Help!!! installed knock sensor now car dies!
Old Sep 3, 2007 | 01:01 AM
jining's Avatar
jining
Default Help!!! installed knock sensor now car dies!
Well.. I just installed a turboxs knock lite, and now when my car reaches 2.5k rpm the motor shuts off...
When I turn the car on, it shuts off immediately, and then if I start it a 2nd time then the car will idle... then when I accelerate to 2.5k it shuts off.
Tried it 4 times does the same exact thing each time.
Limp mode eh?
Old Sep 3, 2007 | 01:43 AM
jining's Avatar
jining
I also just noticed my outside temperature is reading 107 degrees wtf.. im certain the knock sensor is wired correctly. Verified with the FSM.
I unplugged the negative terminal on the battery and I will see if anything changes in the morning :P
Any input would be greatly appreciated!
Old Sep 3, 2007 | 01:53 AM
bizcotch's Avatar
bizcotch
reset the ecu and TB if necessary, it has to relearn itself.
Old Sep 3, 2007 | 03:25 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
man, its cool you are doing all your own work but you have the worst luck!!
good luck to ya from here on out!!
Old Sep 3, 2007 | 04:56 AM
Julian@MRC's Avatar
Julian@MRC
What exactly do you mean you installed aTurbo XS knock sensor?
Are you saying you installed a tuner pro??
Old Sep 3, 2007 | 09:32 AM
jining's Avatar
jining
woops I meant knock lite
Old Sep 3, 2007 | 09:36 AM
jining's Avatar
jining
Going to try and start the car up.. I really REALLY hope it works, thanks for the luck Audible
Old Sep 3, 2007 | 12:53 PM
jining's Avatar
jining
Well it didnt work at first, but I re-plugged in the ECU harness and now it works... wtf :P I guess it just was not seated correctly on the pins.
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
Inspatatrac
Sep 8, 2015 02:12 PM
