Powdercoating the vortech mounting plate?
Old May 16, 2007 | 06:50 PM
moog's Avatar
moog
Default Powdercoating the vortech mounting plate?
Do you think this would throw off the clearances and alignment of anything? I already left Vortech a message and email to see what's up.
Old May 16, 2007 | 06:54 PM
THE TECH's Avatar
THE TECH
Nah. You should be fine.
Old May 16, 2007 | 08:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
That would look bad-*** although I cannot comment on clearances
Old May 16, 2007 | 08:49 PM
jran76's Avatar
jran76
It has been done multiple times with no reported issues. I know of at least 2 on here, there are just too many "Vortech" and powdercoat" threads to find any posts....
Old May 17, 2007 | 12:52 AM
Eazzy's Avatar
Eazzy
Its just common sense on re-assembly. Just to cover all the possibilitys, any place there is a metal to metal mount (Plate/Block, Plate/spacer, Plate/pulley mount) scrape or dremel or file the coating off.
Its not so much a clearence issue (Good Margin for Error here) but a down the road loosening issue.
In time the powder coat will break down at those points and open the possibility of a loose connection ( Like removing a shim and not compensating by tightening the bolt)
That goes for regular paint also. Or in Hi Tech/Precise situations---chrome
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
