debating : Utec Vs. E-manage
If that is the JUN AWD Z I thought they used the VPRO....
As for the OP, I ran the Emanage Ultimate for a while but kept having to replace coil packs. A friend blew his motor because the EU took a dump and the stock ECU took over leading to an extremely LEAN condition = boom. Also had another friend w/ the EU and Vortech SC run into problems w/ his coil packs.
The UTEC is your best bang for your buck. The VPRO is the shiznit especially if you are gonna go for high HP numbers. I currently run the F-Con IS and love it. Close to same features as the V-Pro, HKS CAMP feature w/ the right sensors, uses same harness as VPRO so if I upgrade then it's one less thing I have to change, knock on wood, it has been great for me. May be biased but it may be one the best piggy back systems available. Car idles like stock and drives like stock until you get on it obviously. I'm no expert so these are just my experiences.
Originally Posted by MethodRN
Oh, also forgot to mention that if you're a true baller then go w/ the MOTEC!
Originally Posted by rcdash
Any inside scoop on whether it works with the 5AT. I heard the hydra standalone was having trouble with the 5AT... so wondering...
Is this the same as the e11v2 unit on the Haltech website? Does the stock ECU still control some aspects (DBW, amenities, TCM on the 5AT, etc?)
thanks!
thanks!
It is not the same as the e11v2; the Platinum series is an entirely new platform of ecu from the ground up and the same goes for the new Haltech ECU Manager software.
Originally Posted by Hal@IP
Am I missing something... Motec is a great unit no doubt, but I keep seeing everyone throw it around like it is just one of the plug+play options for us. Where are all the 350Z's running it, installing it, supporting it?
I threw this out there as a joke cause I don't think I have ever seen it used in a Z application. Not on the forums anyway.
The Haltech Platinum has been tested on 5AT and has no problem with the automatic.
