Cooling Mods
Old Jul 30, 2007 | 05:15 PM
taurran's Avatar
taurran
Will those fans only fit with that AMS radiator, or are they universal? I'd like to look into something like that...
Old Jul 30, 2007 | 05:16 PM
iStan's Avatar
iStan
ZR
They are universal. I went with them because they are thinner than stock. With the AMS radiator and Vortech, I ran into problems with space.
Old Jul 30, 2007 | 05:18 PM
taurran's Avatar
taurran
Yeah, I am having to go with the thinner Koyo radiator due to fitment issues with the turbonetics kit. I'm wondering if it would have been a better use of money to just go with that and the thicker one... hmm...
Old Jul 30, 2007 | 05:21 PM
iStan's Avatar
iStan
ZR
The AMS is about 50mm or so. With the FAL and the AMS, I was still able to clear everything with the Vortech. I'm pretty sure this setup is actually thinner than the stock rad and fan setup. I'll try to take some measurements.
Old Jul 30, 2007 | 06:44 PM
i8acobra's Avatar
i8acobra
Anyone planning on the AMS, be advised, it's not plug-n-play. You will need to be mechanically inclined to install it. The thin Koyo, on the other hand, is p-n-p.
Old Aug 2, 2007 | 11:13 PM
iStan's Avatar
iStan
ZR
We're finishing the car tomorrow night!! Woo! I haven't really driven my car in 3 weeks
Old Aug 3, 2007 | 06:24 AM
taurran's Avatar
taurran
haha... 10 or so here... good luck
Old Aug 3, 2007 | 06:29 AM
booger's Avatar
booger
Stan...did you ever figure out the wires for the fans ????
Old Aug 3, 2007 | 07:05 AM
iStan's Avatar
iStan
ZR
Taurran, that's rough.
Booger, we have an idea. We'll try it tonight and see what the results are. I'll update this and the guy who is doing the wiring (i8acobra) will probably start another thread on the topic. We'll let you know asap.
Old Aug 4, 2007 | 05:29 PM
i8acobra's Avatar
i8acobra
Here's some preliminary wiring info, I'll make a diagram later (my hands are still dirty right now).
On aftermarket fan 1, the power wire should be connected to the blue wire on connector 1 and the red/white wire on connector 2. The ground wire from this fan should be connected to the black wire and the yellow/red wire on connector 2.
On aftermarket fan 2, the power wire should be connected to the black/yellow wire on connector 1 and the white wire on connector 2. The ground wire from this fan should be connected to the black wire and the yellow wire on connector 1.
This wiring has both fans coming on when the ECU determines the temp is high and/or when the A/C is turned on. There is only one speed.
Old Aug 5, 2007 | 03:15 AM
iStan's Avatar
iStan
ZR
We'll have the wiring diagram up hopefully tomorrow.
Link to all pics:
http://picasaweb.google.com/istan350...ey=EqvPZmfXM00
Spacing between Vortech, AMS, and FAL Fans
Powersteering
Oil Cooler
Oil Cooler again
Tranny Cooler (removed windshield wiper resevoir)
Tranny Cooler reinforment bracket
Old Aug 5, 2007 | 03:21 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I hope so. It's already 110+ here
That's it? Try 140+, that's hot.
Old Aug 5, 2007 | 03:46 AM
iStan's Avatar
iStan
ZR
^ Arg, I'm debating whether I should go out to the desert and work or not
Old Aug 5, 2007 | 03:48 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I was here for less pay with the USAF so I'm not bitching as much now I'm here as a contractor. However it is freaking hot!!!
Old Jan 22, 2008 | 11:10 PM
iStan's Avatar
iStan
ZR
My new mesh covering of the reflector area
Old Jan 23, 2008 | 06:10 AM
C Ray Z's Avatar
C Ray Z
Default How about the diff?
I don't see those temperatures but I am planning to add a diff cooling for track. I had to replace my rear gear and pinion plus I find the synthic oil after a 102 degree day is cooked.
Old Jan 23, 2008 | 07:09 AM
iStan's Avatar
iStan
ZR
^I'm hearing good things about the Nismo Finned diff Cover. I have mine still laying around, never got around to installing it.
Old Jan 23, 2008 | 07:27 AM
  #38
C Ray Z's Avatar
C Ray Z
I already have that and it was still not enough. I am running a 3.9 rear gear and Nismo LSD set at 66%
Old Jan 23, 2008 | 07:54 AM
  #39
iStan's Avatar
iStan
ZR
Hmm, I remember reading a thread about someone wanting to add an auxilary cooler and a pump to circulate fluid from the diff to the cooler. I'll look around and see if I can find it.
Old Jan 23, 2008 | 07:56 AM
  #40
z350boy's Avatar
z350boy
Well, it's a little too hot for comfort in Vegas. So I just ordered all my cooling mods:
Ams Thin Radiator
https://my350z.com/forum/showthread....&highlight=ams
Thin Fan
http://store.summitracing.com/partde...?part=FLX-220B
Power Steering Cooler
http://store.summitracing.com/partde...5&autoview=sku
Tranny Cooler
http://store.summitracing.com/partde...0&autoview=sku
Oil Cooler
Mocal Oil Sandwhich Adapter SP1FT
http://www.racerpartswholesale.com/mocal.htm
Replaced broken Mocal Oil sanwich adapter with Permacool
Nismo Thermostat (Arrived) -Zcarbandit
Nissan Finned Differential Cover (Arrived) -West Covina Nissan
JMatic Tranny Fluid (Arrived) -West Covina Nissan
Motul Synthetic Diff Fluid (Arrived) -West Covina Nissan
Pathfinder Oil Filter and Crush Washer (Arrived) -West Covina Nissan
Samco Hoses (Arrived) - JSAParts
Install in two weeks. I'll have plenty of pics up. Any other recommendations?
Thanks to i8acobra, terrasmak, and booger.
I bought the Mocal Oil Sandwhich Adapter SP1FT, so I am curious what happened that caused you to replace it with the Permacool version???
