Forge actuator spring rates
Old Jul 30, 2007 | 03:57 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default Forge actuator spring rates
This is what I found out from the search:
Red: 16~20psi
Yellow: 11~15psi
Green: 5~10psi
What's blue spring rated for? I think it's in between the red and the yellow.
Also, which spring should I use for my setup?
APS TT+GTM built engine+GTM turbo cam+3.5" APS TP+3" Evo TT
exhaust+HKS evc boost controller+water&methanol injection.
I'm shooting for 15~17psi 600whp on 91 octane pumped gas with water&methanol injection.
I know Zivman is running the red springs for ~16psi, but he has 2.5" exhausts.
Since my exhaust will be more free flowing, should I be running one step lower? Would that be the blue spring?
Thanks in advance guys.
Old Jul 30, 2007 | 04:16 AM
BrianLG35C's Avatar
BrianLG35C
My tuner is suggesting the blue spring but I'm not sure of it's spring rate. I'm running the EVO TT exhaust with 2.5" TPs.
Old Jul 30, 2007 | 04:23 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
what i have learned is that you can make less boost than the springs if you want but you cant make more than they are rated. i would go with the red springs but you will be limited to around 10-11 for low boost...
DONT go to low or you will regret it cause its a lot of work to change them..
i would say red
Old Jul 30, 2007 | 06:33 AM
rcdash's Avatar
rcdash
i would say red
^ isn't that reversed? With a boost controller, you can set the boost as high as you want but you cannot lower it below the base for the spring. I mean the controller will switch between connecting the wastegate port to the intake port, or connecting the wastegate port to the atmosphere port (as long as this is the case boost will continue to build), right?
Old Jul 30, 2007 | 06:46 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
as Jeremy said, go with the Red, I have swapped springs several times!!!
My setup:
APS tt
3.5L
3" true dual exhaust
3.5" downpipes
blitz sbc-id boost controller
with bc off: 10-11psi
low boost: (set 35): 14.5psi
high boost (set 70): 18psi
yellow will not allow you to go much higher than 16.5, maxed out, the red will give you more room to work with
TODD
Old Jul 30, 2007 | 07:38 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
i would say red
This is why I want to make sure I put in the correct spring for my setup before the installation begins. I'm overseas, so I have no expert tuner to advise me on this matter...
So what's the blue spring rated for?? Nobody knows??
Old Jul 30, 2007 | 07:46 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
My setup:
APS tt
3.5L
3.5" downpipes
TODD
Wow! You only get 10~11psi with boost controller off with the red spring?? I thought Zivman was getting like 13psi with BC off... Too many contradicting stories... This is what I'm concerned with the most... I want to be able to lower the boost to 13~14psi with the red spring, but I'm not sure if that's possible.
Old Jul 30, 2007 | 07:48 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
What's your WHP, psi goal?
Old Jul 30, 2007 | 07:52 AM
BrianLG35C's Avatar
BrianLG35C
I understand the blue is rated somewhere between the red and yellow. I'm hoping for 525-550whp.
Old Jul 30, 2007 | 07:59 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thanks for sharing...boost looks about right for those springs. For those interested, just keep in mind, that you should downsize one spring, if you wanna run these pressures with the 3.5 inch test pipes, and 3 inch true dual. If you can this spring with the 3.5/3 setup, you will see close to 18psi or so.
This is what Sharif said on the other thead... I'm confused...
Old Jul 30, 2007 | 09:41 AM
Zivman's Avatar
Zivman
I ran the red springs with the 3.5" pipes into the 2.5" exhaust. I was consistantly pulling almost exactly 14 psi with my EBC off (EVC 5). I set the actuators with 1/2 hole preload. Set to 24 on the EBC, I was seeing about 16.5-17 psi and at 30 on the EBC, I was seeing about 17.5 psi.
Old Jul 30, 2007 | 10:21 AM
tig488's Avatar
tig488
if you look on the end of the box i shipped them to you in, they are written down on there, the spring rates.
Old Jul 30, 2007 | 01:37 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
ohhh.. +1 on the red springs .. just get em in and you wont have to change again.
Old Jul 30, 2007 | 01:41 PM
Audible Mayhem
My350z
yes but if you hook the boost line up straight to the ports on the actuator with no boost controller, you will make the least amount of boost possible.
internal and external wastegates are exactly backwards of each other when it comes to boosting and boost controllers...
Old Jul 30, 2007 | 02:56 PM
maximumsportZ's Avatar
maximumsportZ
i would say red
+1... too bad we had to learn the hard way..
Old Jul 30, 2007 | 03:29 PM
tig488's Avatar
tig488
iirc the blues are 19-25psi.
go with red, if you go with blue, youre gonna be overshooting your goals, you can always use a controller to go higher, but you cant go below the spring pressure.
Old Jul 30, 2007 | 04:52 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thanks guys, I didn't look at the box.. Thanks for the info!
$h!t~ blue's rated higher?? Good to know.. Red it is..
Now I just need to find/order an extra red spring... Anybody want to donate a spare red spring? I'll put you down as my sponsor! LOL I just might have to ask Sam@GTM when I order the GTM turbo cams..
Old Jul 30, 2007 | 05:31 PM
BrianLG35C's Avatar
BrianLG35C
Now I'm confused, I understood from Zivman the red ones are rated higher than the blue.
Old 05-12-2007, 05:46 PM #5
Zivman
[Quote=Zivman]
So you feel the red springs are best for the APS TT application?
I would say at least get the blue springs. and if you are comfortabel with 13+ as the lowest amount of boost, go for the red ones. IMHO, over 13 lbs on spring pressure is a bit much.
Brian, you will also be running a slightly bigger exhaust with the EVOTT - I don't know if it flows better than the aps 2.5", but I would think it would. That being said, you might be better off with the blue ones. Talk to Tuan and see what he thinks
__________________
Old Jul 30, 2007 | 06:17 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The reason this is confusing, is becuase internal wastegates are dependant on the amount of preload you put on the arm, and they are very sensitive to backpressure. So bigger exhausts and downpipes will make more boost. Bench testing is the only way to know for sure. I have seen yellow springs push 16psi easily with a boost controller (about 8psi WG only), but other customers have reported that they can't get more than 13psi...even with a boost controller.
With a built motor, it definately comes down to red or yellow. Blue is going to make 20psi plus...that's a nasty spring.
Old Jul 30, 2007 | 06:18 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I hear you.. Forge actuator website doesn't have any info... I'm gonna checkout the box as Tig mentioned when I get off work... (it's 11:17am in South Korea)..
