anything tricky on the turbonetics kit install?
Old May 9, 2007 | 09:43 PM
freezeg35's Avatar
freezeg35
Default anything tricky on the turbonetics kit install?
I already know about the ac line.
I recall a post about the fuel tank seal, and not getting gas on it or freezing it possibly, not too sure.
Anything else that i should tell my shop to watch out for.
Thanks in advance.
Freeze.
Old May 10, 2007 | 06:34 AM
MIAPLAYA's Avatar
MIAPLAYA
Tapping the pan. Do it carefully. Aside from that just protect your hands if you can with some gloves. A lot of stuff will cut you up under the car...
Old May 10, 2007 | 07:01 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Keeping the motor together afterwards....
I kid I kid....
Old May 10, 2007 | 07:10 AM
abyss's Avatar
abyss
I kid I kid....
Old May 10, 2007 | 07:12 AM
freezeg35's Avatar
freezeg35
Thanks, thats was done already with the vortech.
Do i need to get any exhaust gaskets?
Old May 10, 2007 | 07:16 AM
MIAPLAYA's Avatar
MIAPLAYA
No you should not..
Old May 10, 2007 | 08:28 AM
MUZZY's Avatar
MUZZY
Dont Drill The Bottom 2 Holes In The Fuel Pump Assembly... I Cant Emphesize This Enough!
Old May 10, 2007 | 01:25 PM
papiloco21's Avatar
papiloco21
you cant use enough heat wrap on the a/c line lol
Old May 10, 2007 | 02:59 PM
freezeg35's Avatar
freezeg35
I was reading the instructions and it said to drill 2 or 3 3/8 holes on the bottom of the fuel pump housing. Is this the one your talking about and if so why.
Thanks.
Old May 10, 2007 | 03:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Thanks.
Yes thats what he's talking about. The reason he said not to do it is that it eliminates the function of the surge can. While I have never had an issue with it phunk laid out a very detailed reason why not to. Search for it and you'll see it...
Old May 10, 2007 | 03:20 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Either way it doesnt matter, all too much if you dont run your car under a 1/4 tank of gas the surge function doesnt really affect anything.
I am not going to drill it because its one less thing I need to do. I have been researching this install and kit for over a year now, and am waiting on some final parts, I want to go with a dump off a 38 or 44mm tial wg w/ 9psi spring.
Old May 10, 2007 | 04:16 PM
blowncob's Avatar
blowncob
yes wrap the ac lines!!!....the dick who installed my kit did a horrible job and my ac went out...now my car is at the shop getting all 3 ac lines replaced, yes thats right, all 3!!! thats like 400 dollars just in parts! not to mention the 6 hours or so of labor to put them in so this job is costing me like $1000 bucks just to have my ac working again!!
Old May 10, 2007 | 05:15 PM
A-A-A's Avatar
A-A-A
Find really small hands to help you!!!!
Old May 10, 2007 | 05:20 PM
freezeg35's Avatar
freezeg35
Found it. Ill get them to modify the jet.
Thanks.
Car goes in monday, im stockpiling all this info for him.
Old May 10, 2007 | 06:17 PM
blowncob's Avatar
blowncob
and to top it off the guy who did my work is a ****ing scam artist!! MIA PLAYA, you know him, his name is ivan, or disturbed2483. he lives in palm dale, i payed him for his kit and for him to do the install and he didnt even finish the install!! he didnt finish the gauge install, there was stuff loose, and guess what, he still hasent fixed it!! he dissapered and said he moved to the other side of the country! finally a few weeks ago he gets in touch with me after 3 months and says he will pay for a shop to finish the install. he says hes going to mail me a money order...then bam, hes dissapered again!
Old May 10, 2007 | 06:18 PM
blowncob's Avatar
blowncob
so now the shop has racked up over a 1000 dollar tab to fix it and who is paying for it? me! because that mother ****er is trying to screw me and wont answer my calls or emails, after he said he was going to pay for it! if anyone knows where this ***** is at, let me know please!!!
Old May 10, 2007 | 06:34 PM
freezeg35's Avatar
freezeg35
Can we keep this on topic please.
Old May 11, 2007 | 06:49 AM
MIAPLAYA's Avatar
MIAPLAYA
[Threadjack]I don't know him per say. I've talked to him a few times when he had questions on the kit but thats about it. Sorry to hear about that dude. Hope you find him and get your money.[/Threadjack]
Old May 11, 2007 | 08:59 AM
bbs350z's Avatar
bbs350z
will an AAM oil pan spacer (w/ the pre drilled oil fittings, etc) work instead of tapping into the actual pan itself?
Old May 11, 2007 | 09:23 AM
MIAPLAYA's Avatar
MIAPLAYA
Technically yes but people have had issues with the pan spacer and having oil back up in the return line. I would stick with tapping the upper oil pan.
