Poor cylinder compression on new built motor - what to do?
Hot damn - there she is
Sam called - no news to report as of yet - but was assured it was not a timing issue, not a turbo issue, not a backpressure issue. I just have to sit on my hands and wait patiently... couple more days I hope?
While she's there, Sam said there were a number of 'loose ends' that needed to be tied up on the car: not that I half-assed anything, but I was in a rush to get out there, so things such as unsecured wiring, my ext. WG knocking on the floorboard, etc. will be resolved while she's there.
from your pics and psoted pics on the local forums iknow you dont half-*** your work... so its funny that you actually did it but understandable for being in a rush.... keep us all in the loop man to whats going on...
Definitely keep us posted on the progress and subsiquent diagnosis.
Originally Posted by TENGAI
Something I just thought about... What spring pressure are you running off of the tial wastegate? Also, did you weld cap the internal wastegate port and cut off the flap? Still thinking about this mysterious boost leak... If Sam says the turbo (and the rest of the kit is fine), then my only guess would be the boost sol. on the controller...
Definitely keep us posted on the progress and subsiquent diagnosis.The Tial 38mm WG is using a blue spring - I thought it was a 1 bar spring but Sam was able to turn the BC down to 10 psi and that car was holding at that pressure, so I couldn't tell you for certain now
The BC appears to be in working condition, as you can turn the boost up to 16+ psi and it will hold there all day long. Loud, but functional
Originally Posted by failsafe306
Make sure that crappy flexible plastic intake tube isn't collapsing under boost.
Just throwing out ideas here...
Originally Posted by Infinus
Hey, i've been following along, any updates as to what is wrong?
I have been in contact with Sam and Don, nothing conclusive s of yet- but the issue is a valve/valves not sealing in cylinder #1, as to why, we'll know soon...bent valve?, freak machining error? burnt valve?...also maybe a poor ring seating in cylinder #1 compunding the problem...
from what Sam told me, it has been narrowed down to a mechanical engine issue, as to why, unknown at this time.
I'm curious to know as well for obvious reasons.
TODD
The engine is being torn down at GTM and inspected/spec'd, so hopefully more answers will emerge by week's end...
Keep me updated... unfortunately, I'm betting it is a bent valve, per the assumption that it could be a machining error of the valve job here on our end, I just went through and checked 3 sets of heads that I have on the shelf, all valve clearances are within 1 thousandth of ideal and all valve seat surfaces are pristine, further, I had them all vacuum tested, all perfect, so I really do want to get to the bottom of your issues (as I'm sure you do as well)
good luck
TODD
Originally Posted by Mr_pharmD
I'm sorry to hear that Joe. Is the short block still saveable?
hopefully when Sam pulls the engine and takes off a cylinder head, he can conclusively figure out why the valve isnt sealing- a good little check is to shine a flashlight through intake port/exhaust port..dim the lights, and see if you can see any light coming through the valve sealing surface, inspecting the valve is sometimes difficult to see a minor bend (like if it kissed a piston over-revving--ex: going from 5th gear and downshifting to 2nd gear-mechanically over-revs an engine- valve spring can't pull the valve closed quick enough and the interference motor interferes
)if the valve stem is bent, spinning the valve on a lathe will show this...
again, Joe, keep me posted, as I told you in a pm, if this issue is due to our error, we will take care of it or you.
-TODD
Originally Posted by Motormouth
'we will take care of it OR YOU'? is that a threat?
hahahaha..we'll give out a lethal dose of some pharmaceuticals
joking, we will of course take care of IT....
like the 350z mafia
lol
right on!... stuff does happen... its about someone supporting their work in the end what matters... this is great to see.
updates?.... kinda worried something still isnt right in here...
No addt'l information as of yet, I have a call out to GTM so we'll see...
I have yet to see that movie
