Utec Map Sensor Calibration Off?
Old Aug 27, 2007 | 02:58 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Default Utec Map Sensor Calibration Off?
For about 3 months I thought I had a severe boost leak because my utec would never show boost higher than 7.5 psi. Well after eliminating every boost leak my stupid a$$ looks at the dashboard on the UTEC with the car off... the map sensor is reading -1 psi just sitting in open air... so I guess I was hitting 8.5 psi the whole time.
Anyways I have the parameters set to Absolute and it reads -1 psi. when i have it set to Gauge it reads +19.4 psi... I dont know if my sensor is faulty or if it is supposed to be like this. I used the calibration card to calibrate it in the parameters, but im not sure if i should toy with it or get another map sensor.
Any input?
Old Aug 27, 2007 | 03:35 PM
KPierson's Avatar
KPierson
Sorry, I can't read.
I would contact TurboXS for a replacement.
Old Aug 27, 2007 | 04:16 PM
jining's Avatar
jining
Hmm call turboxs indeed
Old Aug 27, 2007 | 06:12 PM
Blackbird CPV35
wtf, this will be the 2nd map sensor they had to replace. what a bunch of ****
Old Aug 27, 2007 | 06:16 PM
jining's Avatar
jining
how odd.. do you have a boost gauge to confirm its reading wrong?
Old Aug 27, 2007 | 06:20 PM
Z PHAT Z's Avatar
Z PHAT Z
You might also upgrade the software if you haven't done that.
Old Aug 27, 2007 | 07:00 PM
Blackbird CPV35
it has the 2.8 software, and no I havent referenced it with a boost gauge. I just dont understand why it would read -1 psi with the car off
Old Aug 27, 2007 | 07:03 PM
jining's Avatar
jining
yea that isnt right i dont think
Old Aug 27, 2007 | 07:12 PM
jining's Avatar
jining
let me go check mine give me a second
Old Aug 27, 2007 | 07:15 PM
jining's Avatar
jining
Yea yours isnt calibrated right or something, mine reads +.1 with the car off so I think mine is slightly off as well.
Old Aug 27, 2007 | 07:31 PM
Blackbird CPV35
thanks for confirming, i will call turboxs tomorrow morning
jining's Avatar
jining
np
Old Aug 28, 2007 | 05:47 AM
Blackbird CPV35
soooo, I just called TurboXS and Jermaine said that -1psi sitting with the car off is normal, which I think is bs. Usually they are pretty good at helping me out but this time they had no interest. He told me to just play with the calibration numbers or something
Old Mar 24, 2008 | 06:21 AM
merlin3's Avatar
merlin3
did you ever get this taken care of as I have the exact same problem. My txs map sensor is constantly reading -1 psi less than what it is supposed to be. I need it to be accurate as I took out my boost gauge and was planning on just using the map sensor to display my boost on my car pc screen.
Old Mar 26, 2008 | 01:57 PM
SpoilsofWar's Avatar
SpoilsofWar
My utec says +.4 (absolute) when the car is off. I have not calibrated the map sensor though.
Which brings me to my question:
How do you use the map sensor calibration card to enter the values into the utec? For example, my calibration card states:
PSI Output
Cal 1 input: 1176 Cal 1 output: 7.13
Cal 2 input: 1725 Cal 2 output: 20.18
BAR Pressure Output
Cal 1 input: 875 Cal 1 output: 0.00
Cal 2 input: 1485 Cal 2 output: 1.00
So my question is how do these figures translate into the between 1 and 300 values that the utec wants you to enter for map calibration? The only thing I could think of was for the PSI numbers to divide input by output, because both of those would result in numbers between 1-300... But this is just a guess.
Old Mar 26, 2008 | 02:45 PM
JonnyC's Avatar
JonnyC
I would also like to know, since my used MAP sensor didn't come with a card, and the settings on the UTEC are the default settings from the manual.
Intercept must be the value for 0 psi, and gradient is the rate by which the value will increase per a certain increase of boost - hmmm, yeah, not much information included to determine this. Hopefully someone knows.
Old Mar 26, 2008 | 03:57 PM
str8dum1's Avatar
str8dum1
u shouldnt have to mess with the calibration. Performance factory said thats for the tunerxs, not the utec. Have you called Jermaine at TurboXS?
Mine is spot on.
Old Mar 26, 2008 | 04:06 PM
TinmansZ's Avatar
TinmansZ
PSI Output
BAR Pressure Output
+1, I recently had to replace a bad map sensor. I've read the utec manual a time or two and have an idea as to how to set it up but it doesn't reallly explain the calibration card and how that applies. Hopefully one of the experts on here can chime in and help us out.
Old Mar 26, 2008 | 06:12 PM
KPierson's Avatar
KPierson
PSI Output
BAR Pressure Output
350Z UTEC Gradient 116
350Z UTEC Intercept 179
What can I say, I'm good with numbers.....
Actually, TurboXS provides a MAP calibration spreadsheet that you can enter the information in and it will spit out the calibration. I'm not sure why they can't just put the actual UTEC info on the calibration card.
Old Mar 26, 2008 | 06:13 PM
KPierson's Avatar
KPierson
Mine is spot on.
I'm pretty sure TurboXS recomends putting in your MAP calibration data. Without it, the UTEC won't read data correctly.
