need some help with fixing a few codes
Old Sep 22, 2007 | 03:45 AM
kevin8086's Avatar
kevin8086
Default need some help with fixing a few codes
p1168 Closed Loop Control (Bank 2) so wich sensor is this exactly?
p1065 ECM Power Supply Heater
p1051 A/F Sensor heater (Bank 2)
can someone please point me in the right direction on fixing these?? thanks
i have a utec and the stock ecm has a technosquare reflash. i only have the front 2 o2 sensors and am running test pipes. i was told that i shouldnt have any problems with not having the rear o2 sensors. Sam from GTM told me this during our tuning this past monday. he could not retune the car due to fuel trim code, he also stated what i posted above.
Old Sep 22, 2007 | 06:14 PM
kevin8086's Avatar
kevin8086
no one??
Old Sep 22, 2007 | 06:35 PM
westpak's Avatar
westpak
SFZCC
P1051 - Possible causes - Harness or connectors (The A/F sensor 1 heater circuit is open or shorted.) or Air fuel ratio (A/F) sensor 1 heater
P1065 - Possible causes - Harness or connectors [The ECM power supply (back-up) circuit is open or shorted.] or ECM
p1168 - Possible causes - Harness or connectors [The air fuel ratio (A/F) sensor 1 circuit is open or shorted.] or Air fuel ratio (A/F) sensor 1 or Air fuel ratio (A/F) sensor 1 heater
Old Sep 22, 2007 | 07:01 PM
kevin8086's Avatar
kevin8086
which is sensor 1
Old Sep 22, 2007 | 07:02 PM
kevin8086's Avatar
kevin8086
if my car runs fine what could be wrong with the ECM, i mean what does open or shorted mean
Old Sep 22, 2007 | 07:31 PM
westpak's Avatar
westpak
SFZCC
Sensor 1 is the first sensor and both codes are for the passenger side.
Old Sep 22, 2007 | 09:49 PM
kevin8086's Avatar
kevin8086
cool thanks, now i just need some help on the ECM code and what could cause that problem
Uriyo_
Sep 8, 2021 08:46 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
