APS TT Smoking, Oil Restrictors?
Old Jun 1, 2007 | 10:35 PM
Abishop's Avatar
Abishop
Default APS TT Smoking, Oil Restrictors?
Well guys, this is the only bug i need to work out on my APS TT setup. It smokes like crazy. I read a thread about people replacing the stock oil restrictors with smaller ones. Is this the fix? Boulder Nissan has checked the oil return lines for kinks and have trimmed them to size. What else can we do? Is the oil restrictors the only fix for my smoking problem?
It smokes heavy on decel. Light smoke all the time tho...
Also, i had boulder put in exactly 5.5 quarts, is that still to much oil?
Old Jun 1, 2007 | 11:28 PM
sbcbaseball's Avatar
sbcbaseball
I had the same problem. I had my lines trimmed and even placed just 5 quarts of oil and it still smoked. I later discovered it was a bad passenger side turbo. I dont know if you have true dual exhaust or not but in my case 1 side of the exhaust was the smoker. good luck.
Old Jun 1, 2007 | 11:36 PM
Crom's Avatar
Crom
Is it a new motor...? How many miles
Old Jun 2, 2007 | 05:43 AM
Abishop's Avatar
Abishop
It is not a new motor, it has 14,500 miles on it. I can tell its obviously the turbos making the smoke.
Old Jun 2, 2007 | 05:45 AM
Abishop's Avatar
Abishop
How did you go about getting a new turbo?
Old Jun 2, 2007 | 06:53 AM
failsafe306's Avatar
failsafe306
Did you buy the kit from an APS dealer?
Old Jun 2, 2007 | 06:54 AM
failsafe306
I had the smoking problem since day one, and GRD ended up sending both turbos back to APS for rebuilding.
Old Jun 2, 2007 | 10:09 AM
Zivman's Avatar
Zivman
the oil restrictors is not what you want to do.
smoking under acceleration?
under decel?
white smoke?
Blue/black smoke?
As SBC stated, run it where you can distinguish between each side.
Most likely it is a turbo and it will have to be pulled and be replaced/rebuilt
Old Jun 2, 2007 | 10:37 AM
Abishop's Avatar
Abishop
Yes, Z1 motorsports.
Old Jun 2, 2007 | 10:40 AM
Abishop's Avatar
Abishop
under decel?
white smoke?
Blue/black smoke?
Its white smoke. At start up it doesn't smoke. But at decel it really smokes. Im going to try to put 5 quarts in and see if it stops smoking. I think at 5.5 i still have too much oil...
Old Jun 2, 2007 | 10:44 AM
Abishop's Avatar
Abishop
Anybody have smoke when they put in 5.5 quarts?
Old Jun 2, 2007 | 10:54 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
you want your oil level to be right at the low line on the stick
Old Jun 2, 2007 | 11:10 AM
maximumsportZ's Avatar
maximumsportZ
Yup, L mark is your new full line.
Mine would only smoke if I ever overfilled it with lets say 6qts. 5.5qts and it never smoked again.
Old Jun 2, 2007 | 11:34 AM
Zivman's Avatar
Zivman
+1
Abishop you have PM
Old Jun 2, 2007 | 11:46 AM
Crom's Avatar
Crom
After 3k miles after the install it pretty much stopped for me. I doubt it was cause of my my catch can install, but who knows. Make sure your oil return lines are ok, and that angle is appropriate for gravity to do its work.
Old Jun 2, 2007 | 01:53 PM
sbcbaseball
I hope its not your turbo because its a pain in the **** to send it to aps. Not only did i have a about a month of down time, I also had to pay to uninstall and reinstall the turbo.
Old Jun 2, 2007 | 02:37 PM
failsafe306
Don't forget shipping! $300 for air freight.
Old Jun 2, 2007 | 03:38 PM
Abishop's Avatar
Abishop
ha ha well you guys are making me feel great about this! Not!
Old Jun 2, 2007 | 08:23 PM
Abishop's Avatar
Abishop
Ok guys. i put in exactly 5 quarts. Still smoking under decel. It wont smoke under acceleration. It will smoke for awhile at idle then go away as it sits and idles. I have really no idea what is going on. How do you know if you have a bad turbo(s)?????? Please Help Me!!!! Smoke is mostly white with a hint of blue.....
Also, around how much is a turbo rebuild under APS Warranty really going to cost me??
Old Jun 2, 2007 | 09:12 PM
Glex25's Avatar
Glex25
Wouldn't smoking under acceleration signify a bad turbo?
Sounds more like a return line issue
Did your motor consume oil before the TT install?
What are your other supporting mods?
