Problems with buying used cams?
Old Aug 27, 2007 | 12:23 PM
Gman2004's Avatar
Gman2004
Originally Posted by stormcrow
i almost guessed that these were your cams, doc... so, no one is trying to let ill-will fly here...
sorry I didn't mean to imply I thought there was ill-will with anyones' responses. I should have worded my post better.
Old Aug 27, 2007 | 12:28 PM
stormcrow's Avatar
stormcrow
it's cool... i just thought you felt my post a jab when it wasn't and i wanted to clarify... btw, what's up with your ride? getting new goodies or what?
Old Aug 27, 2007 | 12:41 PM
Kenk2's Avatar
Kenk2
Professional
Originally Posted by QuadCam
Tim,
it looks like you'll have a new motor before I will!
I am still waiting on revup cam cores. I am having custom cams ground.....and my heads are still being ported. In the mean time, I am up to my as in parts, though. Including the engine in my car,I have 3 full revup motors.
Damn you Andrew.. I am still trying to find a non rev up motor..
Old Aug 27, 2007 | 01:04 PM
Gman2004's Avatar
Gman2004
Fixing the ol headlift and since the motor is coming out I am changing the cams.
New mods coming.
GTM Stage 3 turbo cams
GTM's version of L19's
HKS head gasket
HKS EVC 6
HKS Navigator - with oil temp and egt sensors
AAM stage II fuel system - (I know it's not the best, but my wife bought it for me last Christmas and besides there's nothing else on the market besides the APS extreme system. I don't need everything that comes with the extreme, plus I see mixed reviews. As far as CJM stage 3, I can't wait any longer. Anyway for the power I am looking for the AAM stage II will work.)
GTM cooling fans and shroud
New tune - low and high boost on 91, 93, and a race gas map.
Tein Mono Flex w/EDFC
Old Aug 27, 2007 | 01:18 PM
Gman2004's Avatar
Gman2004
Just so that there is no drama, (people know that Sharif has worked on my car in the past) the reason I took my car to GTM instead of Forged is because I had to take a business trip to Southern CA so I decided to drive my car out there since I used to live in San Diego and hadn't been there in over 8 years. I was able to kill a couple of birds with one stone and visit some friends, drop my car off, and take care of my business trip. Before I knew I had to go to CA on business, I was already making arrangments with Sharif. I was also considering Japtrix since they recently just became HKS certified.
Old Aug 27, 2007 | 01:37 PM
chris'smax's Avatar
chris'smax
check for any wear marks on the journals caused from improper oil lubrication.
I know when i bought a set of used cams i also did a dye penetration test on the shaft to check for any hairline cracks. This may be overkill but it doesn't hurt.
Old Aug 27, 2007 | 01:39 PM
Gman2004's Avatar
Gman2004
how many miles on the used set you bought and did you have any problems with them after install?
Old Aug 27, 2007 | 01:40 PM
TENGAI's Avatar
TENGAI
New mods coming.
HKS head gasket
HKS EVC 6
I believe these are the 11mm ARP 2000 headstuds? Check with Sam on these as I ended up purchasing a set by mistake when looking for actual L19 headstuds. FYI - you can only torque them down to a MAX of 85 ft. lbs. as opposed to 92+ with the L19. I'm in the process of building 2 blocks, so they ended up in one of the engines anyway... But long story short, I bought them originally hearing that they were actually "better" then L19 headstuds... Found out later that they weren't exactly what I thought they were. No big deal, but just so you know in any case.
Old Aug 27, 2007 | 01:45 PM
chris'smax's Avatar
chris'smax
They were used for around 3k miles. No never had any probs with them while i had the car, but i sold the car after only having them installed for a month.
Old Aug 27, 2007 | 01:48 PM
chris'smax's Avatar
chris'smax
BTW OP,
another thing you want to check is if the cams were installed by a professional shop or someone who knows what they were doing. The reason i say this is because if the cam caps were not torqued down in the correct sequence and w/ the proper torque then it could warp the cam itself.
Old Aug 27, 2007 | 02:26 PM
TTRANK's Avatar
TTRANK
Tim,
Hey buddy!
I am looking at doing my build in October. UMS Tuning is moving so I have to wait until they are moved to start this project.
Why do you have the 3rd motor?
Old Aug 27, 2007 | 04:22 PM
stormcrow's Avatar
stormcrow
New mods coming.
HKS head gasket
HKS EVC 6
sounding sick... what whp are you aiming for this time? also, will you be back up in ATL any time? if so, let's meet up...
Old Aug 27, 2007 | 04:47 PM
QuadCam's Avatar
QuadCam
Originally Posted by TIMMAHH
Hey buddy!
the 3rd motor is just to have another motor. I may do a pretty crazy project with that one........but I mainly picked it up because the price was right.
Old Aug 27, 2007 | 04:50 PM
TTRANK's Avatar
TTRANK
Can you say 4.15L
Old Aug 27, 2007 | 06:43 PM
Weqster's Avatar
Weqster
as long as there is no excessive lobe scoring, 2nd hand cam's are perfectly good. I come from the honda community where cams are slutted around more then bad VRT jokes. 20yr old vtec cams, revved to 9k with double valve springs. these things get a workout. no issues at all as long as the head wasnt bad when they were taken out.
Old Aug 28, 2007 | 07:02 AM
QuadCam's Avatar
QuadCam
check the lobes and the base circle of the cams. see if there is any runout in the basecircle or on the cam journals.
Old Aug 28, 2007 | 07:48 AM
Gman2004's Avatar
Gman2004
BTW OP,
My motor was built by SGP. While I do have some issues with some of the work that they did on my car, I have to say they built a great motor. I have posted this in the past as well. I am not just saying this to sell my cams.
Old Aug 28, 2007 | 07:50 AM
  #38
Gman2004's Avatar
Gman2004
I will guarantee that they are in perfect working condition. If the buyer has them checked out by a trusted shop before they are install and they claim the cams are no good, I will refund the purchase price after the cams are returned to me. I will also pay for the shipping cost back to me.
Old Aug 28, 2007 | 07:51 AM
  #39
Gman2004's Avatar
Gman2004
Also anyone interested can call Sam @ GTM and ask him if he thinks the cams are damaged or not.
Old Aug 28, 2007 | 09:38 AM
  #40
Julian@MRC's Avatar
Julian@MRC
Cams Shipped, thank you.
Uriyo_
Sep 8, 2021 08:46 AM
