think My Motor's done
Old Jun 25, 2007 | 12:31 PM
taurran's Avatar
taurran
So did he give you any good reason other than it wouldnt turn over?
Sorry, but that wouldn't be a good enough reason for me to believe a built motor was blown. Sounds more like an electrical, ecu, ignition, or fuel problem to me.
Don't just take his word on it. Find out what the root cause is before you do anything drastic.
Old Jun 25, 2007 | 12:34 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Cannysage
he said the motor won't even turn and completely ceased.
[sp]siezed[/sp]
if thats the case i think the motor is toast indeed.
Old Jun 25, 2007 | 12:42 PM
taurran's Avatar
taurran
Originally Posted by MIAPLAYA
[sp]siezed[/sp]
True, guess I missed that statement. I'd take it to a Z specific shop like GTM before I made any decisions as well...
Old Jun 25, 2007 | 01:02 PM
Cannysage's Avatar
Cannysage
Sam gave me a little hope over the phone. it'll be towed over to GTM, sometime today and he'll give me a correct diagnose (however you spell it).
Old Jun 25, 2007 | 01:04 PM
doug's Avatar
doug
its ok.. we know what you mean.. hope everything works out for the best man.. hopefully its a dead starter or something electrical
Old Jun 25, 2007 | 05:33 PM
Weqster's Avatar
Weqster
GL dude, let us know how it turns out.
Old Jun 25, 2007 | 06:12 PM
Crom's Avatar
Crom
I saw your ride at corner 3 today....steve mentioned that the motor is in question...flatbedding is a little expensive - good luck w/ everything....let me know if you need a ride out to GTM...was planning on going there next week.
Old Jun 25, 2007 | 06:30 PM
diwun67's Avatar
diwun67
Did you check the oil prior to being told the motor was siezed? Do you remember if it ever overheated?
Old Jun 25, 2007 | 07:39 PM
Cannysage's Avatar
Cannysage
it should be in gtm by now
thanks bro
yes, I actually put a quart in, before I started driving. No over heating, no smoke or clicking noises, nothing..
Old Jun 26, 2007 | 03:59 PM
chichi506's Avatar
chichi506
actually after marin had the car, it was sold to a guy named val that i bought it from, He only had the car for about 3 weeks before it was sold to me and i later sold it to cannysage. that sucks man, i feel your pain, i dumped nearly 6k into that car when i first had it to get it running right. new fuel system, injectors, tuning, custom overflow...but in the end i had to sell. I really hope everything works out for you. if you need any information on the car, i can give you some phone numbers so that you can get things squared out. take care.
Old Jun 26, 2007 | 04:01 PM
doug's Avatar
doug
4 owners in about 2 months.. yeah.. definately somethings up with that car
Old Jun 26, 2007 | 04:06 PM
taurran's Avatar
taurran
This is the same car that supposedly made 700whp on the APS TT kit and a JWT clutch/flywheel setup? Something never seemed quite right about that to me.
Old Jul 3, 2007 | 06:52 AM
Jason333's Avatar
Jason333
hi
Any new info?
Old Jul 3, 2007 | 08:01 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Well if you need a stock engine, let me know?
https://my350z.com/forum/showthread.php?t=281303
Old Jul 4, 2007 | 11:32 AM
Cannysage's Avatar
Cannysage
it's at GTM, and I guess it's the timing chain. sam did a compression test and it was low on couple of the cylinders. He says compression would be back to normal if I were to get the timing chain fixed. but he wants to take the engine apart and make sure there are no other damages, which makes sense. This will take a lot of money and I need couple of days to figure out what I'm going to do.
Old Jul 4, 2007 | 11:38 AM
failsafe306's Avatar
failsafe306
I'd have them fix the timing chain and see how it runs from there. No point in spending another couple grand rebuilding your motor at this point if it's not absolutely necessary.
So I'm guessing the chain broke, or what?
Old Jul 4, 2007 | 11:42 AM
captj3's Avatar
captj3
This is not the first time I have heard of this happening. I know a car that one of the guides for the timing chain break. Everyone thought the motor was toast. In the end the chain and the guides were replaced. Now the motor is running fine at 505 rwhp. Good luck with the motor.
Old Jul 4, 2007 | 12:23 PM
  #38
Cannysage's Avatar
Cannysage
yeah it broke. motor seemed fine to me,when the problem occurred - no smoke, knocking, overheating or anything.
hmm sound reassuring.
Old Jul 4, 2007 | 03:51 PM
  #39
VIZAGE's Avatar
VIZAGE
Defiantly get the chain fixed. Then check compression again. Then go from there.
Old Jul 4, 2007 | 04:03 PM
  #40
doug's Avatar
doug
those prior owners must have put some major abuse on that motor... timing chains are usually indescrtuable and will last the car's whole lifetime... which is why nissan switched to timing chains as oppose to timing belts
