Vortech Fuel problems....
Old Jun 4, 2007 | 07:27 AM
jpc350z's Avatar
jpc350z
Low boost is what level..? Have you tried to tune a Vortech with only a Walbro and larger inj's..?
G Thizzle's Avatar
G Thizzle
Sharif... so you are saying that i cant run the walbro with stock injectors and ditching the Vortech FMU like Muzzy said?
Old Jun 4, 2007 | 08:13 AM
MUZZY's Avatar
MUZZY
My info: "you can run stock injectors with the walboro 255" BUT!!!!!!!!!!!
"You will need a tune if you are using the SS box"
take out everything vortech gives you for the fuel setup. install the walboro 255. do not drill holes in the assembly. drill holes in the fuel regulator. remove the yellow siphone on the bottom assembly. tune the SS box/utech with the setup.
if you run the stock SS program with the walborro pump it will not work and you will have the problems you say you are having.
can I make it more clear? tell me how. Help me help you.
this is all for the 7psi setup only b/c the 9psi setup is diferent
Old Jun 4, 2007 | 08:55 AM
priscilla ls1's Avatar
priscilla ls1
He does not have the ss box Muzzy he has the utec. This is starting to make more sence maybe you should get the 440's like D has. I am sure there is a way for it to work but if you just upgrade the injectors you wont have to replace your fuel canister assembly you drilled.
Old Jun 4, 2007 | 08:59 AM
Mr_pharmD's Avatar
Mr_pharmD
i believe u have 2 options.
1) take out the fmu and just run bigger injectors like 440cc with the walbro pump and try to see if the utec can lean out the fuel at idle. - bad gas milleage with this option.
2) get new pump canister assembly and install stock pump and get the aux pump to connect with the fmu and stock injectors. - i have my used aux pump if u need it (60 shipped).
Old Jun 4, 2007 | 09:12 AM
jpc350z's Avatar
jpc350z
1. Vortech has no 7psi set up . The stock pulley 3.33 is an 8psi boost.
2. If you have ditched the FMU and have the utec with a walbro and stock injectors then a return fuel system is a must for safety. (AAM has a system that uses the stock fuel rails) for about $500.0.
3 A tune.
Old Jun 4, 2007 | 09:25 AM
priscilla ls1
3 A tune.
This is also a good option, fuel return or 440cc injectors. He has the modifid fuel canister so that should only nerrow down his options to larger injectors.
Old Jun 4, 2007 | 09:40 AM
MUZZY's Avatar
MUZZY
3 A tune.
1. you are wrong. link:http://www.*********.com/zwiki?title...&printable=yes
2.you dont need a return fuel setup with only a 7psi setup. maybe just bigger injectors
3. agreed. defenetly need a tune
cant link to it its on wiki. copy and paste
Manufacturer Vortech
List Price $5,895.95
Found Price $4,900 (+$370 polished)
Application 2003-2006 350Z VQ35DE, 2005-2006 VQ35DE Rev Up
Base PSI 7psi
Base Power 340hp
Base Torque
Compressor Vortech V2
Intercooler Front mount, full width
Piping
Fuel OEM injectors, Vortech FMU, Walbro 155 inline pump
EMU Split Second Timing Box
Air Filter K&N
Blow Off Valve Vortech Bypass Valve
Old Jun 4, 2007 | 09:43 AM
jpc350z's Avatar
jpc350z
Not convinced larger inj's will be all he'll need. I have the walbro and 440inj's and the FMU/Aux fuel pump and had it tuned with a 11/12 A/F ratio all accross the RPM..W/O the FMU and Aux fuel system I don't think I'd be at 11/12...A fuel return would eleminate the Vortech fuel system as well as adding a significant increase in reliability by eleminating all the extra fuel lines and components..
Old Jun 4, 2007 | 09:51 AM
G Thizzle's Avatar
G Thizzle
I want to try what muzzy said and just ditch the FMU and just run the 255 straight into the fuel rail like stock... but we did drill the holes in the bottom of the fuel assembly so what i will that affect?
Anyone know where i can get a whole new fuel assembly?
Old Jun 4, 2007 | 09:53 AM
jpc350z's Avatar
jpc350z
Base PSI 7psi
Base Power 340hp
Base Torque
Piping
Air Filter K&N
Muzzy, cut and paste doesn't work. However I called Vortech and they said the V2SQ S/C on a stock 350Z or G is an 8psi boost system..That's what mine reached w/ the 3.33 and now 9 psi w/ 3.12 pulley..They no nothing about a 7 psi system...
Old Jun 4, 2007 | 09:59 AM
G Thizzle's Avatar
G Thizzle
JC... so what do you suggest? Going with bigger injectors or fuel return? Keep in mind my assmebly has those 2 holes drilled in the bottom...
Also... why is my exhaust blowing cool air on the drivers side and hot air on the pass side????
Thanks in advance for all the help fellas...
Old Jun 4, 2007 | 10:22 AM
jpc350z's Avatar
jpc350z
Personally I would go with the return system. Safer and eleminates the crappy Vortech fuel system..
Stock injectors will have you at a high inj pulse rate..The experts say stay below 80%.. Larger ones like 440 will certainly accomplish this.
As for the exhaust temp delta what is your exhaust system. Sounds like you have an obstruction or killed your catalytic converter. Is the flow rate between the tips the same? Puzzling
Old Jun 4, 2007 | 10:31 AM
priscilla ls1
We did kill the cats and replaced them with test pipes. Still running cool on the drivers side.
Old Jun 4, 2007 | 10:38 AM
G Thizzle's Avatar
G Thizzle
Even with the holes drilled in the bottom of the assembly?
Injen SES true dual... the cats were replaced with test pipes... but it is sputtering on the driver side and blowing cool air....
Old Jun 4, 2007 | 10:45 AM
jpc350z's Avatar
jpc350z
Send a PM to "phunk" he's a member and very knowledgable and can answer the question about the holes.
The exhaust question is puzzling. Is the flow rate about the same?? No obvious leaks?
Old Jun 4, 2007 | 10:52 AM
MUZZY's Avatar
MUZZY
the only thing negetive about hte fuel return system with the 2 holes in the bottom of the feul pump assembly is that you have to be above 1/4 tank if not the fuel drains out of the pump assembly and the pump those not get enough fuel. I know this because this is my problem right now. I have to pump gas every 3 days
Old Jun 4, 2007 | 10:55 AM
  #38
priscilla ls1
Thats what I was thinking so maybe he should just go with larger injectors for now, and get the fuel return and a new fuel assembly later.
Old Jun 4, 2007 | 10:56 AM
  #39
G Thizzle's Avatar
G Thizzle
No leaks... flow rate is about the same... just hot and cold... one is sputtering and the other is fine... it is very weird...
I am trying to find a new fuel assembly but to no avail...
Old Jun 4, 2007 | 10:59 AM
  #40
MUZZY's Avatar
MUZZY
not trying to get into a **** fight here but if you look at any vortech spec for the 350z on this website or the ********* website or any vendors website is says 7psi
you could have sean 8psi if you have a higher rev limit than stock. this is possible.
but think about it. why would vortech sell an upgraded pully just for 1 psi?
im running the 9 psi pully but I hit 9,5psi @ 7100 rpm instead of the regular 6800 or 6500 rpm
