Question about Greddy TT kit w/ open DP's
Old Oct 2, 2007 | 07:13 AM
JAM3Z's Avatar
JAM3Z
Phenom
yeah, thats pretty much exactly what im looking for. some one mentioned something earlier about the car smelling like exhaust, which is something i obviously dont want. would i get that smell with this setup?
Old Oct 2, 2007 | 07:18 AM
punish_her's Avatar
punish_her
Um I realy did not notice any but I've gotten use to the duals and TP's. Theoreticly you shouldnt notice any exhaust smell from the opening of the waste gates dumping becuase your accelerating fairly fast. Not like the formentioned exhaust setup that just passes it straight through.
Old Oct 2, 2007 | 07:34 AM
taurran's Avatar
taurran
Your car is going to smell like exhaust unless you run stock or high flow cats. A turbo downpipe (such as the APS, AAM, or FP downpipes) are basically "test pipes" that bolt up to a turbo, meaning you eliminate the catalytic converters. On a turbo setup, you want absolutely no back pressure if you want to make the most efficient power. Unless you're willing to sacrifice a good amount of power, you're going to want to go with some large down pipes. The car will obviously smell a little if you stand behind it or let it idle in one place for a long time. It's not THAT bad, really.
As stated above, the wastegate dumps will alleviate some more back pressure, but the car won't smell any more because they only open when the turbos are spooling and the car is moving.
If you're set on running cats with the TT system, open wastegate dumps might not be a bad idea as they'd help alleviate some of the back pressure while the turbos are spooling.
Old Oct 2, 2007 | 07:38 AM
IslandZavage's Avatar
IslandZavage
how much faster would the turbos spool up? Will the closeness (is that a word..lol?) of how soon they open up to 3inch differ in performance? Im comparing the SGP to the AAM's.. The SGP's seem too open up closer to the turbo..
Old Oct 2, 2007 | 07:49 AM
taurran's Avatar
taurran
With the open dumped wastegates? The spool should be SLIGHTLY improved, but on a TT setup I don't think you will really notice much difference. The gain comes from alleviating back pressure caused by recirculating the exhaust gasses back into the exhaust stream, which allows the turbos to flow larger volumes of air more efficiently, making more power.
Oh, and they sound cool too....
Old Oct 2, 2007 | 08:00 AM
IslandZavage
I know.. I heard them this week at Bradenton and was like DAMN!!! Sounded so sick I have to have em.. I regret not doing them ...
Old Oct 2, 2007 | 08:02 AM
IslandZavage
Hey Taurran
what about, Will the closeness of how soon they open up to 3inch differ in performance? Im comparing the SGP to the AAM's.. The SGP's seem too open up alot closer to the turbo..
Old Oct 2, 2007 | 09:31 AM
taurran's Avatar
taurran
Hey Taurran
(Referring to down pipes)
I would think it would make a slight difference in theory, because the exhaust gasses should be the hottest right at the turbo exducer (and fully expanded). But we might be splitting hairs at that point when it comes to noticable performance increase. A shop that's played around with both sets of pipes might be able to give their opinion.
You could always buy both and do your own dyno comparison!
Old Oct 2, 2007 | 10:03 AM
JAM3Z's Avatar
JAM3Z
Phenom
this has turned into a pretty informative thread
Old Oct 9, 2007 | 05:22 PM
JAM3Z's Avatar
JAM3Z
Phenom
would thr AAM kit work with my nismo exhaust?
Old Oct 9, 2007 | 06:21 PM
JAM3Z's Avatar
JAM3Z
Phenom
anyone...?
Old Oct 9, 2007 | 06:30 PM
taurran's Avatar
taurran
I believe it would bolt up to the y-pipe, but using 3" downpipes on that exhaust would just defeat the purpose of the downpipes.
Old Oct 9, 2007 | 06:38 PM
JAM3Z's Avatar
JAM3Z
Phenom
yeah, obviously to maximize the benifit of this setup, an exhaust like the EvoTT is a must. damn.....this is really starting to add up, lol.
Old Oct 9, 2007 | 06:53 PM
rrmedicx's Avatar
rrmedicx
This is the SVRT set-up:
Installed:
The Left:
Both from a little further back:
Old Oct 9, 2007 | 06:56 PM
JAM3Z's Avatar
JAM3Z
Phenom
^i see that those are the dump tubes. does the svrt include down pipes? btw, do you have a link to their site?
Old Oct 9, 2007 | 07:01 PM
rrmedicx's Avatar
rrmedicx
Unfortunately no they don't. I purchased a wastegate relocator kit because that is one of the known weaknesses of the Greddy. With a decent sized diameter test pipe and a free flowing exhaust you can make some really good power.
Here is the link:
http://www.svrtechnologies.com/1.html
Old Oct 9, 2007 | 11:00 PM
punish_her's Avatar
punish_her
Yeah same as mine, but I went with the ceramic coating to help keep the radient heat down.
Old Oct 10, 2007 | 12:17 AM
  #38
Sam405's Avatar
Sam405
I'll try to post my setup when i get the camera back.
Old Oct 10, 2007 | 12:29 AM
  #39
JDMFairladyZ33's Avatar
JDMFairladyZ33
So how the hell do you kids pass emission with this setup?
Old Oct 10, 2007 | 01:20 AM
  #40
phunk's Avatar
phunk
CJ Motorsports
i just installed my SGP 3" downpipes with open dumps over the weekend. i changed out my wastegate springs to 10.1 psi springs while i was in there since i am getting ready to tune it to 16-17 psi in the next few days hopefully.
i havent owned a car with open dump in a while. the sound is definatly stereophonic since there are 2 on this car rather than 1 like the last car i had it on. its extremely aggressive and i dig it for now, but sometime in spring/summer 08 i will bring it back into the downpipes.
i ran into issues with compatability between this setup, which is almost identical to the one in the pics above, and my fuel plumbing. I didnt like how close the fuel lines were to the wastegate extension pipe or the downpipe. i went ahead and made a custom hardpipe and new hoses that travel a different route than my standard stage 2 kit. i firesleeved everything as well, and heat wraped the hot parts in the area of concern. i also got rid of the goldish bracket that holds the wiring harness to the trans and used adel clamps to secure the harness about 1.5" further back to get it away from the hot parts.
ill try and get pics of it this week. at first i would concerned about the wastegate extension tube eventually cracking and my 38mm bouncing down the expressway, but when installing i noticed they used very damn thick wall pipe to reduce that risk.
