greddy slow to spool
Old 05-16-2007, 12:57 PM
QuadCam
QuadCam's Avatar
on spring pressure alone, I was hitting full boost (5.x psi)by about 2500-2700 rpm on a 5th gear pull.
Old 05-16-2007, 01:13 PM
merlin3
merlin3's Avatar
ok little update and a question for those who are familiar with this piece of junk engine management known as emanage blue. Just had to run down the store real quick and it seems in like 4th gear it'll hit 5.4psi by like 3500rpm. Here's the problem though, the car seems slow to rev and won't really rev past 4k as it starts hesitating/bogging. The previous owner had it set up for 9-10psi and blew the motor. I turned the boost down to the low setting. Is the fuel map in the e-01 dependent on boost? Like does it use the same map for low and high boost? Also does it read off of the boost pressure sensor or is it just dependent on rpm? I'm wondering if the car is going really rich and bogging down.
Old 05-16-2007, 01:15 PM
JETPILOT
JETPILOT's Avatar
You didn't tune this after install? You're fuucking kidding me! No dyno run to establish A/F ratio? Hahahahaha!
JET
Old 05-16-2007, 01:20 PM
merlin3
merlin3's Avatar
it was supposed to be tuned before, thanks for the help though
Old 05-16-2007, 01:35 PM
JETPILOT
JETPILOT's Avatar
Of course your having problems. You're car isn't tuned.
JET
Old 05-16-2007, 01:54 PM
KPierson
KPierson's Avatar
The car made ~500whp on high boost on the tune it has. Obviously, the tune wasn't perfect (or he was just pushing the limits of a stock block), but it should still make boost, especially at min boost.
I would guess that the previous owner kept upping the boost without adding fuel, and that is why the motor went.
The big question now, does the Emanage blue tune on a MAP sensor or strictly RPM?
Old 05-16-2007, 01:59 PM
Gman2004
Gman2004's Avatar
I wouldn't drive the car in boost on the tune that blew the previous motor even though he turned down the boost.
Park that thing, install a new EMS, and get it retuned before you go ragging on it anymore. He is probably stalling/bogging because of how rich it is running because the boost has been lowered and it's getting to much fuel now.
Old 05-16-2007, 02:03 PM
TENGAI
TENGAI's Avatar
+1
Old 05-16-2007, 02:08 PM
Kenk2
Professional
Kenk2's Avatar
Yea ditch the EM Blue and get AT LEAST a UTEC... Quite a few vondors here sell them, including the one that has posted in this thread. I am sure he can hook you up.
I along with Quadcam run the UTEC and it works GREAT! I wouldn't use anything less than the UTEC.
Old 05-16-2007, 02:37 PM
DMK
DMK's Avatar
lol.
Old 05-16-2007, 02:47 PM
KPierson
KPierson's Avatar
Thats what I was thinking, but I'm not sure if the EM blue tunes off of boost or not.
Old 05-16-2007, 03:14 PM
merlin3
merlin3's Avatar
evidently no one knows the answer. Obviously I know that I need to get a new management like utec or I wouldn't have called the emanage junk. I'm just trying to learn how this thing works.
Old 05-16-2007, 04:52 PM
doug
doug's Avatar
evidently you didn't get the part about stop boosting on the emanage and get the car tuned
Old 05-16-2007, 07:28 PM
Alberto
Cranky FI Owner
Alberto's Avatar
Boom
Old 05-16-2007, 07:46 PM
westpak
SFZCC
westpak's Avatar
The emanage can be tuned off of boost if you connect the signal from the e01 to it or run a pressure sensor to it.
If the guy had it tuned to 9-10 psi that doesn't mean it was tuned at the 5 psi level, you really need to get this thing tuned, also did you hook it up to pull timing as well? not standard on basic kit.
Old 05-16-2007, 08:02 PM
merlin3
merlin3's Avatar
it has a j&s safeguard to pull timing but i know those things are worthless too. Going to try to purchase a wideband for it soon, and hopefully get a utec. It has a pressure sensor that goes to the e-01. I was just curious if the maps change when you change boost settings.
Old 05-16-2007, 08:04 PM
westpak
SFZCC
westpak's Avatar
No the maps do not change when you change boost settings, your only hope is that the map is tuned for that new boost setting.
Only way for the boost signal to get to the emanage is if it has a harness connected from the e01 box to the emanage
The J&S is good, I ran for over 2 years with the emanage and J&S at 9-10 psi.
Old 05-17-2007, 09:27 PM
  #38
IntenseFab
Intense Motorsports
IntenseFab's Avatar
Its kind of hard for someone to diagnose the problem without seeing your car in person. Before you jump to any conclusion, get it dyno'd locally, get a wideband in your car, and see what exactly your car is making, where... It will make it alot easier to determine if you do that.
Old 05-18-2007, 04:25 AM
  #39
QuadCam
QuadCam's Avatar
exactly,......just because the 9-10 psi values are good doens't mean the 5 psi values will also. WOT is the easy part of tuning; part throttle, low boost tuning is the key to a really good, smooth tune.
Old 05-18-2007, 04:26 AM
  #40
QuadCam
QuadCam's Avatar
I just went back and checked the spool up, and in 6th gear, I hit 5 psi, by about 2300-2400 rpm.
Quick Reply: greddy slow to spool
