Need Help! APS ST
Old Jun 12, 2007 | 07:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It took nearly 45 minutes of driving to finally get a check engine light, and the limp mode/bad hesitation. It is a crank position code error. As I mentioned to Faraz over the phone, we're going to check the crank position connector, and test the wiring tomorrow.
Old Jun 13, 2007 | 06:24 AM
original786's Avatar
original786
thanks sharif, look fwd hearing from you!!
Old Jun 13, 2007 | 02:44 PM
Sharif@Forged
Forged Performance
The APS supplied crank position connector had some bent pins, and everything was corroded on the inside. The crank sensor also had some pretty strong corrosion as well. We replaced the connector, and the sensor, and the problem seems to be solved. One of our technicians will drive the car around tonight, just to make sure. Glad it was an easy fix.
Old Jun 13, 2007 | 06:34 PM
TENGAI's Avatar
TENGAI
Sweet. Great work Sharif
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
ZZZ-35
Dec 30, 2004 05:56 PM
ZZZ-35
Australia/New Zealand
31
Aug 31, 2004 02:53 AM
