Vortech finished, possible boost leak. Help!
Old Jun 28, 2007 | 08:02 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What type of dyno was used?
Old Jun 28, 2007 | 08:06 AM
MUZZY's Avatar
MUZZY
could be 2 things
1-adjust your dump valve, do you hear it close? unlike BOV ours kinda works diferently, its open all the time then closes for boost.
2-belt slippag, tighten belt
Old Jun 28, 2007 | 08:23 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Originally Posted by zzerotwosixty
8psi is good with test pipes. Are you using the Vortech cone air filter? It's a big restriction, I'm changing mine next week.
what are you changing it to, it doesnt seem like there is alot of room for a different filter
Old Jun 28, 2007 | 08:34 PM
Nexx's Avatar
Nexx
dynojet. i was having some belt slip issues until it was tightened a bit.
Old Jun 28, 2007 | 08:36 PM
Nexx's Avatar
Nexx
+1, saw pic of a larger one that was more cylinder shaped and it extended through the intake hole behind the top portion of the front bumper.
Old Jun 29, 2007 | 08:29 AM
zzerotwosixty's Avatar
zzerotwosixty
Nexx your pm box is full. I'm going to use the HKS Super Mega Flow Reloaded. Long name huh. It'll be above the IC and require some piping.
Old Jun 29, 2007 | 08:56 AM
Blackbird CPV35
well i guess that makes me SOL bc the G Coupe doesnt have that hole in front of the filter. Just AC hardlines
Old Jun 29, 2007 | 02:22 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck i hope you get your problem solved so you can enjoy the kit.
Old Jun 29, 2007 | 06:47 PM
zzerotwosixty
I don't know how much room you have in the G. I was going to put the filter directly on the Vortech, I think it would fit but I'd have to pull the radiator to get it in. I decided it would be easier to pull the bumper cover and pipe it in. Better air anyway.
Old Jun 30, 2007 | 02:27 PM
zzerotwosixty
Had to take out the bumper. Wasn't planning to bump into anything anyway.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
