ATI Procharger SC pulley for 20psi+
Old Aug 24, 2007 | 01:46 PM
Jay'Z's Avatar
Jay'Z
Exclamation ATI Procharger SC pulley for 20psi+
Anyone know how I could get a pulley for over 20psi.. I called procharger and they said they only make up to 11psi=weaksauces.........
Hoping prob some FI Vendors will chime in.. or anyone with SC pulley knowledge........ I know my teeth count is .. like 40/22 I cant get a good read on it right now..
If I could get like 42/18 that would be sick.. or maybe even 44/16
Old Aug 24, 2007 | 01:58 PM
klimaxx805's Avatar
klimaxx805
Try these guys http://www.aspracing.com/frame.htm
--Frank
Old Aug 24, 2007 | 02:06 PM
Jay'Z's Avatar
Jay'Z
--Frank
Thanks Frank! So far it looks as they have nothing for the C-2.. I may have to call tomorrow..
Old Aug 24, 2007 | 02:36 PM
booger's Avatar
booger
jon
Ive never got a good look at a ATI blower kit . Does it have a serp pulley coming off the crank pulley . That turns your longer cog belt ????
Old Aug 24, 2007 | 02:44 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by booger
jon
Hold up.. Ill post pics.......
Old Aug 24, 2007 | 02:47 PM
Jay'Z's Avatar
Jay'Z
Its the two cogs on the end of the belt.. The lower one by the radiator.. and the upper one by the radiator cap.. Those control boost..
Old Aug 24, 2007 | 02:53 PM
booger's Avatar
booger
So it has a cog pulley bolted to the crank ? Or a serp pulley and belt that turns the two cog belts I see in the pics
Old Aug 24, 2007 | 02:56 PM
Jay'Z's Avatar
Jay'Z
serp....... lemme post pics of bumper off...... http://www.exoticperformanceplus.com....html?item=394 scroll down..
Old Aug 24, 2007 | 03:10 PM
booger's Avatar
booger
OK...none of them showed me what I was asking .
You have two cog [toothed ] belts . The longer one turns the jackshaft [ front bumper side of bracket ] which turns the blower belt [rear bumper side of the bracket ] . What I was trying to find out is . WHat is coming off the crank pulley to turn your first cog belt I see in the pics ? Is it the serp belt that turns the AC pump and power steering pump ????
Old Aug 24, 2007 | 03:14 PM
Jay'Z's Avatar
Jay'Z
Yes.. Ill go take pics of the actual shizza now.. BRB
Old Aug 24, 2007 | 03:17 PM
sentry65's Avatar
sentry65
the burninator
oh man, is that tiny little mini AC belt really responsible for turning the entire cog pulley system on the ATI kit?
Old Aug 24, 2007 | 03:28 PM
Jay'Z's Avatar
Jay'Z
Here are the pics..
Old Aug 24, 2007 | 03:36 PM
sentry65's Avatar
sentry65
the burninator
oh, so it uses a longer main belt to turn a pulley that is connected to the cog
Old Aug 24, 2007 | 03:38 PM
Jay'Z's Avatar
Jay'Z
Foshizzle.......
Old Aug 24, 2007 | 03:45 PM
booger's Avatar
booger
It looks to be the Power steering pump pulley belt ...If Im looking at it right . Either way it does have a shorter serp pulley belt and that is why the ATI is able to build a few more psi than the vortech . I think Trefling was able to get his to 15psi before the belt slipped . M ight want to PM him and ask about what pulley's hew used .
Old Aug 24, 2007 | 03:48 PM
Jay'Z's Avatar
Jay'Z
I got the same pulleys he used.. I want more power, over..
I already have the 14-16psi pulley.. I want a 20 psi pulley or more.. So i can hit high boost earlier in the rpms.. And smoke shiiiiiiiiiiiiiiiiiiiet.. BTW well see how she does with the new belts on tuesday.. Maybe it was all the belt alignment that made me lose so much hp... I should have waaaaaaaaaay more than 420whp/377tq
Old Aug 24, 2007 | 03:59 PM
booger's Avatar
booger
Good luck Tuesday !!!!
Old Aug 24, 2007 | 04:12 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
[QUOTE=jonb7007]I got the same pulleys he used.. I want more power, over..
I already have the 14-16psi pulley.. I want a 20 psi pulley or more.. So i can hit high boost earlier in the rpms.. And smoke shiiiiiiiiiiiiiiiiiiiet.. BTW well see how she does with the new belts on tuesday.. Maybe it was all the belt alignment that made me lose so much hp... I should have waaaaaaaaaay more than 420whp/377tq[/QUOTE
You smoke shieeet? Dang I figure you just smoked Privates. God luck with the new belts.
Jay'Z's Avatar
Jay'Z
Thanks, I think it was the belts/alignment though.. If you look at eltness Sig he made 430whp at 11psi..
Old Aug 24, 2007 | 05:46 PM
Jay'Z's Avatar
Jay'Z
LMFAO!!!!!! u stupid man..
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
