and scale of that place are staggering. I'm used to going to smaller shops with 2, maybe 3 lifts and a single dyno, and can maybe fit a total of 7 or 8 cars in their building at the absolute most with cars on top of each other up on and under the lifts
Attached Thumbnails Load Based (Dyno Dynamics) vs. Inertia Based (Most DynoJets)-car2.jpg
Old May 2, 2007 | 11:43 AM
  #48
DaveFunction2ND
I posted my data logs. There was a significant difference between the DynoJet and the street. The DynoDynamics shows little difference between logs on the street and the dyno. That means on the street all I am doing is refining and not making significant changes.
I don't trust the duty cycle on the UTEC. The fact that I was able to go to up to 18PSI and still run correct AFR's tells me that the UTEC is wrong.
Sorry, I'm not a drag racer so I will not be going to the track or posting up any time. The point of the exercise was showing what could be done with proper tuning and 18PSI on a STOCK BLOCK. Impressive by anyones standards DynoJet or DynoDynamics. Which we then promptly blew up on the street. So I guess that sits well with your position. But I've tuned on DynoJets, Mustangs, and DynoDynamics.
You still have not answered my question. Have you ever tuned on anything else?
Old May 2, 2007 | 11:54 AM
  #49
IIQuickSilverII
He told me they're planning on getting a dyno-dynamics in addition to their dynojet. They already have the hole cut into the concrete (see foreground in picture) and a 2nd garage door. The resources and scale of that place are staggering. I'm used to going to smaller shops with 2, maybe 3 lifts and single dyno, and can maybe fit a total of 7 or 8 cars in their building
well i agree with your post until you pulled the size of the shop... i mean... it should be the years of experience he has all you needed to point, the rest really doesn't mean its a better shop. You can see shops that big at some dealers shops, but it doesn't mean they are good.
In any case +1 on how many years has Dave been tunning?
Bottom line dyno jet is industry standard.. but i could care less which dyno they use as long as the tune is good
Old May 2, 2007 | 11:58 AM
  #50
sentry65's Avatar
sentry65
the burninator
I was just pointing out the scale of resources GTM has in addition to Sam's 16+ years of tuning experience. I know there's a lot of really great tuners on the forums and I'd never knock them. But even a lot of them have less than 3 or 4 years of professional tuning experience under their belt
I agree though, the quality and experience of the tuner is the most important part to getting a good tune
Old May 2, 2007 | 12:01 PM
  #51
Trav4011's Avatar
Trav4011
No disrespect.. but, a good tuner knows better than to risk the customer's car, or lives of others by tuning on the highway.. Sure, we all speed from time to time.. but, triple digit speeds on the highway, while you're trying to datalog, or pay attention to gauges.. listen for knock.. is very risky. We used to tune this way.. but, over the years, we realized how big of a risk we were taking, and stopped.
There's no reason that you can't perfectly tune a vehicle on a load based dyno.. You can simulate any condition that you would see on the highway with a load based dyno.
Old May 2, 2007 | 12:03 PM
  #52
Trav4011's Avatar
Trav4011
It doesn't matter if it's 2 years, or 20 years.. Maybe the guy that has been tuning for 20 years, has been doing it wrong for 20 years.. while the guy who has been tuning for 2 years, has learned the safe/proper way. Not saying that Sam is doing it wrong.. I'm just saying that years of experience doesn't really matter. You either know how to tune, or you don't..
Old May 2, 2007 | 12:04 PM
  #53
sentry65's Avatar
sentry65
the burninator
who said anything about doing triple digits on a highway?
When Sam and I were driving around, they were pretty much on back roads in the middle of nowhere or industrial zones where there was no traffic. At least when I was in the car driving, we didn't reach triple digits. A lot of the tuning was just seeing how the car responds to normal everyday driving as well as WOT.
Old May 2, 2007 | 12:05 PM
  #54
Gman2004's Avatar
Gman2004
I got the best of both worlds. Sam tuned my car on Sharif's heartbreaker DD.
Old May 2, 2007 | 12:07 PM
  #55
Gman2004's Avatar
Gman2004
When Sam was street tuning my car I took that biatch just a little bit past 130 MPH on I-75. Sam said I was a crazy ****.
Old May 2, 2007 | 12:11 PM
  #56
sentry65's Avatar
sentry65
the burninator
I agree.
But when you have a tuner that does know what they're doing, and has spent a really long long time doing it, they've picked up more things and have seen more over the years than someone that's also really good, but been tuning for 6 months and has tuned a total of maybe 100-200 cars
Old May 2, 2007 | 12:12 PM
  #57
Trav4011's Avatar
Trav4011
The point is.. tuning on the highway is dangerous. Call it what you will, but, I've seen several people hurt/killed in accidents where they were tuning on a high horsepower vehicle. So, why risk it? Would you feel comfortable with a tuner driving your car around on the highway, with his eyes glued to a laptop, trying to tune your car? Or, would you rather the car be on a dyno, with absolute control over everything, including conditions that you could simulate on the highway?
Old May 2, 2007 | 12:15 PM
  #58
sentry65's Avatar
sentry65
the burninator
see I knew this would turn into a road tuning vs load dyno tuning thread...
I dunno they both have their strengths. You don't have to do triple digit speeds on a highway though for road tuning. You can go WOT on a back road far from any other cars and pull over or stop on the road to look at the data and make tweaks, then do it over again. I didn't really have a problem with Sam driving my car around to log some data. Just driving around town normal can get you killed these days
Old May 2, 2007 | 12:17 PM
  #59
Motormouth's Avatar
Motormouth
I am all for the road tuning.
people die from breathing in the exhuast fumes or not properly tying down the car too...
Old May 2, 2007 | 12:25 PM
  #60
sentry65's Avatar
sentry65
the burninator
yeah I mean people have been hurt standing over the engine while it's being run hard on the dyno and then it blowing up and getting shrapnel in their head.
Obviously you can minimize risk on the dyno by keeping people away from the car just like you can minimize risk on the roads by not being a reckless driver in the middle of heavy traffic at triple digit speeds
Ideally we'd all have access to an oval track for the day to tune on.
The other thing is a lot of tuners just do standard cookie cutter tuning. Like installing a turbo kit and then tweaking the stock map that came with the kit. Doing a full out standalone tune from complete scratch - which ignore the factory's stock ECU parameters completely for WOT and non WOT situations, and dialing all those parameters in - not just A/F and timing, and doing all this on a highly modified big whp car with a completely different than stock engine is a totally different ball game than just tweaking A/F and timing and calling yourself a "tuner" simply because your shop owns a dyno and you tweak A/F and timing maps.
Monitoring all the information from sensors and knowing what to do with that info is a big time difference in ability compared to someone who doesn't mess with any of that stuff and just tune off the dyno charts and innaccurate A/F readings taken from the tailpipe instead of right after the exhaust manifold
